Question about HP Photosmart C6180 All-In-One InkJet Printer
Black ink failure
I don't get any error messages, the printer recognises the ink levels and seems to think all is fine. However, no ink is released from the black cartridge. this happened over time, starting with faint white bands, now there is nothing. I've contacted the help line and done everything they suggest - diagnostic tests, resiting cartridges, resetting printer, uninstalling and reinstalling software but no change. on a diagnostic test the black prints as very pale green
the printer is only 2 years old and hasn't had loads of wear. Do I really have to throw it away ?
  • Dianne Drew
    Dianne Drew Feb 04, 2009
    have tried a new cartridge - printer recognises it is full but still no black printy. thanks for trying
    Genius:
  • 2,120 Answers
The ink is dried up in the cartridge.
Posted on Feb 04, 2009
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
Why does my printer not recognise ink cartridges
there is a reset for that that comes with some carts or you can just order the reset mabye
Jul 25, 2014 | Cannon Office Equipment & Supplies
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
I have the ink system failure error and error Oxct18a0206 I was going to try and fix it and it somewhere it said that it could be because the ink cartridges are low. How do you see what level they are at...
Yes, The error is caused by air in the ink feed tubes which happens when the ink in the cartridges runs out or you use an improperly filled cartridge. We have a step by step repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
There is not any easy way to determine the level of ink in the cartridges but you will need to use full cartridges when you do the air purge procedure needed to clear the error.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Will not print, has error message 0xc18a0406. ink system failure
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it.
Press and hold the “*” key. Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Jan 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
Dell 942 AIO printer won't recognise black cartridge:
I think you purchased a black cartridge with bad electronics. Basically your cartridge can't communicate with your printer and you should exchange it for a new one. There is no way to "fool" your printer into accepting refills with bad electronics. What you can do is when you get the message that you aren't using genuine cartridges and it won't be able to estimate ink levels is to check the box indicating to ignore the ink levels.
Nov 13, 2009 | Dell 942 All-In-One InkJet Printer
Error: OXc18a0201
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Sep 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
Can print...ink system failure - followed process but it wont wor
release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit
Aug 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Canon MP145 printer can not recognise replaced Black cartridge
When you got Error 4 on your printer canon MP145 It’s means one of your cartridge color/black has detected no ink. It happened maybe the printer MP145 is not used for long time. Don’t thinking your Cartridge is damaged. We can not do resetting procedure MP145 to resolve this I have tried it and failed.
When it happened to me I don’ want to go to the service center. We can guest what they say about that “your printer cartridge need to be changed” don’t believe. I go to Search Engine, browse and browse again finally today I found the guide for resolving the canon MP145 Error 4.
how to resolving error 4 on printer canon MP145 Press Reset/Stop Button about 5 second or more until the error 4 disapper. It worked! Save your money for newcartridges.
Jan 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
ERROR U130
The remaining ink level cannot be correctly detected. Replace the ink tank and close the Scanning Unit (Printer Cover). Printing with an ink tank that was once empty may damage the machine. If you want to continue printing in this condition, you need to release the function for detecting the remaining ink level. Press and hold the Stop/Reset button for at least 5 seconds, and then release it. * With this operation, releasing the function for detecting the remaining ink level is memorized. Please be advised that Canon shall not be liable for any machine malfunction or damage caused by refilled ink tanks. See “Replacing an Ink Tank” on page 46.
Apr 10, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
99 people viewed this question
Ben Johnson
