Question about Toshiba Satellite A60 Notebook
Toshiba A60 shuts down in 3 seconds
Start up the laptop then in about 3 sec's it shuts down again. i can hear the hdd starting and the cd drive . but keeps with a blank screen nothing on it and a few lights turn on for thouse sec's.
anyone got any ideas?
  • Roy Lonsinger
    Roy Lonsinger May 11, 2010
    Check your cpu fan. This auto shutdown could be caused by the cpu telling the system it is overheating.
    Problem Solver:
  • 5 Answers
Bios may be set wrong(fix by restoring default settings)
memory may be damaged(replace if true)
battery may be low and system shuts itself off(make sure battery is charged)
Drivers may be wrong(replace drivers in safe-mode)
Motherboard or other devices inside laptop may be loose and/or shorting.(Go to local computer fix-it shop or (open up laptop and check for loose connections which may void warranty.))
My guess is your bios needs resetting
Hope I am a help.
Posted on Feb 03, 2009
Check system then press f1 key
Try this:
Instructions
    • 1
      Insert the Toshiba A60 recovery disc into the CD/DVD-ROM drive.
    • 2
      Power off the Toshiba (with the recovery disc still loaded inside the optical drive).
    • 3 Hold down the "F12" key, at the same time hit the "Power" button to turn the system back on. You don't have to hold down the Power button, but keep holding the F12 key.
    • 4
      Release the "F12" key when the" In Touch with Tomorrow TOSHIBA" screen is displayed. This will open up the BIOS.
    • 5
      Change the boot order by using the arrow keys to select "CD/DVD ROM" icon in the menu. The Toshiba will now boot from the recovery disc and restore the system. Follow any additional on-screen instructions.
Aug 19, 2012 | Toshiba Satellite A60-S166 Notebook
Starts up then shuts down within 3-5 seconds
is this happening everytime you start the machine? What is being displayed on the screen? Do you hear the fans running when you press the power button? Do you hear the disc drive running? Do you hear the cd drive click once and the light on the cd drive door come on for a second or two? Is it posting anything on the screen during the boot process? Is it getting to the actual windows desktop which is where you see your icons? Computers shut down for a reason. Either some piece of hardware is not working such as a fan, or some hardware is faulty (such as the memory, cpu or motherboard), or some software issue or a virus has taken over.
Mar 19, 2012 | eMachines Computers & Internet
How did i boot my toshiba satlilit pro
Here is a solution for your problem.Please follow the below steps to boot your laptop.
1. First of all insert the CD from which you want to boot your laptop. 2. Shut down your system. 3. Press the power and then start it again and press the "C" key to boot from the CD.
If this method doesn't work, you can try pressing F2 or F12 at startup and selecting the CD drive from the list of options.
If neither method works, hold the "Esc" key while restarting the computer and press F1 when prompted to access the BIOS. From there, you can change the boot order so that the computer attempts to boot from the CD before any other devices.
This will surely help you out.
Thanks you. Have a good day.
Aug 10, 2011 | Toshiba Satellite A60 Notebook
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
Satelite a60 shuts down after 3 seconds
SEND ME LAPTOP TOSHIBA PSA60L OC9003 VGA DRIVER
May 31, 2009 | Toshiba Satellite A60 Notebook
Answer to your question
You will need to get into the bios, and set the CD drive to boot before the hard drive. Since your in this uncompromising loop, remove the hard drive, then start the machine. It should go to the initial Toshiba screen and you will see the prompt on what to press to get to the bios, or utility set up. Once your in the bios, find the boot order and set the CD drive over the hdd. Then put the hdd back in, the recovery or operating system disc in the CD drive, and start the machine. It should now boot from the disc. At this point you will want to do a system repair. If the repair doesn't take, then reformat the hdd, and install a new operating system. If the hdd will not format or you have any issues during or after the install, then the hdd has failed and will need replaced. If you need any futher aststance, just ask.
Aug 28, 2008 | Toshiba Tecra M1 PC Laptops
Toshiba Satellite A60 powers up then off after 2 seconds
Mark F K, truong808, does the cooling fan(s) blow or come on? If not, the system will sense tha ti is overheating and will shut down to prevent further damage. Also, a thermal sensor may be failing on the Mobo and thus keep the fan from initiating. The cheapest fix is to replace the fan. Worst case scenario is another Mobo may be the fix.
Jan 06, 2008 | Toshiba Satellite A65-S126 Notebook
Toshiba satellite A60 no boot
We can only assume that because the cd drive operates then the motherboard is operating in part, although, the southbridge chip may be damaged, as the northbridge works memory etc. Maybe it is that the processor is fried as there is no fan and the system then shuts down. Toshiba are probably half way there with the answer, unless; they investigated further and decided it was not the processor but the motherboard.
Jan 02, 2007 | Toshiba Satellite A60 Notebook
Toshiba Satellite A60 wont post
It may be possible to startup in safe mode(press F8 on boot up) and highlight 'Last Known Good Configuration' or highlight 'Start Windows in Safe Mode. If this gets you up try a system restore to before you updated driver or look for the system recovery folder, normally on another partition of your hard drive, that is if you didn't get a recovery cd. If you are not able to get up and running you will need your Windows Installation Disc to either repair the system or do a complete re installation by putting in cd whilst you boot up. It may also be that your HDD is damaged and thats why you can hear the cd drive powering up, looking for a system disc, as it cannot find Windows.
Nov 07, 2006 | Toshiba Satellite A60 Notebook
Toshiba Satellite A60 Notebook Logo
208 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
