Sub-Zero 561 / F
Problem for Sub-Zero 561 / F
Subzero model #561, freezer is warm, water leak
By kenmlai on Feb 03, 2009
I have a Subzero model #561, with two split doors. The motor is constantly running. The freezer is not cold, the ice-maker is not making ice even though it is on. The refrigerator is cold. 2 times a week, water leaks from back onto the floor. What has happened to this Subzero model #561? How should I fix it??
Same Problem
Feb 21, 2009
-   if there is frost over the sensor that tells the freezer that it is cold enough i had to turn off and defrost all ice with a hair dryer and turn it back on. -   Guest
Best Solution
posted on Aug 05, 2009
Very Helpful)
halftank123
Rank: Guru
Rating: 87%, 28 votes
Check to see if the freezer fan is running. Push in the two switches at the top. The light should go out and if the freezer is powered on the fan should come on. The icemaker runs on temperature so no cold means no ice. Check for ice build up around the evaporator. Could be a defrost issue or a sealed system problem. As for the water, is it the floor of the unit or the floor of the house? Is the drippan in place or sitting on the floor? Also check the condenser fan motor. If this is all greek to you, you should probably call a factory authorized servicer.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sub-Zero 561 / F
Questions and Unsolved Problems for Sub-Zero 561 / F
Do you recommend Sub-Zero 561 / F?
Answer
Answer
refrigerator is not cooling? freezer works perfect.
Answer
compressor is good but when its connected to the condenser relay it wont work
Answer
We need a new filter What should we do?
Answer
I can't figure out how to remove it; there are no obvious screws and a wood panel over it
Answer
took out the ice maker drawer and can't get it back in
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sub-Zero 561 / F:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
