Question about Car Audio & Video
Hi there i bought a hyundai i30 2008 model and i have installed a bluetooth car kit works great but i want to hook it up to the mute wire on the back of the radio unit,but i can't find which wire it is
  • raiders1305 Feb 07, 2009
    from where any suggestions ive tried everything need help please
    Problem Solver:
  • 6 Answers
Google the units wiring diagram
Posted on Feb 06, 2009
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
Brown mute wire for new ken wood in 2002 rodeo, does it go with illumination wire, green/red or red/green?
Hi, i'll need a bit more info to be able to give you an opinion , am i correct in assuming the "new kenwood " is a radio/cd player ? If so do you have a car phone or a hands free kit for your mobile/cell phone ? Assuming the kenwood is a radio the mute wire has to be connected to the car phone/mobile hands free kit , this is usually described in the phone installation directions , how the mute system works is when you recieve a call the signal is sent via the phone system to the radio , which is where the mute wire comes into use .If you have either of the phone set ups i've described post back with there details , make , model etc ,if you do not have this type of system and are using an ear piece then the mute funtion can't be used , i hope this is of some help to you
Apr 06, 2015 | 2002 Isuzu Rodeo
No Sound from Jensen VM9725BT
Jimmie Monica Hey, Its not a problem with the unit. You have the blue or Blue/White wire hooked up wrong. Disconnect both the blue wire and the blue and white wire and I guarantee the sound starts working on everything. If you have one of those two wires hooked up for a power antenna or remote amp turn on, then switch which one you are using and that will fix the problem permanently. Disconnecting them both will get it to work though. I guarantee it. Please post back and let me know if it works for you. Thanks
Sep 06, 2013
Feb 22, 2013 | Jensen VM9725BT Navigation receiver
How to wire my parrot ck3100 into a sprinter van can u give me the wiring diag as i dont have any connectors on my parrot kit as its from my old car im having trobule with the mute wires and speaker...
First, you will have to know if the vehicle has a facra or an iso norme build in it.
If it is a Facra, the wires to wires install is still possible but complicated and will necesarly need to get the diagram. Especially if the vehicle has an amplified system build in it. Or maybe optic fiber somewhere in the vehicle.
The vehicle has maybe an mute included into the autoradio, then the hot question you have is about the existing cable harness existing.
In that case I will advising you to get in touch with the manufacturer of the kit to get informed.
Aug 03, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Bluetooth wiring diagram
you will need to search for a wiring diagram for your model of car radio
car kit blue - connect to ignition cable OR connects to switched 12v cable going to radio
car kit red - Direct to +terminal of battery OR to constant 12v cable going to radio
car kit black - connects to GROUND going to radio
car kit yellow - connects to mute function of radio if your radio supports it.
OR
connect blue and red together and directly to battery
and connect black to Body of vehicle
(not recommended as could result in draining of battery, even thought the kit is supposed to prevent this).
Jun 30, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
'Yellow Wire - Stereo Connection???'
Yellow wire connects to the music mute wire on the back of the car stereo (usually brown). This will mute the stereo when the hands free is in use!
May 28, 2009 | Sony -Ericsson OEM HCB-300 Bluetooth...
CK-7w mutes stereo
if cutting the power to the kit dont work try removing the radio and removing the yellow wire from the back for the radio (the one coming from the junction box of the kit). that should get the radio/cd working properly. inspect the wire and make sure its not earthing anywhere behind the dash. radio isnt realy that easy to take out if you dont know what your doing.
Mar 04, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Dvd player
before yo take out the radio make sure you don't have to have a code for it and when you take it out if any wires need to be added make sure you get an additional wire connector for your harness don't let anyone cut your wires with the wire connector they can connect the wires for your bluetooh car kit without causing problems make sure they read the instrutions that com with the additional wire connector just go to a audio shop atell them you want a connector for your harness to connect a radio to your car and the back of your radio if you are not replacing the one thats in your car
Oct 19, 2008 | 2006 Toyota Camry
Installation of Parrot hands free car kit - bluetooth
In the parrot kits I've seen, they insert a relay to switch the audio to the phone. This only works with 2 speakers generally. Your vehicle either has dedicated amp channels for each of the 3 speakers/door or the installer tapped into the wrong point. If it has individual amps for each speaker, they may need to force the amp to shut off to get it to mute the audio.
May 13, 2008 | Car Audio & Video
BLUETOOTH Car Kit Type No. BTHCK 100
Connect the fuse kit's GREEN Ignition Sense wire (3 amp fuse - switched) to an ignition switched location on the fuse block. When the ignition is off the sense line is low.
Connect the ORANGE entertainment mute wire to the vehicle's entertainment system. (that is if your stereo supports it)
Connect the RED Positive primary lead to a 4-10 amp fused connection
Connect the BLACK ground wire to the vehicle chassis.
YELLOW & BLUE are not used.
Oct 22, 2007 | Motorola Mobility Bluetooth??¢ HF850 Car...
Car Audio & Video Logo
199 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
