I installed the software for NIC USB modem, its the application interface software ...the problem is when i try to open it , it doesn't and it indicates error........ Please reply anyone to me......
  • Kim Tyler May 11, 2010
    you might have the wrong driver
    what is the make/model of your USB modem, and what OS are you using??
  • 1,602 Answers
NEED TO GOING CONTROL PANEL OPEN THE FOLLOWING FOLDER FOR ASSISTANCE:
DEVICE MANAGE, PROPERTOES OF THE SOUND ,NETWORKING AND SHARING,PROBLEMS REPORT,SYSTEM.
OPEN EACH ONE BY THEMSELF AND LOOKING THREW THE ITEMS THAT YOU ARE HAVING THE PROBLEM
IF YOU DONT FIND ANYTHING JUST GO TOTHE POWER SWITCH AND TURN IT OFF AND THAN TURN IT BACK ON AND WINDOW WILL OPEN INTO SAFE MODE OPTIONS, SELECT THE OPTION MOST SUITED TOYOU PROBLEM AND HIGHLIGHT IT AND ENTER KEY AND FOLLOW THE INSTRUCTION ON THE SCREEN,
YOU MOUSE MAY NOT WORK IN SAFEMODE TAB KEY TO MOVE AROUND, THE TAB KEY WILL HIGHLIGHT THE BOX YOU ARE ON OR BLINK ALSO.
ROD
Posted on Feb 03, 2009
My xp wont reconise wireless networks in range any more
Well It could be a problem with the hardware or softwarefor software query , go to run > type Msinfo32 and click ok> check for the NIC ( Network Interface card ) Installed in your computeror laptop ... go to google.com and download the latest version for the relevant NIC and install it ... before installing it right click on my computer and click on properties or Press pause break button on your keyboard with the help of windows button > then do to device manager .... amongst the list of hardware click on network adopter and expand it > right click on the content and click uninstall > close all windows then install the latest updated driver
to verify thet the nic is working properly go to run and type > PING 127.0.0.1 and press ok if the ping command works your Nic is work properly if problem doesn't goes off
in computer :- buy another Nic and install it in PCI slot and install the supporting driver that comes with the new nic... if you have no idea of hardware then buy a external usb wireless NIC ... ( its plug and play ready and is compatible with win xp sp2 install it and try it .... it will definitely resolve your problem
for more queries revert back to me at any point of time
spd.sam@gmail.com
Apr 15, 2012 | Microsoft Windows XP Home Edition English...
I have a hp pavilion a1140n and i cant set up wireless internet in my house what do i do
To have wireless internet you would need a (cable or DSL modem depending upon your ISP. A wireless router (doesn't matter which brand) Also for a desktop computer you will need to buy and install a wireless NIC (network interface card) as desktops almost never come with one, only a hardwired NIC (cabled)
Dec 16, 2011 | HP Pavilion a1140n (PX774AA) PC Desktop
How do I turnon the USB on the westell 6100 modum?
f you reformatted your Windows on your pc, there's no need to change the settings of your network connections. The Westell 6100 can either be connected to your pc using the Ethernet port or the USB port if you're using the combo cable or Y-cable. It's more stable to use the Ethernet port for your Lan connection. For the USB, to reinstall the USB connection properly, you'll need the Verizon Installation CD. Make sure the USB is not connected to your PC first before you install it. You just need to follow the CD because it will tell you when to hook up the USB cable to the pc. If you still have the CD, after it runs, you have to select existing customer and then select connect new modem. After that you just to have follow the steps to install the USB connection properly and then your modem will work fine afterwards. If the problem still persists, you can try replacing the cable. If all else fails, it could be a modem problem already. You also need to check your Network Interface Card of NIC as we call it, it's built in your pc. it's the device that allows your pc to communicate with the modem. Normally after reinstalling windows, the NIC is forgotten, make sure you also install the drivers and utilities Cd for your windows.
Sep 06, 2011 | Westell Wirespeed ProLine 6100 Router...
I can not connect my star to my pc using the usb cable. 'usb modem 1.0 driver cannot be detected' is what i get
have you installed Samsung PC Studio software first on your computer?, without installing this software the computer would not recognize the handset if you are trying to use your handset as USB Modem
Nov 18, 2009 | Samsung Star GT-S5233 Cell Phone
Installing NIC card to dell optiplex gx100
NICs usually come in PCI interfaces. motherboards have usually four PCI slots to hold many devices such as NIC. just slide the card and fit it into the PCI slot. It could take any of the slots where it fits. the OS will detect it and loads the necessary drivers.
Aug 28, 2009 | Dell Ethernet Card Network Adapter
Resuming verizon dsl usb internet connection
If you reformatted your Windows on your pc, there's no need to change the settings of your network connections. The Westell 6100 can either be connected to your pc using the Ethernet port or the USB port if you're using the combo cable or Y-cable. It's more stable to use the Ethernet port for your Lan connection. For the USB, to reinstall the USB connection properly, you'll need the Verizon Installation CD. Make sure the USB is not connected to your PC first before you install it. You just need to follow the CD because it will tell you when to hook up the USB cable to the pc. If you still have the CD, after it runs, you have to select existing customer and then select connect new modem. After that you just to have follow the steps to install the USB connection properly and then your modem will work fine afterwards. If the problem still persists, you can try replacing the cable. If all else fails, it could be a modem problem already. You also need to check your Network Interface Card of NIC as we call it, it's built in your pc. it's the device that allows your pc to communicate with the modem. Normally after reinstalling windows, the NIC is forgotten, make sure you also install the drivers and utilities Cd for your windows.
