Samsung SGH-e315 Logo
Posted on Feb 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant open .jar files in my samsung e250 mobile
When i load any games fro usb port that can never open
Anonymous
Level 2:
Sergeant:
  • Expert 270 Answers
  • Posted on Feb 03, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
270
Questions
0
Helped
81332
Points
619
Because that games are not supported by your phone.so load the games suitable for your phone
2answers
Installing java games to SAMSUNG E250
I finally succeeded in installing some java games to my Samsung E250 via bluetooth. I thought I would share the info on how I do it here because it seems to be a frequent unanswered question on various forums. You will need a *.jad and a *.jar file for your game. 1) Download Softick PPP and Samsung Java Uploader.exe . Also JADmaker if required. 2) Install SoftickPPP according to this Polish website. I don't understand Polish, but the pictures tell enough of the story. Set up your bluetooth COM ports in the SoftickPPP bluetooth/serial settings. My Bluetooth COM ports are either 24, 25 or 26. I leave them all ticked. 3) Enter *#52828378# on the phone to access the Java Test Menu. Choose OTA type setting, choose Serial bearer OTA. Click select. (This seems to need to be changed back to GPRS bearer OTA for Samsung PC Studio to connect) 4) Start SoftickPPP. Click on cancel for the missing USBPort.dll error message. Accept bluetooth connections for DUN and Serial connections on the phone. 5) Choose 'Activate PPP' by right clicking on the icon in the taskbar. Accept connections on phone again. 6) Start 'Uploader.exe' and then add the required jad file. Leave the program open. 7) If you are not still in the Java Test Menu then enter *#52828378# on the phone again. Select 'Serial test', 'PPP Up', 'Bluetooth' on phone, 'Serial download'. My phone sometimes restarts at this point in which case I have to choose 'Shutdown PPP" in the taskbar icon and then re-activating it once the phone has restarted and then re-do step 7 after entering the Java Test Menu again. A Java splash screen should appear with a progress bar showing the upload of the file. The game then starts automatically. There we go. It works for me Please man do you speak bosnian..
.Quote:
1) Type in the code *#9998*52824678255# (which reads *#9998*JAVAINSTALL# )
2) Your phone should return with 'Activated'
3) Now using Bluetooth or USB cable, connect to your phone (IR probably works too)
4) If you have a game as .jar, but don't have a .jad file, use JadMaker to create one (draw the .jar file to it and it will generate a .jad file for you).
5) Copy the .jar AND .jad file of the game into the map called "Other Documents" on your phone.
6) Now on your phone under 'My Files' browse to the 'Other Documents' map and doubleclick on the just copied .jad file.
7) The phone will ask you if you want to Install the game.
8) After Install you will find the game under Games on your phone.
9) You can now remove the just copied .jar and .jad file again (they were only there to install the game onto your phone).second answer:that i go to samsung company and when i ask them about jave install on samsung they say to me that the only way is to download from mobile internet games but it will be triall expet a game called 4*4 extreme race only and i tried to install any game it will be trial thanks for your reading (trusted)
3helpful
How i can install java games in samsung sgh e250 via card reader problem:
I got a beautiful answr on d net surfn 4 yr questn ...
.Quote:
1helpful
I can't open jar or jad files to my sgh e250.
jar files do not run on pc and in case of mobile it may be possible that file may be corrupted or the size of the file might be bigger than the max. size of file that ur mobile can run
so try downloading a smaller size game file and install it
Unable install games in samsung e250
for ur mobile u can get games from dotsis.com, nd getjar.com,waptrick.com these r the sites where u can get compatible games for ur mobile..surf from ur mobile....
you must download games with the phone's browser via wap .
1helpful
2answers
I also have a samsung e250 and i followed these instruction and it worked...
You must download two programs the SoftickPPP which you can download in this link: (if this link is not working try google you can find many sources)
http://users.skynet.be/yozy/tutorials/downloads/SoftickPPP234-en.exe
last is the uploader.exe
http://users.skynet.be/yozy/tutorials/downloads/Uploader.exe
Download the 2 programs and install the first program configure its setting on bluetooth/serial and choose the general serial port you are using for example: \device\mdm0 then press OK
Your fone must be connected to the pc via bluetooth or usb cable.
open uploader.exe and add the jad file of the game you want to install... then activate softick, which you can see in the taskbar right click the green icon and select activate softick.
type *#52828378# on your telefone
OTA type setting
then
Serial bearer OTA
then save
activate SoftickPPP which you can see in the taskbar right click the green icon and select activate softick.
type #*5737425# on telephone
then
PPP UP
then
choose usb port (if you are connected via usb cable) or bluetooth
then
Serial Download
(sometimes the fone restarts during this procedure, just inactivate your softick while the fone restarts and activate it again...
you can see java screen when the game is being uploaded...
if you still have questions email me at [email protected]
goodluck...
90helpful
13answers
How to install jar/ jad files samsung sgh e 250-
Sadly I think you need the usb cord for it and to type some code in(the phone) to activate java when it's plugged into your computer then send the files =( I've tried for a few days I don't know how long and have no idea what to do. Too bad all phone companies don't think to just use the smaller usb port thing for charging so i could just use my usb cord for my TI graphing calc or my mp3 player...oh well seems I'll have to keep searching.
Apr 03, 2008 • Cell Phones
16helpful
10answers
Application intaller on samsung E250
انا عايز ثيمات لتليفونى samsung e250
7helpful
9answers
Problems on games in samsung e250
To Install Java Games On Your Samsung-E250,You Have To Download "Softick" PPP and A "Java game Uploader"(search it on Google)..........
lnstall java games using usb data cable
SAMSUNG E250
Install\Run SoftickPPP221 from the Softick.PPP.v2.21 Folder. Ignore any errors about usbsync.dll by pressing OK.
Leave the option use usb in shared mode checked.
Run when finished installing. You will get an error message about being unable to locate usbport.dll, just click cancel.
Plug in your usb cable and turn phone on.
Right click on softickppp running in your taskbar and select settings.
In the usb tab uncheck accept ppp connection on usb and tick both use usb in exclusive mode and overide usb compatability,
Click on ok and completely exit softickppp by right clicking then exit.
Run softickppp and again goto settings. On the bluetooth\serial tab tick the correct com port.Mine is com3. Then click ok
On your phone key in *#52828378# press 2 ota type setting and select serial bearer ota.
Run samsung java uploader and add your jad file
On your phone select 3 serial test , 1 ppp up , 2 usb
Your phone will now reboot. While its rebooting right cklick on softickkppp in your taskbar and choose shutdown ppp
When your phone has rebooted again key in *#52828378#
Right click softickk ppp and activate ppp
On your phones java test menu press 3 serial test , 1 ppp up , 2 usb , 2 serial download
Your game should install and start running.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
