Question about Recoton Advent Advent Q2035A 20" TV
Laptop advent k4000. power went off whilst in use.
Tested power supply. Ok
A number 1 and a letter a that looks like they are in a suitcase any ideas what they are
Posted on Jan 12, 2010
My laptop is saying its on wireless but it wont conect to it what can i do to fix this problem
Posted on May 14, 2009
My advent modena m202 will only work through mains power supply. I have a brand new batter which I was only able to charge in my old laptop. so m202 is not charging and wont work with fully charged
If the battery is OK then there may be an issue with the contacts that connect the battery to the motherboard or the regulator on the mother board has failed due to a previously faulty battery, in which a motherboard repair is required.
Jan 12, 2014 | Advent Computers & Internet
Advent K4000 CD/DVD Drive Wont load the disc...says no disc present
What are you doing with it? Trying to record a CD? I don't know why, but that happens sometimes when trying to burn a CD, no matter what you do. Try being sure the tray is shut good, open & close it again, and if that isn't it, then try a different disk. A few days ago, I had an expensive disk that just didn't get found in mine, & nothing helped but a different disk. Then no problem. Hope it's not your last 1. :) If those things don't help, come back and ask more, & tell us what you tried, please. More info= better answer. :)
Sep 18, 2010 | Acer TravelMate 4000 Notebook
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
I am having exactly the same problem
Its not recognising the power supply.Get the power supply checked in the laptop.
Jul 06, 2009 | Advent 4211c Notebook
Screen went black whilst using it
You could have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 13, 2009 | HP Computers & Internet
Advent k4000 laptop . power went off whilst in use
Your energy management software may be set to shut off or go in standby.
If so, go to display properties by right-clicking mouse and finding option and clicking on it in menu then screen savers then underneath that should be where your energy management software for your os is. Click on this and change to your liking.
Other possibilities, computer may be heating up(check for proper ventilation and that all fans are up), power supply port may be damaged(replace), or short may be present(get someone to check for loses and shorts that is a professional).
Feb 03, 2009 | Computers & Internet
Advent 7108 notebook
plug it in!? .. dead battery? .. shortage in wire? ... try holding the power button down FOR A REALLY LONG TIME! ...
those are my suggestions..
Jul 30, 2008 | Computers & Internet
Recoton Advent Advent Q2035A 20" TV Logo
246 people viewed this question
Top Recoton Advent Televison & Video Experts
S. Gontko
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
