Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
My tv shut off now it wont turn on on the lamp light is flashing
It just shut off when i was watching it .it made a poping sound then shut off. its a 50 inch sont grand wega its a couple years old
  • 3 more comments
  • dlb22jef Feb 11, 2009
    i read one of the solutions re: counting # of blinks=code....our tv blinked 55 times.
  • nick2124 Mar 06, 2009
    it flashes 3 red lights
  • hillboy700 Mar 07, 2009
    I have it flashing 101 times
  • traceyre76 Mar 10, 2009
    The Tv just shut off after making a very loud popping noise. When I tried to turn back on it made a weird screeching sound and the green light at the bottom was blinking...help!!
  • hotboipresto Mar 20, 2009
    my light blinks 57 times
  • 4,234 Answers
A little more info is required bfore we can help much. If you attempt to turn on the set, the standby light should blink a repeated code. If you can post that count here, we can use that to tell you what circuit has the problem. If that light does not come on at all, that too is good info.
Thanks,
Dan
Posted on Feb 03, 2009
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
I have Sony Wega and the picture just cut out and went to black. The sound wont come on and the TV wont even turn on. The light at the bottom of the TV flashes lamp light. We took the lamp light out and...
if u take out the lamp the green light will flash ,its not detecting a lamp at all.a bad lamp is being detected before you took it out.u will have to replace the lamp before u get a picture again
Sep 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I was watching tv and there was a poping noise and now when i turn the tv on i get a whining sound
Please check Lamp light on tv front, if its On, replace lamp as pop sound was broken lamp.
Lamp replacement procedure would be written in user manual.
Let me know if you have additional question.
Thanks.
Apr 15, 2010 | Sony KDF-50E2000 50" HDTV
Samsung HLP6163W wont turn on
I went to sleep my tv was play i woke up and don't work so i turn it on popping crack sound and it shut down what do nowno tv
Sep 13, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Weird Rapid Metallic Popping Sound
I think i have the same problem, but i can get audio still. did the poping plinking sound come from the inside back panel of your TV? it sounded almost like a arc wielding noise?
Sep 29, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
My 60" lcd projection tv wont turn on sometimes and throws a lamp light, and if i watch tv for a while and turn it off it wont turn back on and throws the red lamp light
The buzzing sound you most likely hear is the ballast trying to fire up the lamp. I would say replace the lamp and yes they can act up at will. If this is the first lamp replacement ever then you are doing good.
Feb 01, 2007 | Hitachi 60V500 60" Rear Projection...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
229 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
