MY IQON TOWER DRIVE IS MAKING A LOUD NOISE LIKE FAN WORKING OVE
Sounds like fan inside tower is malfunctioning
  • 565 Answers
Probably just needs replaced. Sometimes one can clean it and it will last a little longer. It's an easy job to replace it. Just download the manual for your model from the maufacturer's website to see how to gain access to the inside of the computer. Replacement fans are available at places like CompUSA or similar stores, or you can order one on the internet. Just take the existing fan out of the case and take it to the store with you to be sure you get the right one. Take care about static electricity, as it can zap your components, especially the motherboard and the memory sticks. Touch the computer case before touching any parts inside the computer.
If you don't feel comfortable changing the fan out, a computer repair place can probably do it for not much.
Posted on Feb 03, 2009
  • Bob
    Bob Feb 04, 2009
    Thanks for the vote. It's also possible that the fan in the power supply is making the noise. It's easy to replace the power supply too. It's basically just a matter of taking note where each connector goes, disconnecting the cables and unscrewing it from the back. Be careful about using to much force when plugging in the plugs back into the motherboard. Again, take the power supply to the store with you. You don't need a power house, just one with the same or more watts. Make sure the connectors on the new power supply will work for you before leaving the store.. A new 300 watt power supply is probably $30 US or so
    A computer repair shop shouldn't charge to much replace one. However, do your homework on the price of a power supply so you'll be able to determine if the one they offer is a deal, or at least a fair price.
I just bought the Honeywell Quietset 8-Speed tower fan (black and silver on top). I installed it correctly but the fan is extremely loud and squeaky and can hear the inside pole that rotates the fan, even...
STOP! Before you take anything apart, turn fan upside down and find the large plastic "screw"(cord passes through it)that secures the fan to the pedestal. Is same color as unit. Loosen it and see if squeaking stops. Worked for me!
Mine was driving me nuts and I was prepared to return it to store.
Aug 30, 2011 | Honeywell Comfort Control Tower Fan -...
My cooling fan on a HP Pavillion a1133w never shuts off and is louder that what i would expect. I'm not familiar at all with the decibal count from different towers/fans. It was given to me and works...
Yeah usually towers are pretty loud; but loud is good, because then you know your fans are working and you do not want the fans to stop spinning.
Try installing drivers for your CPU, or look at the settings for your video card, or look in your BIOS; there may be a setting or driver that enables automatic control of the speed of the fans, based on the heat.
Mar 04, 2011 | Computers & Internet
Loud racing noise from the tower e 3052
Open up the side of the tower and you will be able to see the fans. You most likely have dust/hair in one of your fans or one of the fans is going bad. You can clean it out with a low pressure air nozzle or dust can.
May 29, 2009 | E-Machines eMachines Desktop PC
Makes a loud noise when it is turned on. Can't open it.
If it is making a loud humming sound it is probably getting weak and will have to be replaced. Is it doing it in all speeds? Motor replacement would probably not be worthwhile unless it is a very expensive unit. I'd opt to replace the unit.
May 16, 2009 | Bionaire BT45RC Tower Fan
Acer aspire4920 makes loud noise at start up
This could be caused by the harddrive. There might be a bad bearing or something. Please backup all your data. You will probably have to replace the hard drive sooner or later.
May 07, 2009 | E-Machines T6524 PC Desktop
Tower making loud fan noises
yes that is because the fan inside of your computer has a bit of dust on it there is not much you can do appart from blowing into the fan then that might help but not much else you can do about that sorry.
please rate my help to you.
thank you.
Apr 21, 2009 | E-Machines W3503 PC Desktop
Dell Precision 670 Workstation REALLY LOUD and NOISY
It could be due to a failture of either the SMPS fan (Power Supply), the system cooling fan or the Videocard fan... Now checking the power Supply fan issue is easy... Take a toothpick {wooden} n insert it between the fan fins at the back of your tower... This is the fan that is visible from the back of your tower... Now if the noise stops then it is the SMPS fan issue
If it still persists then do the same procedure with the CPU fan located on the inside of the tower.. this is a bit tricky but you seem tech saavy enough to do so but anyways this is the link for a step by step procedure of getting inside your desktop
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/index.htm
The third case is the Graphics Card... now there is no way we can say this with certainty but you can do this... remove all connections from the back of the tower.. remove the graphics card, connect just the power chord n start back up... if the noise is gone then the Video Card is the culprit.. REMEMBER TO REMOVE POWER CHORD ALL TIMES YOU OPEN THE TOWER N BE VERY VERY CAREFUL N FOLLOW THE MANUAL  :-)
Feb 12, 2009 | Dell Precision Workstation 670 PC Desktop
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
Philips iqon recovery cd
Its called, " iqonware iqon system recovery"...only available from iqon in dundalk (ireland)...if you go to there sales section you can see a picture of it, and you can click a button that says make a reservation for this product...and when you do you are then told a member of the sales team will contact you soon!
but there lies a problem....it appears the company went bust!
strange their website still operates really.
if youve formatted your entire hdd, you won't be able to use the F10 during boot up to recover your drive either...
only thing left ..purchase windows xp oem version (about (£65 i think).....
Mar 04, 2008 | Computers & Internet
Cooling fan
Yes. It can be replaced. Try to check which fan is making that sound. Do you have a laptop or a PC? On a PC, there are 3 standard fans inside it. one for the CPU, one for the power supply and one for the computer casing fan as well. It depends on which of those fans it's coming from. On a laptop, some laptops' fans actually makes a loud noise which is common but there is a way that it could be lessened but it might slow down your pc and it might overheat it as well. The loud noise on the fans of a laptop actually indicates that it's trying to cool down the system. If it doesn't stop the loud noise, it could indicate a problem switching the fans back to normal and would just continue to spin fast. Try to contact your PC tech for further diagnostics on the laptops fan to indicate if the problem is with the fan or the mainboard as well.
Jan 02, 2008 | Iomega 33089 250 GB Hard Drive
Computers & Internet Logo
647 people viewed this question
David Payne
David Payne
