Question about Ahead Software Nero 5.5 (NERO5.5) for PC
Deepfreeze from my computer is not working properly
Everytime i open my computer there is a deepfreeze box appear on my desktop and if i will close the deepfreeze box its not working its hang and cannot remove the box unless i will restart my computer then i will not see the deepfreeze box again and there is another box appear telling some messge error sounds like there is some serious error recovered thats why i cannot use my deep freeze and i want to disabled it but i couldnt because its not working so i thats why i cannot save any file from my computer.
Can you help me to solve this problem? how can i fix deepfreeze from my computer? thanks and more power
  • ram20689 Mar 16, 2009
    my deepfreeze is hanged, and whenever i try to open it it gets hanged, what do i do, please reply me a solution.
  • 36 Answers
Try uninstalling deepfreeze, it might solve your problem.. to uninstall deepfreeze, you must run the Installer file of deepfreeze..
Posted on Feb 03, 2009
I forgot my deepfreeze and i need to delete it tho it can't be deleted without unfreezing my pc i tried antideepfreeze and it failed for me ....what can i do ?
There's no possible way to recover a lost/forgotten Deep Freeze password. But there are several ways to possibly disable/uninstall DeepFreeze.
Enterprise Version :
Deep Freeze Enterprise users can generate One Time Passwords (OTP) to gain access to deepfreeze. To generate an OTP,
  1. Open the Deep Freeze login dialog on the system for which you need to generate the One Time Password.
  2. Write down the Token code. It is located at the top of the login dialog.
  3. Open the Deep Freeze Configuration Administrator and click the One-Time Passwords tab or open the Enterprise Console and click on Tools > One Time Password.
  4. Enter the code you recorded into the Token field and click Generate OTP. Another code will appear in the OTP field. The second code is the password for the workstation.
The newly generated One-Time Password can then be used to disable, uninstall, and re-install Deep Freeze with the correct password.
For Deep Freeze evaluations (with no License Key entered) :
  1. Restart the computer.
  2. Enter the system BIOS settings.
  3. Advance the clock by at least 60 days and then restart your computer. This will disable the software.
  4. After the system has started, run the Deep Freeze installation program to uninstall Deep Freeze.
  5. After the computer reboots, re-enter the BIOS and reset the clock to the current date. You can then re-install Deep Freeze after restarting.
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options avalalbe to assist you.
Feb 14, 2013 | Computers & Internet
ICON DEEPFREEZ IN MY COMPUTER IS LOST
1.Check in Recycle Bin on desktop.Select and Restore.
2.Start-Programs-select deepfreeze,rightclick-send to desktop or u will get it from Programfiles Folder,open deepFreeze folder-select DeepFreeze.exe and rightclick-send to desktop.
Jun 28, 2011 | Computers & Internet
My deepfreeze didn't show in my taskbar how i can disable it?
I understand that you would like to disable the deepfreeze software installed on the computer.
One or more methods can be employed to enable/disable (Freeze/Thaw) Deep Freeze depending on the version being used.
A) Locally at the workstation (Deep Freeze Standard and Enterprise):
The following steps can be used to disable (Thaw) Deep Freeze:
  1. Hold down the SHIFT key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6. A Password dialog is displayed.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering a password. The Boot Options dialog is displayed.
  3. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. The same steps can be used to enable (Freeze) Deep Freeze. The only change is to select "Boot Frozen" instead of "Boot Thawed".
B) Remotely via Deep Freeze Command Line Control (Deep Freeze Enterprise only):
Deep Freeze Command Line Control (DFC.EXE) can be used to Thaw/Freeze Deep Freeze through a script or batch file. More information about using this utility can be found in the Deep Freeze Enterprise user guide available at:
http://www.faronics.com/documents/DF6Ent_Manual.pdf
C) Remotely via the Enterprise Console (Deep Freeze Enterprise only):
The Deep Freeze Enterprise Console can be used to Thaw/Freeze a workstation using the following steps:
  1. Select the workstations to Thaw/Freeze.
  2. Click the "Reboot in Thawed state" button to Thaw the selected workstations. The workstations should reboot and appear in the Console in a Thawed state.
  3. Click the "Reboot in Frozen state" button to Freeze the selected workstations. The workstations should reboot and appear in the Console in a Frozen state.
Please try the steps and I am sure you would be able to disable the deepfreeze software.
Apr 20, 2011 | Faronics Anti-Executable Standard
How i can uninstall deep freezer
Please use the Deepfreeze software to uninstall the Deepfreeze from the Computer. I mean use the Deepfreeze software "Deepfreeze.exe" file on the computer which you have already installed the Deepfreeze to uninstall it!
Mar 27, 2011 | Computers & Internet
I want to uninstall deepfreze from my computer ,but i can't do it because it's still enabled Can you help me please , thanks Armando
Stop all the processes related to Deepfreeze in the Windows task manager box. After that go type appwiz.cpl in the run box in order to remove it from the uninstall box. If you are unable to then u can always remove them manually from Program Files. If still deepfreeze remains there go to run box and type regedit.exe then press Ctrl+F for the find option and type Deepfreeze and press find next ( F3 ) in order to search for the occurences of the words in the registry. Go on deleting it from the registry thus u'll delete every instance of the file from your system. Bingo !!
Sep 24, 2010 | Computers & Internet
How to delete deepfreeze
Hi. I think if that deepfreeze workstation program has password then you should know it and enter that password by pressing and holding CTRL+ALT+SHIFT then press F6 then enter the password. After that you must change the state to THAWED state then restart your computer. Your deepfreeze icon on the lower left should have an X marked now that is blinking, it means that your deepfreeze is already disabled, now you can uninstall it by using the same installer that you use to install your deepfreeze workstation. If you dont know the password you should have the main installer for deepfreeze 6 that creates a workstation installer and you can use that main installer to generate a password for you to login your deepfreeze workstation. Hope This Helps
Jun 04, 2010 | Computers & Internet
No deepfreeze icon in task bar
try to unfreeze it. then uninstall it by using your deepfreeze installer.
Jan 23, 2010 | HP Pavilion dv6000z Notebook
I want to remove deepfreeze software from my pc but i forgot the password
follow the path name to it's folder and delete the contents, an example is:
c:\program files\deepfreeze
I am certain there are more folders in the path. Active files will not delete this way, so you may have to use task manager to turn off the deepfreeze applications to fully remove the program
Jun 04, 2009 | Computers & Internet
Uninstall the deepfreeze in vista
  • Booting Computer From CD use Windows XP Installer
  • After coming up with part to Enter Setup, Press Enter then F8 and await some moment
  • then selected R to repair Windows ( Repair Setup)
  • Hereinafter continue Install windows untill finish.
    1. Now prepare the Deepfreeze v.6 of and double click
    2. will appear “Uninstall Deepfreeze” windows and process uninstall till finish.
    3. Done……
  • In this time i still not known more effective way to remove DeepFreeze 6.0. if there is a way of more effective please share here… icon_biggrin.gif
  • Jul 25, 2008 | Microsoft Windows Vista Ultimate Edition
    Ahead Software Nero 5.5 (NERO5.5) for PC Logo
    433 people viewed this question
    Top Ahead Software Computers & Internet Experts
    celos
    lemesee
    Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
