Question about Nokia N70 Cellular Phone
I want to upgrade the firmware on my N70,what do i do.i am also trying to download yahoo!go 3.0 but am getting a message saying its not available on my device. i checked the compatible phones and N70 is on the list. any help?
  • 58 Answers
Hi,there...if you want upgarde the firmware of your nokia i suggest you better you go to nearst nokia service center and let the expert in nokia do it for you for the best result to your cellphone
Posted on Feb 03, 2009
La impresora 4345mfp se bloquea y nose como hacer la actualizacion del firdware.
Upgrading the firmware
The MFP has remote firmware update (RFU) capability. Use the information in this section to
upgrade the MFP firmware. The overall process involves the following steps:
1 Determine the current level of firmware that is installed on the MFP.
2 Go to the HP Web site and find out whether a firmware update is available. If an update is
available, download the latest firmware to your computer.
3 Transfer the new firmware from your computer to the MFP.
Determining the current level of firmware
To determine the current level of firmware, view the configuration information on the MFP control panel. To view the configuration information, follow these instructions.
1 Press MENU.
2 Touch INFORMATION.
3 Touch PRINT CONFIGURATION. The configuration page prints.
4 The firmware datecode is listed in the section called Device Information. The firmware
datecode has this format: YYYYMMDD XX.XXX.X. The first string of numbers is the date, where
YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20040225 represents February 25, 2004.
Downloading the new firmware from the HP Web site
To find the most recent firmware upgrade for the MFP, go to www.hp.com/go/lj4345mfp_software.
This page provides instructions for downloading the new firmware version.
Transferring the new firmware to the MFP
Use one of the following methods to update the firmware.
Using FTP to upgrade the firmware on a network connection
NOTE The MFP can receive an .RFU file update as long as it is in a "ready" state.
The elapsed time for an update depends on the I/O transfer time, as well as the time that it takes for the MFP to reinitialize. The I/O transfer time depends on a number of things, including the speed of the host computer that is sending the update. If the remote firmware update process is interrupted before the firmware is downloaded (while Receiving Upgrade appears on the control-panel display), the firmware file must be sent again. If power is lost during the flash DIMM update (while the Performing Upgrade message appears on the control-panel display), the update is interrupted and the message Resend Upgrade appears (in English only) on the control-panel display. In this case, you must send the upgrade by using the parallel port. Finally, any jobs that are ahead of the RFU job in the queue are completed before the update is processed.
Follow these instructions to perform the upgrade by using FTP.
To upgrade the firmware on a network connection by using FTP
1 Take note of the IP address on the HP Jetdirect page. The HP Jetdirect page is the second page that prints when you print the configuration page.
NOTE Before upgrading the firmware, make sure that the MFP is not in Sleep mode.
Also make sure that any error messages are cleared from the control-panel display.
2 Open an MS-DOS command prompt on your computer.
3 Type: ftp <TCP/IP ADDRESS>. For example, if the TCP/IP address is 192.168.0.90, type ftp
192.168.0.90.
4 Press Enter on the keyboard.
5 When prompted for the user name, press Enter.
6 When prompted for the password, press Enter.
7 Type bin at the command prompt.
8 Press Enter. The message 200 Types set to I, Using binary mode to transfer files appears in
the command window.
9 Type put <filename> where <filename> is the name of the .RFU file that was downloaded
from the Web, including the path. For example, type put C:\LJ\4345FW.RFU, and then press
Enter.
NOTE If the file name or path includes a space, you must enclose the file name or path
in quotation marks. For example, type put "C:\MY DOCUMENTS\LJ\4345FW.RFU"
The following series of messages appears in the command window:
? 200 PORT command successful
? 150 Opening BINARY mode data connection
? 226 Ready
? 226 Processing Job
? 226 Transfer complete
Then, a message that contains the transfer-speed information appears.
10 The download process begins and the firmware is updated on the MFP. This can take
approximately five minutes. Let the process finish without further interaction with the MFP or
computer.
NOTE The MFP automatically turns off and then on again after processing the upgrade.
11 At the command prompt, type: bye to exit the ftp command.
12 At the command prompt, type: exit to return to the Windows interface.
Using MS-DOS commands to upgrade the firmware
To update the firmware by using a network connection, follow these instructions.
