Question about Mercury P4VM800M7 Motherboard
System not booting
When i switch on my system my harddisk is booting before getting into home page system automatically gets turns off. When i press the power button in cpu, system never turns on. I have to turn off the ups and turn on again to restart the system. I have inserted Windows Xp Sp2 cd in my DVD drive and changed my cmos to boot from cd drive, but the system is not getting booted from cd. My mother board is Mercury PVM7 PRO V1.0, in my mother board where can i plug the following pins HDD Power card, LED power card.
Please help me in fixxing my problem.
  • Roberta Smith
    Roberta Smith May 11, 2010
    two things... are you sure it's a bootable cd... and you have to tap a key for it to actually boot to the cd
    New Friend:
Windows are any time currpted
Posted on Feb 18, 2013
  • 28 Answers
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
aamknr-23
Posted on Aug 29, 2009
I want display driver of vista for p4m800m7
Posted on Feb 03, 2009
    Champion:
  • 254 Answers
Remov the cmos battery and reset cmos to std
try safe mode ? tap the F8 key while booting
see if you can turn off the auto restart on system failure
R/Mouse button on My Computer (not a shortcut) L/Mouse on properties . Advanced Tag Start up and Recovery Settings Button
Untick auto restart
hope this helped
2 Suggested Answers
bravsman
  • 94 Answers
SOURCE: CMOS setting distrubed for mercury PVM7 ver 1 board
just press del to enter to the cmos and then change the date and time of cmos and press F10 to save your configeration if you start the cpu again and if you see the message "press F1 to continue and del to enter bios it time to replace your cmos battery inside of cpu is like a coin inside of your computer
Posted on Nov 24, 2008
When turning on computer it gives me an error message saying no boot disk please insert boot disk
press f12 during start up and select your harddisk and if that doesnt solve it take out your harddisk (large plate that you can remove at bottem of laptop)
and boot your laptop switch it off put in harddisk and switch on again
Apr 20, 2010 | Acer Aspire One PC Notebook
Tip
If you get message: " boot disk failure" then follow this tip
1)If any cd or dvd is there in the cd or dvd drive remove them first then try booting
if problem persists then
2)check the boot device priority in the BIOS menu,change the boot device priority if required(change to 1 st boot device floppy, 2nd harddisk drive,3 rd to cdrom drive something like this)
to go to bios setup press del or f2(it depends if del key doesnt brings you the bios utility then press f2) at time when you switch on the pc ie at the time of booting the pc ,
3)check whether the harddisk is detected or not in the bios setup
if it is not detected then just open the CPU & check the bus & power supply cable connected to the harddisk remove them & reinsert them ...
if required then replace with the new ones ....
if the problem persists then
4)the operating system might have got corrupted just reinstall ....
5)the harddisk partitions might have got corrupted or crashed ,just try partitioning them again and by installing the operating system.
on Aug 28, 2008 | Compaq Presario 5000 PC Desktop
Dell Dimension E520 has "NO BOOT DEVICE AVAILABLE" message. Pressing F1 F2 doesn't help. What should I do?
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
Sep 03, 2009 | Dell Dimension 8400 PC Desktop
My Hp Pavillion laptop dv2214tu doesnot boot beyond the HP INVENT logo page. I tried performing the Primary Hard Disk check as stated on the HP Support site but its not happening.I also reseated the RAM...
Unscrew your Laptop HardDrive bay and remove your harddisk first, then try to boot your system wthout the Harddisk inside. If it Boots past the HP Invent Logo Page, then your harddisk is the one that is faulty, if still doesnt, get another good, working RAM, apart from the one in your system, and use it to test your laptop...making sure that the harddisk is still not inside...then if it boots insert your Harddisk back with the new RAM, and restart your system.
If in the first case it boots (i.e wihout the harddisk inside)...then it means your harddrive is faulty, just retrieve your file on it and get a new one.
If in the second case it works (i.e with a new external RAM) then just change your RAM instead.
Jul 09, 2009 | HP Pavilion Notebook
How do i get laptop out of hibernation
To get the machine out of hibernation just press the power button.
Regards
Jul 01, 2009 | Toshiba Satellite Pro L300 Notebook
Hi. Well there are not any reason for this problem to appear. Done nothing regarding disk problem. Anyway when I boot the process stops with the black screen with "Verifying DMI Data...... Boot from...
Make sure you dont have a floppy in the floppy drive inserted.
Also if you have a jump drive installed, plz unplug it.
But if you little computer savy. Go to your bios and make the boot sequence to first boot the Hard Drive
May 24, 2009 | Foxconn G31MX-K socket LGA775 motherboard
L440Gx server board do not boot
1: Check wether the on/off button on your power supply is turned to on.
2: Check your cables. Try switching with those from other pc's.
3: Check wether all the connections from power supply to the mainboard/ram/video/harddisk are OK.
Hope this helps,
Yannick
Feb 18, 2009 | Intel Server Board L440GX (KMS440GXTPAK10)...
Freezes up at 3/4 boot 90% time
when u power up the computer press
F8 key then enter in safe mode.then tpye in run"chkdsk /r"
then press "y"
then restart the system.then it fixes error on harddisk.scan your computer with latest updates antivirus.
Jan 05, 2009 | Computers & Internet
ASUS Z91H PUSHED POWER BUTTON BUT WITHOUT DISPLAY
Try pressing the power button and press [del] button. See if it goes to the bios setup page. If it does, have your harddisk checked. It could be corrupt OS or problem with your harddisk.
Sep 12, 2008 | Computers & Internet
Disk Boot Failure
you need to select ur harddisk as the first bootable device., that option is in BIOS settings. When switch on the system before loading OS press F2 to get the BIOS settings and select boot option in the menu and select your harddisk as the first bootable device. Restart the system now. If the same error is displayed your harddisk data cable may be failed or your harddisk may be corrupted...
Jul 11, 2008 | Computers & Internet
Mercury P4VM800M7 Motherboard Logo
803 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Alun Cox
vsri9
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
