Question about Hyundai HLT-3272 32 in. LCD Television
Loud hissing sound from tv
There is a loud hissing sound from my Hyundai tv. It is especially noticeable when I turn off the tv via the remote control. The only way to stop the noise is to actually push the off button on the tv itself.
3 Suggested Answers
  • 4 Answers
SOURCE: remote code
hi
google the tv make hp4240
cost £12 for remote
just like the real thing
martin
Posted on Mar 15, 2008
ekcnoel
  • 998 Answers
SOURCE: LG TV 32H3300 - volume
The cause of the problem is that the switch of your tv is dirty when cleaning it you must be familiar to the unit and the parts you will remove to prevent any damage you can use a contact cleaner, when applying a contact cleaner you must only spray it to the switch. Consult a expert technician to do it for you actual.
Posted on May 15, 2011
Hissing sound and then the car stalls
Was it a snake or a flat tire? The suspense is killing me.
25448532-xipalmoknr3fbjmp51kycajc-2-0.jpg or
Feb 19, 2015 | 2005 Hyundai Accent
42PFL9900D/10 Philips LCD Television Hissing Speakers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Televison & Video
LCD Television Philips 42PFL9900D/10 Hissing Speakers
Turned the tv on in the afternoon sound not working nothing I tried would give it any sound, turning the volume up just made a loud hiss.
Several possibilities.
I am assuming that you have no stereo system hooked up to your TV. In the event you do, then go to menu on TV and make sure your TV speakers are off.
Did you hit the mute button on your remote by accident? Need more info on brand of TV and what you have in the way of inputs to your TV. cable? DVD? HDMI? With limited info, cant do much for you but good luck.
Jun 19, 2011 | Televison & Video
I have a problem with hiss coming from the sound bar (ZBase 550 HSD) when using my digital cable box. It is not an issue with PS3 etc. I have the sound on the cable box turned to max, but I still hear a...
Hello ZVOX Owner,
The hiss you hear is generated by the analog audio output of the cable box. The best way to eliminate this hiss to use the digital output of the cable box. The preferred way to do this is to connect the digital audio output of both your cable box and your PS3 to the your TV (I presume your TV has two digital audio inputs.)
Your TV has a digital audio output. You should connect the digital audio output of your TV to the digital input of the ZVOX.
This should reduce or eliminate the hiss and provide convenient video source selection via the TV.
From Fred P. at www.zvoxaudio.com
fred@zvoxaudio.com
Jan 27, 2011 | ZVOX ZBase 550 HSD Lowprofile SoundBase...
Hissing sound coming from speakers
I found out that if I manually turn the speakers down on the tv and then turn it up with the remote control the hissing sound goes away
Mar 18, 2009 | Toshiba 65HDX82 65" Rear Projection...
My polaroid has sound and picture problems
This is a well-known problem with many Polaroid FP displays. Eventually, the picture will simply go black, rendering the TV useless. The solution is a new control board, ~$400.
Feb 27, 2009 | Polaroid FLM-4201 42 in. LCD Television
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
Loud hissing through rear (souround sound) speakers
I have the Sony Bravia KDL-46S4100. The high-picthed hiss drives me insane. I have a work around but not a fix. Go into your TV's menu and find BACKLIGHT. Adjust it from 1-9 with the house quiet and find what frequency of the hiss is the least annoying.
Sony Bravia high pitch hiss hissing sound high frequency
Nov 22, 2008 | Audio Players & Recorders
Sony kp-41s3u 50" hissing sound
sounds like high voltage arcing,caution
Oct 28, 2007 | Sony KP-41T65 41" Rear Projection...
Hyundai HLT-3272 32 in. LCD Television Logo
601 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