May 18, 2009 | Westell Wirespeed ProLine 6100 Router...
I have a dlink router and I want to connect my usb modem to it
is this an additional router?
Verizon are issuing modem with built in wired and wireless modem.
Try this;
How do I properly set up a D-Link Router with a Westell Modem? (#7125)
This FAQ is for setting up a BellSouth supplied Westell 2100/2200/6100 modem (Models A90-210030-04, B90-220030-04 and B90-610030-06/C90-610030-06, respectively) with a D-Link DSL router. Although actual screen shots vary throughout the DLink line, the instructions below are applicable to all models. Important Note: These procedures and pictures are based on the most recent firmware for the Westell. Other Westell firmware menus and screenshots are slightly different but the bridge options and functions are still available. It is highly recommended that you click here and update your Westell firmware.
This FAQ has 3 Major sections:
Section 1 - Overview
Section 2 - Westell modem configuration
Section 3 - D-Link router configuration information
Section 4 - Connections and power up
bred.gifImportant Note: Due to some known operational issues it is VERY important that you have the latest firmware on your D-Link router. Please go to the D-Link Support Site for firmware updates.
bred.gif The best configuration for networking a router with the Westell is to set the Westell to "Bridged Ethernet" mode and allow the router to do the routing and DHCP functions. The Westell is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
bred.gif Before proceeding both the modem and router should be set to default. Despite what the help desk tech tells you, resetting the Westell does not put it into Bridged Mode.
bred.gif The BellSouth Installation CD and Connection Manager are not required to use this configuration.
bred.gif Since BellSouth assigns static WAN IPs via your username the configurations shown are applicable to both dynamic and single static IP customers. Select dynamic PPPoE regardless of your setup.
bred.gif You must connect the Westell directly to the computer's NIC to make the necessary changes before you connect the router, because you will be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where your Westell is connected). Additionally, they may be on completely different subnets. After you have made the changes to the Westell you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the Westell's PPPoE and DHCP functions. Click here for more information.
bred.gif If you encounter any problems simply reset the Westell, connect it directly to your NIC, restart your computer, log into the Westell interface, and start over again.
bred.gif More information about the Westell is available here.
Section 2 - Westell Configuration
bred.gifStep 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Completely power down the Westell and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the Westell to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter 192.168.1.254 in the URL address field to access the Westell interface. If you are unable to access the interface make sure your NIC is set to "Obtain an IP address automatically". This may require you to reboot the computer (or release/renew) to obtain a proper IP.
bred.gifStep 3
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the Westell.
Section 3 - D-Link Router Information
bred.gifStep 4
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the router and then the computer.
bred.gifStep 5
Use the following steps to configure your D-Link DI-604 Router. Important Note: You must use the username@bellsouth.net format for your username. If you do not add "@bellsouth.net" after your username you will be unable to connect to the internet.
Section 4 - Connections and Power Up
bred.gifStep 6
Power everything down and physically connect the Westell, the router, and any computer(s).
Westell 2100 shown. Pictures by Andy Houtz
bred.gifStep 7
Power up the network equipment in this order:
•Westell Modem (wait till the Ready light is a steady green)
•D-Link Router
•Computer(s)
Open a browser session and go surfing!
bred.gifAdditional Imformation
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network. For more information about changing MTU on a D-Link please click here.
•The 6100 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the DLink to establish the PPPoE session the light will stay off. This is normal.
Mar 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I want to install ec 325 nic usb modem on xp 64
If its USB , Xp should sort itself out and use the default usb drivers when you plug it in
If not , go to device manager - can you see the NIC modem in there?
If you can but theres a yellow ! next to it , right click it , select update driver and go through the steps to search for and install the driver software
i also found these driver links on another website:
http://www.reliancecommunications.co.in/Communications/rcom/Netconnect/RCZip/Huawei_EC325.zip
http://www.reliancecommunications.co.in/Communications/rcom/Netconnect/RCZip/Huawei-EC325.zip
Jan 02, 2009 | Computers & Internet
My modem with dial up but not high speed
You might need a new NIC card, thats high speed capable. What kind of hi speed are you trying to use ex.DSL,FiOS,Cable?
May 16, 2008 | Computers & Internet
Speedstream 5100
FOR AOL Instructions see the first question in
http://www.smallbusinesscomputing.com/we...
As far as configuring the router try
http://www.dslreports.com/faq/efficient/7_Misc._Questions
or
www.waymark.net/tech_support/DSL/SBC/5260.pdf
or
http://whirlpool.net.au/index.cfm?a=h_view&model_id=112
FROM THE SECOND LINK --
Installation Requirements
To install the 5260 ADSL LAN modem, you will need the following:
• A computer equipped with an Ethernet network interface card (NIC) or
an Ethernet hub
• A DSL-ready telephone line installed at the desired installation site
Package Contents
Your package should contain the items listed below. If anything is missing
or damaged, please contact the dealer from whom the equipment was
purchased.
• 5260 LAN modem unit
• Power supply
• One RJ11 unshielded twisted pair (UTP) cable (for the DSL connection)
• One RJ45 UTP straight-through cable (for direct connection to a PC
with a NIC installed)
• Installation Guide, Safety and Certification booklet, and Release Notes
(if applicable).
Nov 29, 2007 | Efficient Networks SpeedStream 5260...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
