Question about Canon imageRUNNER C3200 Copier
Canon ir 3100 making grinding noise, not reading black toner
  • 59 Answers
Take out the black developer unit, probably is siezed up ie won't even turn by hand vac out or replace
Posted on Mar 23, 2009
I av a problem wit my canon copier ir 2018 .it is having a display red light flashing indicating out of toner while toner is there.wat is the solution of this problem?
Jun 29, 2011 | Canon iR 2016i Black and White Copier
My photocopy, the iR 2016 does not read the amount of tonner. It sends a messege that the tonner is out while is half full.
you could try to remove the developer (is where you put the bottle of toner) and clean the toner that is in the machine and the contacts.
May 22, 2011 | Canon iR 2016i Black and White Copier
I bought a new copier toner cartriage and the copier is making a grinding noise and poping. The copies skip parts of the copy. I have bought a second toner cartriage and it does the same thing. I put the...
make sure cartridge is fully installed and sitting properly. Sounds like gears are not meshing so check gears with cartridge out (bottom of copier) and see if they are damaged. If so, copier is junk.It might not be out of toner just can't read it properly as it is not seated proper.
Dec 22, 2010 | Canon PC-940 Black and White Copier
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
E020-01A9 Error Code.
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
I have toner of Ir 3100 but I want to use in ir c 3200 is it
Well toner compositions change to work correctly with different developers. If you use the wrong toner/developer in your machine you WILL need a tech to de-contaminate your machine at a hefty price. That is why the manufacturer makes the bottles different, so the customer cannot use the wrong toner in the machine. DO WHAT YOU WILL.. But I advise Strongly against it.
Apr 03, 2009 | Canon imageRUNNER C3200 Copier
Canon IR3100 CN making grinding noise may visit canon website at internet..chose product support/dowlnload----find your product here and finally you can get and download manual book as pdf for free....good luck..
Feb 03, 2009 | Canon imageRUNNER C3200 Color Printer
Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Feb 19, 2008 | Office Equipment & Supplies
Lexmark C510 Laser Printer- Grinding Sound on startup and while printing
Thank you Krissy! I had the same problem with the horrible grinding noise.
I took out all of the toners and the photo developer and noticed that my Blue toner was leaking all over. After reading your post, I tried replacing the toner. It worked!!! No more noise - and no more mess!
Jan 30, 2008 | Lexmark C510 Laser Printer
Canon imageRUNNER C3200 Copier Logo
128 people viewed this question
old marine
old marine
