Question about Panasonic Lumix DMC-LZ2 Digital Camera
Please turn camera off & then on again
I have a panasonic lumix DMC-LZ2 which is saying "please turn camera off & then on again" When i turn it off then back on, it repeats message after about 30 seconds. The lens doesnt go back in when camera is turned off. I have reset the camera in the menu but this didnt work either.
    Sergeant:
  • 270 Answers
Off the camera again and try to open the menu and try to reset it .if the problem persist send it to the survice center
Posted on Feb 03, 2009
  • Bobin Thomas
    Bobin Thomas Feb 03, 2009
  • John Smith
    John Smith Apr 19, 2012
    Pity this "Expert" can't spell "service"!!!
Lumix DMC-F3 When I turn the camera on, the display screen says "PLEASE TURN CAMERA OFF AND THEN ON AGAIN" when you do it, it says it again???
There is a problem with your camera Lens Assembly. It is not opening within stipulated time. The lens assy is jammed or damaged. Take it to service center.
Dec 24, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
I purchased a sdhc 4gb memory card for my Panasonic DMC-LZ2 Camara and when I put it in I get a message that says memory card error. Do I need to format it? and how do I do that
The DMC-LZ2 uses SD and MMC cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible. You will need to use SD cards 2GB and smaller.
Dec 05, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Message stating turn camera off and back on again after the camera is on a few minutes
you have dropped your camera hard. the lens array is defective now. try tapping the cam while it displays the message. if it works you are lucky. if no then you have to replace the lens array. it costs about 60$
Jul 05, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Have Panasonic Lumix DMC-TZ5. get message turn camera off
Did you drop the camera on the lens?
You have to replace the barrel (cost around 175,00 euro)
try to find a cheap second hand camera en replace the lens unit...
Jun 17, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
The lens stays extended when power is off
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
Oct 09, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Problem with Panasonic Lumix DMC-LZ2 camera
hello baylie101, this message shows when the camera picks up a lens fault, if the camera has taken a knock or drop something could have went faulty in the lens. camera should be looked at by a qualified technician.
Jun 14, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
The camera itself.
shutter not openining. ccd flex not plugged in correct or it is faulty. main pcb fault. first turn the camera on then check if the shutter opens.
May 22, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic Lumix DMC LZ2
My camera is a Lumix DMC - LS70 and the same thing was happening to me, the camera kept telling me to turn it off which never solved the problem and the lens never closed when the camera turned off. What i did was, i zoomed out as i turned the camera on (while it was in a picture taking mode) and it corrected itself. Try it and see what happens.
Sep 23, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Camera powers on, then off
My got fixed when I gave it 5 gentle, firm bangs on the carpet with the bottom facing down. Got the advice from somebody online, figured, it's already broken and about 2 years old so what do I have to lose? To me was less risky than trying to open it. The focus problem got fixed and so far no message. Worth trying
Oct 01, 2006 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
1,932 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
