Question about ASUS VW222U Monitor
Enable overdrive on screen
A pop up keeps appearing "enable Overdrive" and i can`t get rid of it or activate etc, any ideas - thanks
  • tembleke23 Apr 20, 2009
    no para de salirme enable overdrive en mi monitor ya no se ke acer ayudarme porfavor
у меня на екране показывает Enable over driver (Yes no) ничего немогу зделать показывает по центру. Ето сообщение невозможно выключить. помогите кто сможет.
Windows 7 ultimete 64-x
nvidia Geforse 9600GT
intel core2 duo CPU E8200
2.66GHz
2.67GHz
RAM 4,0GB
[URL=http://fastpic.ru/][IMG]http://i13.fastpic.ru/big/2011/0109/69/6b3db7b0dbe4318765b52ad3b6a5ca69.jpg[/IMG][/URL]
Posted on Jan 09, 2011
2 Suggested Answers
SOURCE: enable Overdrive
yes, the problem is off by itself, i did nothing:) thanks for your interest;)
Posted on Aug 26, 2009
Downloading library books
not sure if this will help.....ERROR: "User not activated" appears when trying to open Overdrive ebooks on a Nook. The problem is likely that your Nook came preloaded with an Adobe Digital Editions (ADE) folder and because of this your ADE program won't recognize your device. 1. Go to "My Computer" (or the equivalent on your PC or MAC).
ERROR: "User not activated" appears when trying to open Overdrive ...
www.hooverlibrary.org/.../error-user-not-activated-appears-when-trying-open-overdrive...
Dec 09, 2016 | Tablets & eReaders
I have a 1999 Chevy 2500 he diesel and over drive pops in and out...now it will not shift from first
Automatic trans having overdrive issues - Diesel Bombers
www.dieselbombers.com > ... > 12 Valve 2nd Gen Dodge Cummins 94-98
Apr 22, 2011 - '96 dodge 2500 transmission is having trouble staying in overdrive. ... Hetold me it could be the Throttle Position Sensor, the computer needs ... Oh and another thing, The brake safety for shifting out of park is .... 95 chevy 3500 6.5l trans issues, drgracen, Chevy/GMC 6.2L and 6.5L, 1, 10-05-2015 10:13 PM.
Keeps Jumping in and out of overdrive
Mar 25, 2012
4l80 no overdrive or reverse
Mar 10, 2012
4l80E overdrive problems
Dec 10, 2011
More results from www.dieselbombers.com
The most ridiculous Overdrive questions - Diesel Place : Chevrole
Dec 02, 2015 | Cars & Trucks
The Enable Overdrive menu pops up on the screen when i turn it on and it wont go away. ive checked to see no buttons are stuck in aswell but it will not go away
are you sure it isnt software installed on your pc that is displaying the overdrive menu . Check to see if you have it installed, as as far i can recall there is no overdrive program for monitors. They are used to overclock the cpu of your computer
If this has helped you please give feedback by voting
Feb 23, 2011 | ASUS MW221U LCD Monitor
I have a 2000 Expedition 4.6L Triton. I've had truck about 7 years and love it. I have had all the transmission issues this truck can have...(I thought) until now this: SYMPTOM Transmission drives well in...
4R100 or 4R70W?
Geartrain
Power is transmitted from the torque converter to the geartrain components through the input shaft and forward clutch cylinder.
  • By holding or driving certain members of the gearset, four forward ratios and one reverse ratio are obtained and transmitted to the output shaft. The ratios are as follows:
GEAR RATIO 1ST 2.71 to 1 2ND 1.54 to 1 3RD 1.00 to 1 4TH 0.71 to 1 REVERSE 2.18 to 1
Input Shaft
The input shaft is supported by two bushings in the stator support. End positioning of the input shaft is controlled by the splines in the converter turbine and the overdrive planet assembly.
Output Shaft
The output shaft is supported by two bushings in the case and by the slip-yoke and bushing in the extension housing. End positioning is controlled by the parking pawl gear and snap ring or shoulder and by the reverse ring gear hub and snap ring.
Overdrive System
The overdrive planetary system consists of the overdrive planet assembly, overdrive sun gear, overdrive ring gear, coast clutch cylinder, overdrive one-way clutch assembly and the center shaft, as shown in the following illustration. The overdrive planet assembly is splined to the input shaft. The overdrive sun gear is centered by a bushing on the input shaft and held in place laterally by needle bearings on the reactor support and the overdrive planet assembly. The overdrive sun gear is splined to the coast clutch cylinder, which in turn is splined to the overdrive one-way clutch inner race.
The outer race of the one-way clutch is splined to the overdrive ring gear, which is splined to the center shaft. The center shaft is centered by the forward planetary assembly and is laterally held by needle bearings on the center support and the overdrive planet assembly. The center shaft is splined into the forward clutch cylinder.
Two friction clutches are assembled in the overdrive planet assembly. The coast clutch is splined between the coast clutch cylinder and the overdrive ring gear. The coast clutch is activated to perform engine braking in MANUAL 1, MANUAL 2 and third gear with the transmission control switch engaged.
The overdrive clutch is splined between the case and the coast clutch cylinder. The overdrive clutch holds the coast clutch cylinder and, in turn, the overdrive sun gear, to permit the planet assembly to overdrive the ring gear.
Forward Drive System
The forward drive system consists of the forward clutch cylinder, intermediate brake drum, intermediate one-way clutch, input shell, forward ring gear, forward ring gear hub, forward/reverse sun gear and the forward planetary carrier and forward planetary gears.
The forward clutch cylinder is splined on the center shaft. The forward ring gear is piloted on the forward ring gear hub. Thrust bearings on the forward planet assembly and forward clutch cylinder hold the forward ring gear hub in place.
