Question about Lexmark X3550 All-In-One Printer
I cannot Scan onto my computer
I had to turn the computer off because it jammed and it would not let me do anything so I switched it off at the power point as it was the only thing I could do. When I switched the computer off I forget to check if the printer was on and I think it must have been on
when I switched the computer back on I can't access Scanning to the Computer, I get a message 'cannot retrieve application list' can I fix this and could you tell me what to do.
  • 58 Answers
Hi..there...i try to help you still have the cd driver of Lexmark X3550?..if you have... lets try to uninstall the old driver of your printer from your can clik : start menu---control panel ---add/remove program---find lexmark--remove it..after that unplug this printer from pc and turn off it.
restart your pc--after wntering the desktop insert the cd drive ..and start reinstall again...meanwhile turn on your printer but do not connect it to your pc until installation setup ask for it.. if everything ok windows will confirm find new hardware clik cancel let the insallation setup finished.
but if you don't have driver this printer you must download it at lexmark webside..chose support/download...find your printer it and install it to your PC...good luck...
Posted on Feb 03, 2009
  • 679 Answers
You install the printer driver again and then restart your computer.
and let me know for further assistance.
  • rockfixya
    rockfixya Feb 03, 2009
    download your printer driver from the link>>
    Thanks for using FixYa.
Fellowes Paper Shredder PS-79Ci power switch not working -- will not turn on!
Have you looked at the shredder blade to see if anything is still there? Turn power off, check shredder blade, clear anything stuck, put back together, turn power on and try again.
Mar 05, 2014 | Fellowes Office Equipment & Supplies
For some reason, my Epson scanner will not scan.I have checked all connections and they are fine. When I press the button to scan, notthing happens. I used thr printer this morning and it mis working fine....
have you tried scanning from the computer application... If you are running windows, try and initiate the scan using the windows Document imaging software that comes within the office package. post back for a followup.
Jul 16, 2010 | Epson Office Equipment & Supplies
Trying to scan, but keeps on saying "USB not connected"
I also frequently have this problem with my C6200, definitely the first and last time I buy anything from HP.
Anyways, onto you're problem: I've always found what fixes this is to simply turn your printer off and then back on. I also noticed that whenever you turn off or reset or log off your computer the printer can never locate the computer to scan to. I still haven't found that fix, but what I told you about turning the printer on and off should fix your problem.
Mar 01, 2010 | HP Photosmart C4280 Aio Printer
Screen says paper jam, can't find anything
close properly your paper jam cover at the back of your printer down side. if not clean and check the sensor for paper jam.
May 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to Scan a Picture onto the Computer
turn the printer on, place the picture on the glass, on the printer under mode press the big silver button until the scan light comes on  then press select, you should hear the picture scanning, then on the computer, go under my pictures and you should see that picture.
Apr 16, 2009 | Lexmark P4350 All-In-One InkJet Printer
I moved my computer and lexmark3470 to another room. suddenly i hook it back up [ports work fine} the three buttons on the left won't move up and down, and the printer keeps saying theres a computer jam...
If it shows false paper jam error try these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Thinkpad T40 operating system failure/won't boot
Check your RAM, reseat them, if you have RAM in both slots, swap them around. If possibe test them in another computer.
Nov 29, 2008 | IBM ThinkPad T40 2373 Notebook
"Paper Jammed"
Yes I have the same problem :-( I have lots of work to do!!
Apr 13, 2008 | Canon PIXMA MP170 All-In-One InkJet...
My PC computer
freezing cause by sever virus infection and Hard drive error, if virus infection, virus can be eliminated but the system become slower, and if the hard drive error (bad sector) sometime can be resolve but most of that error HDD put to the bin.
anyway, if this cause by virus infection then, boot your computer in "safe mode with network " option by pressing "F8" at first start and then scan your computer for viruses, you can use online scanning here:
if same issue occur, then better backup your files or save your picture in flash dive or any removable drive. and reformat and reinstall the windows operating system.
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Apr 09, 2008 | Computers & Internet
Lexmark X3550 All-In-One Printer Logo
99 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