1 From a command prompt or in an MS-DOS window, type the following: copy /B <FILENAME>
\\<COMPUTERNAME>\<SHARENAME>, where <FILENAME> is the name of the .RFU file
(including the path), <COMPUTERNAME> is the name of the computer from which the MFP is
being shared, and <SHARENAME> is the MFP share name. For example: C:\>copy /b C:
\9200fW.RFU \\YOUR_SERVER\YOUR_COMPUTER.
in quotation marks. For example, type: C:\>copy /b "C:\MY DOCUMENTS\3500FW.RFU" \\YOUR_SERVER\YOUR_COMPUTER.
2 Press Enter on the keyboard. The control panel shows a message that indicates the progress of the firmware upgrade. At the end of the upgrade process, the control panel shows the Ready
message . The message 1 file(s) copied appears on the computer screen.
Jul 15, 2011 | HP LaserJet 4345mfp Printer
Failure to install yahoo!Go 3.0
Just update the latest version of nokia pc suit(available from nokia web site).In that there is a software updater section slect that and then you will get the prompt window for upgrading the firmware.The only thing u should be cautiond is the electricity n internet connection should not be interepted by anything.
Feb 03, 2009 | Nokia N70 Cellular Phone
Certain songs on my Sansa m240, will not play
If the songs you have are DRM protected then you may need to check with the source from where you've downloaded the track.
Sometimes, if the Music data base on the device is corrupt, even then you may run into such problems.
follow the instructions below to get the sansa firmware updater to make sure that the firmware for your payer is updated automatically:
METHOD 1 - Download and manually update the Sansa m200
NOTE: The manual update does NOT support firmware version 4.X.XXX. Refer to METHOD 2 if the firmware on your Sansa m200 is either 4.X.XXX.
WARNING: All data on your Sansa m200 will be deleted during the firmware update. Back up all your data before proceeding.
STEP 1 - Download the Sansa m200 Firmware Updater .exe file and save it to your desktop.
STEP 2 - Install the Updater
1. Double-click the downloaded .exe file (sdmx3-iv001.exe).
2. Click Next
3. Click Yes to agree on the license agreement.
4. Click Next to start installing the program.
STEP 3 - Connect your player to the PC
1. Turn off your Sansa m200.
2. Slide the HOLD switch to the lock position (orange color will show).
3. Connect the player to the PC.
STEP 4 - Update the firmware
1. Click Firmware Upgrade
2. Click OK to continue the firmware update.
3. Click OK to finish update.
4. Disconnect your Sansa m200 from the PC after the firmware has been successfully downloaded.
5. Slide the HOLD switch to the unlock position (orange color not showing).
6. Turn on your Sansa m200 player to check.
METHOD 2 - Using the Sansa Firmware Updater.
1. If it's not installed yet, download and install the Sansa Firmware Updater
3. Connect your Sansa m200 to the PC.
4a. Assuming there's a new firmware available, the following message will appear on your lower right taskbar. Click on the balloon message.
NOTE: If there's no new firmware available, you won't see a balloon message.
4b. OPTIONAL: You can also manually run the Sansa Updater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater
5. Select the Firmware check box.
6. Click Download Now. Firmware download starts.
7. Click Yes to continue the update.
8. Click Finish after the firmware has been downloaded.
9. Disconnect your Sansa player from the PC.
10. An "Upgrading firmware. Please wait..." message will appear on the Sansa m200's display screen.
Jan 10, 2009 | SanDisk Sansa m240 MP3 Player
Cannot reload firmware
I had the Exact same problem and no one had a good solution, i only found one that finally worked after spending 4 freakin hours tryin to fix it. anyway here is the solution.
you need to use a computer that has Windows XP, then if the computer is running any version of Windows media player other than 10, roll back or upgrade to Media player 10. restart the computer.
Now, you need to download and run http://www.delldjsite.com/forums/attachment.php?attachmentid=462 honestly i have no idea what it does. my guess is it reinstalles the USB ports but thats only a guess. but i was so frusterated by the time i found this solution that i was willing to try anything. so download this file, unpack it and run it. then it will ask you to restart. when your computer is restarted run the new firmware file ( i used 1.62.2.0) and it works.
Why? i have no idea, but it i was pumped. the origional site i got this solution from is http://www.anythingbutipod.com/forum/showthread.php?t=18864
Jan 19, 2008 | Creative Labs ZEN Vision:M Digital Media...
How do you update firmware on YEPP YH-J70?
unzip file, put it directly on disc don't use any program, disconnect, turn off, put on recharge and power on the player.