The intermediate brake drum is radially supported by bushings on the center support and is laterally controlled by thrust washers on the forward clutch cylinder and center support. The intermediate brake drum has the inner race of the intermediate one-way clutch press-fitted on its pilot. The intermediate one-way clutch's outer race is splined to the intermediate friction clutch, which is splined to the case. The intermediate brake drum has lugs that are slotted into the input shell to form a mechanical connection. The input shell is splined into the forward/reverse sun gear. The forward/reverse sun gear is common to two planetary gearsets. The forward planet is splined to the output shaft and is laterally positioned by needle bearings on the sun gear and on the forward clutch cylinder, as shown in the following illustration.
Two friction clutch assemblies, the direct clutch and the forward clutch, are shown with the forward planetary assembly. The direct clutch assembly splines the forward clutch cylinder to the intermediate brake drum. The forward clutch assembly splines the forward clutch cylinder to the forward ring gear. The forward clutch is activated during all forward gears. While in third or fourth gear, both the direct and forward clutches are applied to hold the forward planetary assembly and enable it to act as a solid shaft.
In second gear, the intermediate clutch assembly holds the forward/reverse sun gears. It is applied, along with the intermediate one-way clutch, to hold the intermediate brake drum, input shell and forward/reverse sun gear. In higher gears, the one-way clutch overruns.
Low and Reverse Drive System
The reverse planetary assembly consists of the reverse planetary carrier, reverse planet gears, the reverse ring gear, the reverse ring gear hub, the reverse clutch hub and the low-reverse one-way clutch assembly.
The reverse ring gear hub is splined to the output shaft and to the reverse ring gear. The reverse ring gear hub is laterally held by a needle bearing on the inner race of the low-reverse one-way clutch and a snap ring on the output shaft. The reverse planet assembly is splined to the low-reverse clutch hub. The low-reverse clutch hub is connected by the reverse clutch to the case. The inner race of the one-way clutch is bolted to the case.
The reverse clutch assembly is activated in REVERSE gear and in MANUAL 1. The reverse clutch bypasses the reverse one-way clutch during coast and MANUAL 1. The reverse clutch holds the reverse planet assembly in REVERSE gear to enable the sun gear to drive the reverse ring gear in the opposite direction.
Apply Components
The following information describes the operation of the three 4R100 one-way clutches.
One-Way Clutch—Overdrive
The overdrive one-way clutch, shown in the following illustration, transmits engine torque from the overdrive sun gear to the overdrive ring gear in first, second and third gear range. The overdrive one-way clutch transmits power when the sprags are engaged between the inner and outer races. The inner race is splined to the coast clutch cylinder, which in turn is splined to the overdrive sun gear. The outer race is splined to the overdrive ring gear.
The overdrive one-way clutch engages whenever the overdrive planetary system attempts to drive the overdrive sun gear clockwise when the overdrive ring gear has a counterclockwise torque from the vehicle. When torqued counterclockwise, the overdrive one-way clutch engages and acts as a wedge to lock the sun gear and the ring gear together. During coast, the overdrive one-way clutch enables the ring gear to overrun or spin at a faster rate than the sun gear.
The overdrive one-way clutch overruns when in overdrive (fourth gear). In overdrive, the coast clutch cylinder is held by the overdrive one-way clutch, which in turn holds the overdrive sun gear. This causes the overdrive planet assembly to walk around the sun gear and overdrive the overdrive ring gear. The inner race of the overdrive one-way clutch is thus held stationary while the outer race is allowed to overrun clockwise.
Nov 10, 2009 | 2000 Ford Expedition
Enable Overdrive
Aug 25, 2009 | ASUS VW222U Monitor
1992 volvo 240 keeps blowing overdrive fuses
More likely that the solenoid in the transmission is shorted to ground. Has any new electronic equipment been installed recently, like stereo, alarm, etc?
Feb 10, 2009 | 1991 Volvo 240
What are these buttons for? e t c drive & side of shifter
The ETC switch is a transmission control device. When it is not active, the transmissions shifts normally. When the ETC is engaged, it alters the shift points.
Example: the 1-2 upshift occurs normally between 18-20 mph. Now, say you are towing something, or are carrying a heavy load...engage the ETC, and the trans computer will "hold" the 1-2 upshift until 22-24 mph. It is just for that, prolonging the shift points, due to load.
The switch on the side of the shifter is for the Overdrive. Engaged (the OD light is off) the transmission shifts into overdrive. This saves you gas. When the button is dis-engaged (the OD OFF light is on) , the transmission does NOT shift into overdrive. It is best to leave the overdrive ON, and the ECT OFF to obtain maximum fuel mileage. I hope this has answered your question. Please feel free to comment back if you have any other questions. Thanks for chosing FixYa for assistance.
Jan 12, 2009 | 1995 Toyota 4Runner
A light on dash saying o/d off came on
There is a small button on the gear shifter. This is the OverDrive switch. When the button is depressed "IN", the overdrive system is active, and the light on the dash is off. When the button is OUT, the overdrive system is de-activated, and the light on the dash is illuminated. The OverDrive is basically the final shift of the transmission, which gives you maximum fuel economy. When the light on the dash is ON, the OD is "OFF", the transmission will not make its final shift, and will lower your fuel economy. It is best to leave the button IN, and have the OD system active. Hope this helps, and Thanks for Choosing FixYa. The graciousness of a "FixYa" rating for my solution would be greatly appreciated. Thanks for allowing me to help you with your issue.
Nov 19, 2008 | 1999 Toyota Camry
ASUS VW222U Monitor Logo
1,767 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
