Question about Audiovox Rampage 1200 Watt Amplifier Car Audio Amplifier
Audiovox modulator i have an 6 disc rampage audiovox modulator that has 3 wires one black,green,orange i just trying to know what wires go to the power,ground,remote
    Scholar:
  • 125 Answers
Http://audio.manualsonline.com/manuals/mfg/audiovox/audiovox_stereo_amplifier_product_list.html
enter in product model number and info
Posted on Feb 04, 2009
2 Suggested Answers
godspeed808
  • 125 Answers
SOURCE: 6 disc rampage audiovox modulator
You can go to this address and obtain wiring and product info:
http://audio.manualsonline.com/manuals/mfg/audiovox/audiovox_stereo_amplifier_product_list.html
enter in product info model number etc.
Looking for the speaker colors for a 2001 Jeep Grand Cherokee
Item Wire Color Polarity Wire Location
12V red & pink/black + ignition harness
STARTER yellow + ignition harness
IGNITION dk. blue + ignition harness
ACCESSORY red/black + ignition harness
SECOND ACCESSORY none
TACHOMETER *6 *6
POWER LOCK orn/blk - orn/pur *7 5wi door lock switches *1
POWER UNLOCK pnk/blk - pnk/pur *7 5wi door lock switches *1
PARKING LIGHTS + use (-) lights
PARKING LIGHTS - dk. blue/pink *2 steering column
DOOR TRIGGER *4 - *4
HEADLIGHTS yellow *3 at the headlight switch
WIPERS dk. green/red - steering column
LF WINDOW UP/DN lt. blue - white A drivers door lock switch
RF WINDOW UP/DN brown - purple A passengers door lock switch
LR WINDOW UP/DN dk. blue - red/wht B drivers kick panel
RR WINDOW UP/DN gray - dk. green B passengers kick panel
TRUNK/HATCH PIN tan/black - BCM, above diagnostic plug
HOOD PIN none
TRUNK/HATCH RELEASE none
FACTORY ALARM ARM arms with lock *7
FACTORY ALARM DISARM lt. green/orange *7 - *5
HORN TRIGGER gray/orange - steering column
BRAKE WIRE white/tan + drivers kick panel
LOCK MOTOR orange/black drivers door lock switch
UNLOCK MOTOR pink/black drivers door lock switch
DISARM DEFEAT pink/purple passenger kick panel
DISARM NO UNLOCK none
DOME SUPERVISION yellow/dk. green *7 - BCM, above diagnostic plug
SPEED SENSE white/orange PCM, passenger side firewall
SUN ROOF OPEN/CLOSE none
SUN ROOF LIMIT none
LF SPEAKER grn/orn - brn/red at the radio
RF SPEAKER purple - blu/pnk at the radio
LR SPEAKER wht/grn - grn/wht at the radio
RR SPEAKER grn/wht - blu/orn at the radio
RADIO 12V red/white at the radio
RADIO GROUND black at the radio
RADIO SWITCH white/red at the radio
RADIO ILLUMINATE none
POWER ANTENNA none
Notes: NOTE: Jeep vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U. *1 Use orange/black and pink/black at the drivers door lock switch to lock and unlock the drivers door. Use orange/purple and pink/purple at the passengers door lock switch to lock and unlock all of the other doors. *2 The dk. blue/pink will flash the hazard lights. They will flash even with a latch input to the wire. The parking lights can be activated by using a 1300 ohm resistor to ground on the yellow headlight wire. *3 Use a 330 ohm resistor to ground for headlight activation. Use 80 ohms to ground on the same wire to operate both the headlights and parking lights. *4 There are 4 separate door triggers wire, one for each door. Use all 4 wires and diode isolate each together. The drivers door is tan/red at the drivers door lock switch. The passenger door is tan/red at the passengers door lock switch. The drivers rear door is tan/orange and the passengers rear door is tan/yellow at the BCM. WHEN USING A 455J INTERFACE MODULE, IT IS NOT NECESSARY TO USE THE SEPARATE TRIGGER WIRES. USE THE YELLOW WIRE AT THE UNDERDASH LIGHT FOR DOOR TRIGGER. *5 Factory alarm disarm requires a 463 ohm resistor to ground on the lt.green/orange wire at the drivers door lock switch, you MUST use a relay. *6 The 4.7L motor has a separate coil for each cylinder. Go to any coil and use any wire that is NOT dk. green/orange. On the 4.0L motor use any of the tan/stripe wires at the coil pack, or go to one of the fuel injector and use the wire that is NOT dk. green/orange. *7 Can also use DEI part number 455J door lock interface control module. This will control door lock, unlock, arm, disarm, dome light supervision and more.