Dec 09, 2007 | Samsung Yepp YH-J70 Digital Media Player
No License to Play/ sync license from pc
Have you tried updating the firmware of your Zen V Plus? I've had mine for almost an year and haven't had these issues -- I updated the firmware as soon as I unpacked it.
try downloading the
MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
Oct 06, 2007 | Creative Labs ZEN V Plus MP3 Player
I can not get it to download any music
I have the EXACT PROBLEM! I hate this damn mp3 player! I've spent 2 days trying to get it to work!
Apr 26, 2007 | Philips PSA250 MP3 Player
Cant transfer music
Greetings from Ireland. I never had problems before, but i sent my MP3 player to sony for repair and when I received it it had the same issue.
The reason for this is that on the player there is some 5Mb of data that is generated by the firmware of the player. The firmware is like a bios of the device. If the firmware is not compatible with the software you're trying to transfer the music with, you will get this message.
Firstly, check if you have the latest version og Sonic Stage of Open Manager (depending where relevant). This should fix the issue. If it doesn't, you may need a firmware upgrade. The upgrade is easy to download and instal and is available directly from Sony.
Warning: Only install firmware and software updates provided by Sonly directly. Specially with firmware, wrong package can damage your player so be sure that the file you're downloading and installing is the right one.
Visit Sony Support page to download files.
Apr 06, 2007 | Sony Vaio VGF-AP1L (40 GB) MP3 Player
Upgrading firmware
Downloading the Firmware Step 1: Before downloading the firmware, make sure that your computer has an active Internet connection. If your computer is plugged directly into the router and cannot get online, disconnect your router and plug your computer directly into your cable or DSL modem. Step 2: Once you are able to get online, click here to go to the WRT54G Version 5 Download page. Step 3: Click Download to download the firmware file. Approx. file size (Zip file): 1.39 MB If you are using Windows XP Service Pack 2 (SP2) and Internet Explorer, you may see a 'Pop-up blocked' message in your browser Information Bar. If so, click the bar and select Temporarily Allow Pop-ups. Then, click the Download link again. Step 4: Click Save in the File Download dialog box that appears. Step 5: In the Save As dialog box, choose a location for the file (like the Desktop) and click Save. The wrt54gv5_fw_1[1].00.6_US_code.zip file will then be downloaded. When the download is complete, click Close if prompted. Step 6: Double-click on the wrt54gv5_fw_1[1].00.6_US_code.zip file and extract its contents to a single folder (or to the Desktop). NOTE: You will need to use a utility to open and extract files from the ZIP file archive. Popular software to use is WinZip®. For information on how to download WinZip®, visit the following website: http://www.winzip.com. You can also use the built-in unzipping features of Windows XP to unzip the contents from the archive. The following (3) files should be available: * wrt54gv5_fw_1.00.6_US_code.bin * Readme.txt * wrt54gv5_ver.txt Upgrading the Router's Firmware Step 1: Plug your computer directly into Port 1 on the back of the router. Step 2: Make sure that the router's power is plugged in. Step 3: Open Internet Explorer. Type http://192.168.1.1 into the Address Bar and press [Enter]. Step 4: You will be prompted to enter a username and a password. Leave the username field blank, and enter admin for the password. Then, press [Enter] or click OK. NOTE: If you are asked for the password again, the router's default password was changed. Try a common password that you might have changed it to. If are still unable to log in, hold in the Reset button on the back of the router for 30 seconds. After 30 seconds, unplug the power to the router and then plug it back in. Then, try Steps 3 and 4 again. Step 5: When the router's web-based Setup page loads, click on the Administration tab. Step 6: On the Administration page, click on the Firmware Upgrade sub-tab. Step 7: On the Firmware Upgrade page, click Browse. Browse to the location where the firmware files were extracted, and select the wrt54gv5_fw_1.00.6_US_code file. When the file is selected, click Open. Step 8: Click the Upgrade button on the Firmware Upgrade page to start the upgrade. The upgrade will take a few minutes - please do not unplug the router's power cord or make any changes during this process. Step 9: When the upgrade has completed, the following message will appear: "Upgrade is successful. rebooting...." Completing the Firmware Upgrade Step 1: Close Internet Explorer. Step 2: Hold in the Reset button on the back of the router for 30 seconds. After 30 seconds, unplug the power to the router and then plug it back in. This step will ensure that the new firmware loads properly! When you are finished... The firmware upgrade is now complete! You can now use the router's Setup Wizard CD to configure your Internet service and set up your wireless connections.
Feb 16, 2006 | Linksys (WRT54GC) Router
Nokia N70 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
