Question about IBM (25P3294) Motherboard
Restart of computer
My computer restart quickly after bootup.
  • 36 Answers
Try changing your memory, or try replacing them to see if they are defective. If this does not work. try replacing your powersupply..
Posted on Feb 03, 2009
After bootup, my Acer Ferrari 1000 display bottom half blurrs and then computer locks up.
That is good information, especially when you consider the endless possibilities.
Aug 11, 2012 | Acer Ferrari 1000-5123 Laptop
Restore to factory specs.
Hello hihretard,
These instructions to "restore your computer" back to the Factory Settings.
Once the Computer "Bootup;" quickly press, tap the [DEL] key, located at the top [Right] next to the Scroll Lock, and END keys"
*Note: you may have to "Press the [F8] key"
  • The next window will be the "Recovery Environment."
*Note: The wording may differ depending on the type & model computer.
  • "Options:" Select the option, "Repair the Computer."
  • In the next, [Systems Recovery] windows, you will have to "Enter" (Location, Password...)
  • Next, choose the box that best describes, the Recovery Wizard:
  • This will have a notice! Restores System back to Factory Settings, or Out of Box!
Note: There will be all types of "Warnings!" Read carefully, before continuing.
!Attention: "Once the Recovery begins, Do Not Touch the computer, for any reason at all!"
!Warning: The whole recovery can take up to (4 Hours), the computer will "Shutdown & Restart several times; several!
  • So until you see the LOGIN" screen, Do Not Touch the Computer.
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Oct 09, 2011 | Toshiba Satellite M105-S1021 Notebook
I have a Toshiba T6400- and when I boot up and try to go to programs or open files it freezes
On bootup your computer is trying to start an application that is probably causing this problem.
Click Start. type msconfig hit enter.
Click the start-up tab. That tab will list all programs that run on bootup of your computer.
You can untick programs that you do not require on startup. Click OK and restart your PC.
Aug 29, 2011 | Computers & Internet
System in safemode, restart windows normally doesn't cancel safemode neither does earlier configaration Help
  • Hello info88784, "I've read your situation, and I suggest that you can do the following. "Restart the computer, once you see the "Prompt Screen" to Press F2 or Press F12, quickly "Tap! the [DEL]key, located at the top [Right]next to the Scroll Lock, and END keys." You will know if you done it correctly, when you see the {Windows Boot Manager} Heading on the screen; at the bottom of the screen, it will read "Recovery Environment." Note: The wording may differ depending on the type & model computer you have. Now, there will be a long list of "Options" to choose from, select the option that best describes; Try each to fix the problem: Startup Repair, "Repair My Computer, and System Restore; or next time, "Press the [F8] button the next time you "Bootup" and choose the more {Advanced Options} select whatt best decribes; " In the [Systems Recovery] windows, "Configure Last Known Good Boot!" Follow all the instructions, and I hope all goes well. "I would appreciate if you could find the time to give a "Helpful Rating, its my only reward," knowing I could be of assistance! Thanks alot, paul7of9
Dec 10, 2010 | Toshiba Equium 100 PC Desktop
Disk error msg on bootup
Remove all the external peripharials from the system and restart it......it will work!
Jul 29, 2010 | ASUS Eee PC 1000H Laptop
Computer freezes after bios screen on every restart.
One thing you could check is what order your computer is booting from. CD drive hard drive then other. Should be hard drive first. Go into the bios to do that. If you hold the power button down for 5 to 10 seconds the machine should physically shut down rather than unplugg. The unplug thing sounds like its in the power settings. But I've never heard of power settings being connected to bootup except for a password. Anyway a wild guess is check the bios bootup order.
Dec 31, 2009 | Toshiba Satellite® A215-S4807 PC Notebook
Windows file is corrupted and can not boot up computer
Hardrive is most likely faulty or your memory sticks are bad or not completely inserted. If you are able to turn on pc, press f2 or f8 as soon as it boots, then insert bios mode, change bootup settings for CD-ROM as first bootup device, then Hard Disc as second bootup device, then insert your windows installation disc or recovery cd, insert it, restart pc and run the disc to install windows.
Oct 06, 2009 | Dell Celeron, 300 MHz (2997D) Processor...
Unable to get pas message at bootup
I am sorry to say but seems like your system perhaps the Windows system files got corrupted. Boot your computer up to the Windows CD and run a repair. If this does not do it, you will have to reinstall Windows again.
Apr 09, 2009 | Everex StepNote NC1500 Notebook
Acer laptop bootup problems
Please try and bootup your computer in safe mode by pressing the F8 Button just before windows starts to load. a menu appears and you just need to select the safe mode option and see how it goes from there.
Let me know if this helps.
Oct 27, 2008 | Acer Ferrari 4000 Notebook
How to hide or eliminate boot selection on Acer Veriton s460...there wasn't any security selection in the computer BIOS?? thanks
Login to window,,
Go to start --> Run --> type there msconfig
this will open a window, now inthat go to Boot Tab
And check if the two option given, if you have multiboot operating system (Viz Win 2000 and other one Win Xp)
Then it will show you each time during bootup (you can only setup one as default)
You also can setup the time for it to take in bootup.
Let me know if you need further help
Ellin
Oct 15, 2008 | Acer Computers & Internet
IBM (25P3294) Motherboard Logo
27 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
