HP Officejet 5500 - Scan Problem
XP SP3 installed and HP software for the HP unit.
Printing and Faxing = OK
Scanner (using HP software) = requires HP driver CD to be in drive and appears to reload the scanning program again - it seems to be stuck in some sort of loop of "configuring".
The unit has been deinstalled and reloaded, latest updates downloaded from HP but the scanning problem is still present.
  • comtro Feb 04, 2009
    OK - any idea as to what software?
    Problem Solver:
  • 7 Answers
Try with another software
Posted on Feb 03, 2009
Can I send and receive faxes?
u need to have a modem that can send receive fax, then install faxing software in computer, install dell drivers then setup modem, and send recieve program, to send fax u scan n save then use fax program to use image sometimes it may scan and send at same time? read manual with program
Aug 22, 2015 | HP Photosmart 3210 Printer
Scanner error in HP officejet Pro L7590
These instructions will fix the majority of scanner problems and networking problems using ethernet:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01849855&lc=en&dlc=ro&cc=ro&product=3643612&rule=4124&lang=ro
The key is to assign a static ip address for the printer. The install problems of trying to get the HP printer to be found will go away. You can then use the scanner. Also...it is crucial that when connecting other laptop's and PC's on the same network that you use the hp printer'rs host name to find the printer on the network. I find that the IP address can and usually fails to find the hp on the network. Mostly likely you cannot search the network for a hp printer until you go the route of find the hp network printer with the host name of the printer. You will also need your install disk when installing on other networl laptop's and PC's since windows xp and Vista machines don't have the drivers in the list. You will need to point the add printer gui driver to the disk and look for autorun.inf
file. After selecting that file...you can then see your drivers.
May 14, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
After XP re-install, hp5610 scanner function fails
Reinstall the drivers ... making sure you have the latest driver from HP for your XP operating system.
Mar 03, 2010 | HP Officejet 5610 All-In-One InkJet...
IseMY Hp all in one 4355 printer is unable to scan
The HP Officejet 4355 can print, scan, copy and fax.
You need to install the printer software to print and scan. Copy and faxing does not required software installation.
Regards,
Rizwan
Feb 11, 2010 | HP Officejet 4355 All-In-One InkJet...
Just installed HP p6240f desktop with Windows7. Downloaded drivers for HP Officejet 7310 All-In-One Printer. Printer Staus Ok; printing from PC files Ok; printing from HP Solution Cenmter ok; cannot scan...
First, I thought your assistance center would respond to my request since this same problem appears in the HOP website problems & solutions.
I did not resolve the problem after downloading the All In One Series software. It failed to complete the installation after hours of loading.
I did my own tasking and found that I could resolve my oproblem by Control Panel - Devices (printers) - HP 7130 Officejet-Scan Document.
It worked.
Savuing the scanned document is quite different in this Windows7 setup from the prior XP. It is more circuitous to get to where I want to place the file.
Dec 05, 2009 | HP Thin Client - AMD Geode NX 1GHz - 256MB...
Computers not sensing scanner via LAN
Scanning over network usually requires software to connect. First go to the drivers page as below. Windows Vista | Windows XP, download the latest drivers (the Full Feature one) as well as the firmware update for the OfficeJet. Plus the "Update" files that's dated newer than the Drivers.
Upgrade the firmware (this will reset all custom settings in the OfficeJet like IP address) with a USB connection.
Run the full feature installer and if there is an option for Networked OfficeJet, then tick it. Also you may need to change/disable firewall for the installer to pick up the networked OfficeJet.
Scanning over the network usually connects with a customized TCP port. And most likely the Windows "Scanners and Cameras" will not pick up network scanners unless it's been defined manually (installer can do this part).
Jun 15, 2009 | HP Officejet Pro L7650 Printer
Hp5300c scanner-can't use HP software on new PC (XP Pro SP3)
Are you using the software from HP? It sucks. If the HP software is not working correctly, then Use the one provided my your operating system works great. Go your Control Panel, Printer and other Hardwares and click Scanners, make a shortcut to your task or start menu and Scan Away. For Faxes, etc. import in outlook or other email client, etc.
Feb 19, 2009 | HP ScanJet 5300C Flatbed Scanner
324 people viewed this question
k24674
jasbo
jasbo
