Question about Dell Inspiron 1100 Notebook
Red lines on black color area
I've got a problem with my laptop that... the screen has got a kinda red tinge on dark color area, especially with black color. I don't know where to start and what to fix. So, I'm asking for help from one who have any idea how to fix it, please feel free to give your suggestion. I will try to fix it myself.
  • goodygoodfy Feb 05, 2009
    thank you for your advice. I'm able to fix it. I took all parts out clean a bit... and put them all in again. Now, it works so wel;... just like before. ^_^
    Problem Solver:
  • 17 Answers
Its probably the inverter. its a device that powers lcd screen's. ebay the model # and include inverter. it will give you a ballpark number to work with
Posted on Feb 05, 2009
Z3 projector.3 years old. Blue tinge in one corner of projected picture. Grainy picture on dark scenes.
There may be some problem with your picture tube else try this that looks like retrace lines. Anyway, you should try to adjust screen pot not focus pot. Make sure you are turning blue screen pot (there are 3 focus pots and 3 screen pots) and do it slowly. If you turn it too much, it will affect your grayscale
Jun 23, 2008 | Televison & Video
I,ve got a red spot in the screen i replaced the bulp but stil have the problem
it is most likely a burned polarizing filter. There is a polarizing filter on the blue light channel and another on the red channel. When black, or other dark colours are displayed, the red polarizing filter is supposed to block ALL of the red light being projecter. If the filter is burned, some light slips through and creates a red tinge on the projected image. If the red tinge only appears on dark images, but is absent when the images is completely white, a damaged filter is likely the problem.
Seems its hard to buy them. Best bet is probably buying a broken projector from ebay and stealing the filters out of it.
Oct 04, 2010 | Toshiba TLP 670 Multimedia Projector
Red Lines through picture when screen is dark, back ground has a red tint. On my 48 "Sony Rear Projection" TV
You can try adjusting the Red color output. (Very touchy adjustment)
If you take off the front cover/speaker cover, there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need less red in the mix. There is a screw for each color. R, G, and B. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Go to an unused input where the screen should be dark. Barely turn the red down in a dark room so that the red spot is at the same level as the Blue and Green.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn any of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Apr 19, 2010 | Sony KP-48S75 48" Rear Projection...
Dell Inspiron 1501 Laptop-6'' Red Vertical Line
The color red and especially red colored lines or a pinkish hue are indicative of an impending screen failure. The only other possibility is that the data cable on the left backside of the lcd panel may be loose at the socket or on the motherboard. 9 times out of 10 though, it is the lcd panel that it failing.
Jan 17, 2010 | Computers & Internet
Red instead of black screen
Looks like you have a problem either with the LCD inverter or the video card. Unfortunately your best option is to call Dell for out of warranty repair options, that is if your computer is out of warranty.
Sep 23, 2009 | Dell Computers & Internet
Picture is very dark and color not too good.
Take the front speaker grille off; it is stiff but will pull off. Take off the access panel underneath; four or five screws. Inside you will find a screen/focus block control assembly. Get a flashlight. Turn up the screen controls SLIGHTLY. for RED, GREEN AND BLUE. The best way to do this is to turn off the color first and make sure you end up with a good black and white pix ( not tinged green, red or blue) then turn the color back up in the menu.
May 11, 2009 | Televison & Video
Some black colors are replaced with red blue flickreing in whites
Hi there
Firstly reinstall the graphics drivers, if its still the same there is a problem with the graphics card and you'll have to have it looked at.
Good luck and thanks for using Fixya!
Feb 06, 2009 | Fujitsu LifeBook C2340 Notebook
Very fine red lines across srceen
It is an adjustment, but it's an adjustment you may not want to do. It's the red screen control. It's located behind the front panel so the entire front panel has to be removed in order to access it-which will expose you to hazardous voltages. if you like, I can post detailed instructions on how to get that front panel off, it's kinda tricky.
Jun 13, 2007 | Sony KP-51WS500 51" Rear Projection...
Dell Inspiron 1100 Notebook Logo
259 people viewed this question
Alun Cox