Sep 26, 2011 | Car Audio & Video
Cd changer connections
Hi, On your Audiovox ACC56 10-Disc CD Changer with a Prestige P-165/P-185 FM Modulator, the wires: black - goes to the body (-) ground (as you correctly posted); Green/white - (with a small filter box) goes to the constant/always on 12V supply such as the + terminal of your battery Orange/White - should be connected to a switched power source such as the accessory terminal of your ignition switch or to the blue or yellow wire of your head unit or car stereo or whatever wire that will have 12V+ only when the head unit or car stereo is switched on. Hope this be of some help to you. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 21, 2007 | Audiovox ACC56 10-Disc CD Changer
Need the output wiring diagram for a AUDIOVOX 93-im-ETX radio
Wiring diagram for Audiovox 93-IM-ETX
Figured it out by taking radio lid off and following the leads:
Black/white--ground (-)
Green/white--battery (+, that is, always on)
Orange/white--ignition/ACC switched power
White--left front +
Red--Left rear +
Blue--right front +
Yellow--right rear +
Light Green--negative for front speakers
Purple-negative for rear speakers
Sep 28, 2010 | Audiovox Car Audio & Video
I need to know where the wires comming out of the plug go to?? wiring diagram. thank you sony cdx-3100
This is the pinout shown on the Sony website for the CDX series players. Pin numbering is as follows:
1 2 3 4 5 6 7 8
9 10 11 12 13 14 15 16
This is looking at the connector with the wires towards you.
Pin Number Wire Color Description
1 White Left front +
2 Green Left rear +
3 Purple Right rear +
4 Gray Right front +
5 Blue/white AMP Remote
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
9 White/black Left front -
10 Green/black Left rear -
11 Purple/black Right rear -
12 Bray/black Right front -
13 Sky blue ATT
14
15 Orange/white Illumination
16 Yellow Battery
Jan 05, 2010 | Sony CDX-3100 CD Changer
Trying to reinstall this in a car and need the wiring diagram
1) Black Ground
2) Red 12V Ignition
3) Yellow 12V Constant
4) Orange Illumination
(Sometimes there's an extra orange for cell phone mute)
5) Blue Remote
6) Blue/White Power Antenna
7) White Front Left
8) White/Blk Front Left
9) Gray Rear Left
10) Gray/Blk Rear Left
11) Green Front Right
12) Green/Blk Front Right
13) Purple Rear Right
13) Purple/Blk Rear Right
Jul 08, 2009 | Pioneer KEH-P2800 Cassette Player
Feb 03, 2009 | Audiovox Rampage 1200 Watt Amplifier Car...
Hi i have an rampage audiovox acc-40 and on the modulator it has 3 wires one green, black and orange i wanted to know what one is the power, ground, remote
just enter in product number and info
I need a wiring legend for the Rampage BA200 sub woofer
Red - power
Black - ground
Blue - turn-on (switched 12 volt)
Green and Gray -- Hook to factory/aftermarket stereo for the signal.
Jan 14, 2009 | Car Audio & Video
What cables are what
black is ground red is power with key on yellow is power all the time blue white is amp remote wire you dont use this if you dont have amp.
Sep 23, 2008 | Kenwood KDC-3024 CD Player
Motorola spectra
Those should be for the speaker.
Jan 19, 2008 | Radio Communications
Audiovox Rampage 1200 Watt Amplifier Car Audio Amplifier Logo
121 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
