Question about Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius WF220 Front Load Washer dirty rubber drum seal
Is it easy to replace the rubber seal?
  • howie44 Feb 03, 2009
    Thanks for the advice very much appreciated
  • Anonymous Mar 27, 2014
    Dirty seal
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Its a matter of removing the front retaining wire and the inner one which holds it onto the drum, an easy enough job to get off, sometimes a pain to get the inner off and on depending whether it s the screw or clamp type , screw=easy. to get the clamp off use a screwdriver to wiggle the bent wire out of the ratchet grooves. to put back is done with long nose pliers, preferably bent nose ones.
Posted on Feb 03, 2009
Horible smell comingfromthe drum, took the filter out to clean it, now it is leaking, what can I do? ps smell still there, have tried 1 95o wash with no joy
For the pump try taking filter back out and putting back again for smell clean out the rubber door seal with soapy water after the door seal is clean clean the despencer draw fully by taking it out. When you washed the seal and draw get washing machine clean for local super market and do a 95oc wash it should smell nice now if not could be drains hope this helps.
Jul 29, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Hi, the machine/drum area keeps smelling of stagnant water, no matter how many times i clean it. Is there anything i can do to stop this?
Things to do make sure despencer draw is clean and the rubber door seal is clean do a maintenance cycle every year this is the hottest wash cycle with cleaning detergent. also leaving the door open after cycle will help hope this helps
Jul 10, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Something has got between the drum and its container and it catches on the spin cycle making a nasty noise. Question 1 How can anything get in there. Question 2 how can one reach in to remove it even when...
I would enter via the sump hole ....Remove the hose 1st then you may be able to grab it failing this remove heater element and you will see it to remove...Good luck
Mar 24, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Putting back on a door seal on a hotpoint aquarius wf220 please thank you very much
For most front-loaders:
Lubricate the slot which fits over the tub with washing-up fluid. Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange. When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. This is quite difficult and you may need another pair of hands. Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps,etc)
Pl rate me nice for the free help!
May 15, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint wf220
If ther is no filter at the front of washer, then remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose, also remove hose onto pump, and check for obstruction here and in the pump.
Please rate my solution.
Thanks.
Nov 15, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Aquarius washer drum stuck
sounds as if the drum bearings have gave way was it noisey b4 this
Jun 06, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint wf220
Hi, A bleach based cleaner should improve things. It sounds like its a form of mildew , an airbourne fungus that likes damp places. Once bleached it should stay clear for a while. Make sure you rinse it after to avoid damaging your clothes. Hope this helps, Nick.
Aug 26, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius WF220 Front Load Washer Logo
439 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
