Question about Motorola Mobility H700 Wireless Headset
Motorola H700 will not pair with LG VX8500
Purple light not steady. I enter the verification code and will not pair.
    Problem Solver:
  • 5 Answers
Close boom press call button till light turns purple then instantly open boom, ta da, you just forced it into pairing mode! The purple light will be steady untill you finish pairing the two devices.
Posted on Feb 08, 2009
I need to know the bluetooth pairing code for sanyo M1
Well I know for sure the default pin for the M1 is indeed 0000. However I cannot tell you what the pin would be for your specific bluetooth dongle. If I where you I would try 0000, 1111, 2222 and so on
  • As with all Bluetooth headsets, the H700 needs to be paired with the device before it can be used, which is done in pairing mode. In pairing mode, the H700 makes a transmission so that Bluetooth-enabled devices can pick up the device and connect to the headset. Once connected, no other device can connect with the Bluetooth headset. To enter pairing mode on the H700, open the headset boom located near the microphone. After a few seconds the indicator light will turn purple. Once purple, the H700 is in pairing mode.
Searching for the Device With the M1
  • Once the H700 is in pairing mode, have the M1 search for Bluetooth devices. To do this, press "MENU/OK" and choose "Tools," "Bluetooth," "Add New" and "Search." A list of Bluetooth devices will show up on the screen. Highlight "Motorola H700" and press "MENU/OK." Choose "Add to Trusted," enter "0000" and press "MENU/OK." The devices are now connected and ready to be tested.
Testing the Devices
  • Once the devices are connected, test that both the phone and the headset are working properly together. First, place the headset in your ear. Dial a number on the phone and press "Send." If you can hear ringing, the devices are connected properly and ready for use.
    If the connection was not successful, repeat the previous steps and try again. Make sure the indicator light is glowing purple and is steady. If you have connected the headset to a previous device, make sure that device is turned off so as not to interfere with the connection procedure. Once the other device is off, close and reopen the boom to enter pairing mode.
Feb 16, 2012 | Sanyo Cell Phones
My h700 bluetooth will not go into pairing mode
hi sammieyoungj. i'm sorry to hear about your troubles with your headset. Maybe this will help your situation. Ensure the headset is fully charged. Then turn on the bluetooth feature (discoverable mode/set to look for bluetooth devices) on the phone you are planning to pair it with. Next, turn off the headset by closing the microphone boom. After about 8 to 10 seconds or you know the headset is off, press and hold the call button for about 4 to 5 seconds. The headset should activate and show a steady purplish colored light. When the light turns purple, unfold the microphone boom. If the lights stay a steady purple color, then the headset should be in pairing mode and you can revert to your phone to pair them together.
If the light does not stay steady, or turns a blue color, repeat the steps above, making sure no bluetooth devices are around that it may have paired with previously. Hope that helps. Best of luck.
Mar 05, 2011 | Motorola Mobility H700 Wireless Headset
Motorola H700 won't pair with LG CU720 phone
You will need to enter pairing mode on your device. The H700 User Manual indicates that you do so by first turning off any previously paired device and opening the headset BOOM. The indicator light should light a steady purple while in pairing mode.
You may not need to turn off your phone if you do not desire this, you may be able to get by turning the blue tooth function off and on, on your phone and attempt to pair again.
Pairing Pin is likely 0000.
Dec 29, 2008 | Motorola Mobility H700 Wireless Headset
My Motorola H700 Will Not Pair
I had the same problem and I keep trying and trying 1234, 0000 and other numbers I can think of. It was frustrating. I was ready to throw my device away and buy a new one. Then I tried something that I have not and it worked. All I needed to do is to press the big button in the center of the H700 until it turns purple steadily. And then I pulled out the microphone of the H700. The button remained purple. Then I typed the password 0000 into my cellphone. The button will flicker indicating it's finally communicating and then it finally did!. Try that. Hopefully it works for you too. It worked with mine.
Jun 09, 2008 | Radio Communications
Purple light on H700 will not stay lit
I was having trouble with the same thing. The light would flash purple when closed, I opened and it stayed lit only for a second. Give it another second, I found it flashed off then came back on steady for pairing mode.
Mar 26, 2008 | Motorola Mobility H700 Wireless Headset
Motorola h700
5 Steps
First, CLOSE your boom
Second, Hold the talk button( about 5 secs it should turn to purple color)
Third, DO NOT release the button while opening your boom
Fourth, your BT should be in discover mode( show the steady light not flashing )
Fifth, open your phone bluetooth and search for device. Choose your bluetooth that appeared on the list ( pair code normally "0000" ).
Dec 13, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 Headset
close the ear peice and hold the button down till it blinks then open the ear piece.
Nov 11, 2007 | Motorola Mobility H700 Wireless Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Apr 30, 2007 | Motorola Mobility H700 Wireless Headset
Trouble connecting h700 to phone
First: When charging the light should be steady. If the battery is less than 20% charged it should be red. More than 20% it will be yellow. Fully charged it should be green. Make sure your microphone is closed when charging.
Second: Have you "Paired" the H700 and the phone? If not you need to. To put the H700 into "Pairing Mode" do this:
Make sure the H700s microphone are is in the off position. Push in and hold the button on the H700 until the light lights up purple. Release the button and quickly open the microphone button. The light will stay purple and you are now in "Pairing Mode". Now follow the instructions for your phone to pair with a BlueTooth unit. When it asks for a code, use 0000 (that is 4 zeros).
Your phone and H700 should now be connected.
Hope this helps a bunch!!!
Jan 04, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
212 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
