Question about Ricoh Aficio AP410N Laser Printer
Paper Jam Ricoh Aficio AP410N Problem: Paper jam. Printer won't feed paper from paper tray.
  • 903 Answers
Open up the doors and blow some compressed air throughout the paper path (where the paper travels up). Make sure to blow air onto the sensors, because paper dust can coat them, causing false jams.
Does the paper get out of the tray at all? There is a feed roller that feeds the paper up into the machine; if you remove the paper tray you can see this roller -- it's big and gray and has grooves across it -- above where the paper sits toward the front of the printer. Blow air onto this roller as well, and if you have either D-ink or a rubber rejuvinator, clean the roller with a lint-free cloth.
Also make sure the paper is snug in the tray and not bent or crooked.
Posted on Jun 05, 2010
Ricoh Aficio AP410N printer won't print on tray 1. Paper feeds through but no print on it. Tray 2 is fine???
Here are a couple of notes I found on the printer:
  • Before printing on paper other than envelopes, make sure that the levers inside the rear cover are pulled up. Leaving the levers lowered can cause print quality problems when printing on paper other than envelopes.
  • If you set [Paper source tray:] to [Auto Tray Select] on the [Setup] tab in the printer properties dialog box, the machine selects the tray automatically. (I imagine you'd have to enter printer Properties or Settings and choose a tray there.)
Nov 29, 2017 | Ricoh Office Equipment & Supplies
Ricoh Aficio 1515
is thera paper jam sensor wigle paper in and out unplug unit from wall 2 min ten back in hit sensor with paper hit reset on unit
Jan 22, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Paper jam c
Unable to print troubleshooting and routine maintanance chapter in user's guide
Mar 23, 2013 | Ricoh Aficio SP-C210SF Printer
The Ricoh Alicio SP C410dn says to open the A tabs and remove the paper jam. There is no paper jammed into the machine. The issue only arises when printing from the manual feeder and not from the paper...
You must first try to clean the paper feed roller which you will inside of the printer (bottom) when you pull out the paper tray. If this not works, then I am 100 % sure that the magnetic clutch which operates this feed roller must be replaced. I can tell you the part number for ricoh part catalog:
GX20-0014. If you don't have tech skills please don't do it by yourself because it's a hard and precision work. Call for help tech support
pifonski
Feb 25, 2011 | Ricoh Envelope Feeder Type 610 Feeder Tray...
We have a Ricoh Aficio CL3500N and every time we print the paper jams and we get the "Remove Misfeed A: Internal Path". I remove the jam and when it tries to print again we get the same thing,...
There may be an obstruction inside the printer. Try this....remove the paper from the paper tray and put paper in the handfeed tray (front of the machine) If it feeds from that tray it means that the feed rollers in the bottom cassette are worn.
Dec 17, 2010 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N printer phantom misfeed
It seems that the sensor is having dust or toner settled upon it. Kindly remove the toner and clean the residual toner. Take a hard stock paper and give one copy command and push it while it tries to pull the paper. Paper misfeed is not the same as paper jam. Paper misfeed refers to the blank paper tray and paper jam refers to paper which has been taken from the tray and now inside the unit.
May 19, 2010 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio AP410 paper tray
Try this links for the parts of Ricoh printer:
Ricoh USA
The Printer Place
Thanks
Scott
Jan 29, 2009 | Ricoh Aficio AP410N Laser Printer
Paper jam indication, but cannot find the paper that is jammed
I would check to see if the paper is even making it out of the tray. A lot of times, the feed rollers can get dirty, and the printer will display a jam if it doesn't feed in time. If the feed rollers look ok, then I would check and see if the feed rollers are even turning. Sometimes the motor that turns the feed rollers wears out.
Nov 11, 2008 | Ricoh Aficio CL7200 Laser Printer
Ricoh Aficio AP410N Laser Printer Logo
768 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
