Question about Sewing Machines
I have a fairly new NS10. I wore out my Elna SU and as I no longer need a machine that does much fancy stuff, I was advised by my sewing machine shop that the NS10 should do much of what I wanted - taking hems up, the odd bit of mending etc. I have tried to sew net curtains and there was a problem with the tension. I have just been trying to take up a pair of trousers and a pair of fine cotton jeans. The stitching is OK for a time and then it misses underneath occasionally. I have no idea this is happening until I have finished sewing. This bloody machine is pathetic and I wish I'd taken out a mortgage and bought a Swiss one. I never had to alter the tension on the Elna in 35 years and wish with all my heart that I'd bought a second hand one of those. Too late now. Does the tension have to be changed on an NS10 every time you want to do a simple job. It seems like it.
Shop where I bought it want me to take it in with the items I wanted to sew and they would see what the problem was. They said it was a lovely machine and shouldn't cause problems.
Posted on Feb 05, 2009
Having trouble replacing the bobbin case
Elna SP ST SU sewing machine repair tips - YouTube
? 2:25
https://www.youtube.com/watch?v=TqrbimZyP1U
Oct 24, 2011 - Uploaded by Absolute Sewing
More Photos on replacing gears and some repair ti... ... I amhaving trouble with my Elna SU 62 skipping stitches when I sew on knits. ... Elna Lotus SP bobbin case repair - Removing a cotton jam from a Elna Sewing machine ...
Amazon.com: Bobbin Case 627569106 - Elna, Janome ...
Jan 12, 2016 | Elna Sewing Machines
Need manual for elna su
perhaps if you google the make /model and manual you will find help
Mar 20, 2014 | Elna Sewing Machines
Zigzag feature is not working
Remove thread from machine and open door to where you put cams in. Step on pedal and run at full speed. It the mechanism where the cams go spinning? It is likely that your elna graph gear is broke
Jan 09, 2014 | Elna Sewing Machines
Bobbin case Elna 62c
Really you are very appreciated in your machine maintenance. If you wanted to Elna SU 62c machine bobbin case
please see the link :
http://www.ebay.com/bhp/elna-sewing-machine-bobbins .
Dec 29, 2013 | Elna Sewing Machines
What make of walking foot would fit my Elna su air electronic sewing machine, thankyou
You need a low shank style walking foot. Even back in the 80's when your SU air electronic was new, the walking foot sold by Elna was an after market one, and not made by Tavaro. Same with the ruffler attachment, it was after market and actually fitted quite a few makes of machine.
I would just ask the dealer/shop if they will refund your money if you find it doesn't work just in case.
There is a low shank one on sewingpartsonline.com
http://www.sewingpartsonline.com/walking-foot-low-shank-p60444.aspx and they list the SU as compatible with it.
Take off the foot holder on your mache, and you need to fit the little open ended arm over the needle bar and the foot bracket onto the foot with your machine's regular thumb screw. The up and down movement of the needle bar operates the walking foot.
Jun 25, 2011 | Elna 2007 Mechanical Sewing Machine
I purchased a used Elna su type 62cr209707. I need an instruction manual, where do i find one?
The Star Series SU is a lovely machine,
you can purchase a manual from here - well worth spending the dollars to find out how it works, especially the buttonhole which isn't like modern 4 step ones. You may also find that the foot control has a switch to give you slow speed vs normal speed sewing.
http://www.tradebit.com/filedetail.php/91117786-elna-sp-st-su-sewing-machine-manual
If you are in the USA you could also visit www.whitesewingcenter.com, they have lots of Swiss Elna goodies for sale and are very knowledgable on these machines.
You might also want to track down a newer Swiss made Elna pressure foot holder with the clip on feet, rather than using the full feet with your machine. They are interchangeable. Have you got the black discs to go with your SU too? there is a large range so you can sometimes track down some more to add to your collection.
There is also a newer black pressure foot screw which is a combined thread snip, its a bit bigger in diameter to the black thumb screw on your machine now and you can use it to cut and hold the threads at the end of each seam, very cute.
Always give this machine a good clean and oil before using it, there should be a red dot in the middle of the bobbin holder, oil here regularly and any other points that the manual shows with good quality sewing machine oil, it takes 130/705H standard sewing machine needles, put in a new needle for each project to get great stitching results.
Enjoy your SU!
Apr 15, 2011 | Elna 3210 Mechanical Sewing Machine
Need parts for Elna SU Air Electric sewing machine
My Elna repair man is also the individual I purchased my Elna from in December 1980. His name is Boyd Albright, located in Ottawa, Kansas. I have never had the issues you describe, but Boyd has always serviced my machine and as far as I'm concerend, is the best. When I was told by another sewing machine shop in Mississipi that my machine could not be fixed, Boyd did and for less than $40.00! Contact info: 1231 S Willow St
Ottawa, KS 66067-3439
(785) 242-4340
He works out of his home as he is semi-retired.
Mar 30, 2009 | Sewing Machines
Elna SU
Check the brushes in the motor. My old Elna super did the same thing. We replaced the brushes and it has been working like a charm ever since. It's 40 years old and still going strong.
Dec 07, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
50 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
