Washing machine power button is not switching on
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
My fisher and paykel top loading q washing machine won't start. It beeps and lights 5 and 8 come on. Any ideas what the issue might be?
That is fault code 9 machine not sized
9. (00001000) Size Switch Error
The Display size switch setting does not match that which is stored in memory.
Action GW Machines: Reselect the size of the machine by using the SIZE SETTING
MODE.
To set the size switch, turn the power on at the power point and off at
the console. Press and hold Wash Temperature Setting Up then
press Power. SmartDrive will give 4 short beeps and the pattern of
LEDs will change.
One of the following buttons needs to be pushed to lock the size into
memory.
• Press Wash Temperature Setting Up, the Cold LED is on for 5.5kg
(560mm wide).
• Press Water Level Up, the Low Water LED is on for 6.5kg / 7.0kg
(600mm wide).
517790C
35
• Press Spin Speed Up, the Spin Hold LED is on for 7.5 / 8.0kg
(650mm wide).
• Press Power to confirm the setting and also exit this mode.
Action IW Machines: To access Size Setting Mode, push and hold the Fabric Care button
and then press the Power button to enter Size Setting mode. Select
the correct size on the display by pushing the Adjust button to
highlight the correct size. Size setting is then achieved by pressing
the Power button. Powering off will set the size into the memory.
Note: Fault code 9 will only be logged into the memory of IW machines. GW and MW
machines can display this fault but it will not be recorded.
Aug 13, 2012 | Fisher and Paykel Washing Machines
My top loading fisher and paykel q washing machine beeps with lights 5 and 8 on - what is the problem?
That is Error code 9 machine needs resizing.
MODE.
LEDs will change.
memory.
(560mm wide).
(600mm wide).
517790C
35
(650mm wide).
Button got pushed in too far and now unable to start machine
Possible that the button is struck and so does not activate the switch. Please try and remove the power and remove the panel to reset the switch contact before the controller panel can be checked.
Jun 11, 2012 | Washing Machines
Power to machine but will not start a cycle
If child lock has been activated, all buttons on the control panel except for the power button will be inoperable. Child lock is usually activated by pressing either the [pre-wash] or [tub clean] button for 3 seconds. To deactivate the child lock function, press and hold the same key again for 3 seconds.
Try switching the machine off by pressing the on/off button. Press the same button after a few seconds to restart the machine.
Mercedes Parts
May 25, 2012 | Washing Machines
I have got a westpoint washing machine XQG50-604 the water switch is faulty but the machine is working it doenst pour water on the machine at all.rose e-mail:rntuli@uj.ac.za
Hi
I have a Westpoint front loader washing machine, model number XQG50-604. The power button got stuck, opened machine up and find the power switch burnt out. Where is Johannesburg in South Africa can I get a new switch please? Also can you advise how to remove old switch and to replace the new switch.
Regards
Juanita
Feb 15, 2011 | Washing Machines
How do I use the Child Lock option on Samsung WF-B1456GW?
You can use the child lock feature in 2 ways.
1. To prevent operation of the washing machine when no wash cycle is running
To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
2. To prevent any tiny fingers from tampering with the machine while a program is running.
After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Feb 09, 2011 | Washing Machines
Dyson showing fault no 70 600 2701
hi
the support number for Dyson is 0870 600 2701
this is when the code was obtained, therfor you should have an Fxx code.
Try this:
  1. Switch off the power using the 'MAINS ON/OFF' button
  2. Press and hold the 'Temperature' button
  3. Carry out the next three steps within 3 seconds;
  4. Switch on the power
  5. Release the 'Temperature' button
  6. Press the 'Soil type' button
  7. Check that a message similar to "DIAGNOSTIC MODE 123F7F2F5V127" is displayed. If it is not, repeat from the beginning
  8. Switch off the power
  9. Switch on the power. The fault code should have cleared
Mar 07, 2008 | Washing Machines
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
