Question about Micro Focus Application Server (SXAPP10CUS)
Load error 173, error message text not found
The complete error message:
Load error : file 'GUWS001'
error code: 173, pc=0, call=1, seg=0
173 error message text not found
Unfortunately, the error does not appear when running the same application in a different machine
How to remove ask for genuine microsoft software
1. Restart your com­puter, hit F8 before win­dows load­ing screen to go into the safe mode menu.2. Select Safe mode (not with net­work­ing, and not with com­mand prompt)
3. Once your in win­dows, goto START>RUN> type "regedit" (with­out the qou­ta­tion marks) and hit ENTER.
4. Goto EDIT, select FIND
5. Search for wgatray.exe, delete any ref­er­ence found, (after it finds it the ini­tial first time, just hit F3 to con­tinue the search. Con­tinue to delete any­thing it stops on.
6. Scroll all the way back up inthe reg­istry edi­tor, and select My Com­puter (one click. not two) and start a new FIND, this time were look­ing for Wga­l­o­gon, again, delete any ref­er­ences found.
7. Lastly, again, click on My com­puter, and start a new FIND, search­ing for LegitCheckControl.dll , again delete any ref­er­ences found.
8. Reboot and your fin­ished, if not, you may have missed a reg­istry entry.
BTW you should be able to con­tinue to down­load Win­dows update (when set to auto­mat­i­cally down­load an install).
Aug 20, 2011 | Microsoft Windows XP Professional for PC
Hello i have a problem with my nokia 3110c whitch is : when i flash my phone with phoenix i got this result : Flashing started Creating product data items list Product data items list created Backup...
Now what is the condition of the phone ? If the phone has still problem, uninstall the previous file you have installed and re-install this one3110c file.Select the product code 0544311 or 0556977.This two files can use universal.Use fully charge battery or insert charger when message prompt.I hope there will be no error.Thanks good luck.
Aug 16, 2011 | Nokia N70 Cellular Phone
Memory file dump error, pc freezes
This is the issue with your RAM chip or Operating System .Pls replace the RAM chip with goods one and on the system .If still problem not resolved pls re-install the Operating System again.
Nov 17, 2009 | E-Machines eMachines Desktop PC
Dump file error, pc freezes
I would do a complete reinstall. It looks like you have really upset your pc. The kernal files are part of the main operating system and when they mess up its not good. As I said I would redo the pc..Sorry to say you will lose all personal files on pc..
Nov 17, 2009 | Lenovo 3000 N200 Notebook - Intel Celeron...
MadDog MD-16XDVD9 could not perform end of disc-at-once
Have you tried checking your basics ?
Firmware ?
ASPI ?
Disk Defrag ?
IDE location ?
Jumper settings ?
What type of media are you using ?
What programs are you using ?
Exactly where are you and what are you doing when your error occurs.
What are your PC's specs ?
Do you have any Roxio products installed on your PC ?
Please answer ALL of the above - if you don't know, say so, don't make something
Oct 20, 2009 | Computers & Internet
When I try and load programs like burning software or a new sound driver, I get the message "....exe is not a valid Win32 application." What can I do?
This error could be anything from cd/DVD needs clean, program corrupt, to viruses. If you can clean your player and re-install software and drivers your left with problems with the laser pick up in the cd/DVD, still program corrupt or viruses.
The likely problem is that the download did not complete properly. Please check the file size of the downloaded file against what is listed in the download. This often also results in a "Bad CRC" error. Both these errors can be fixed by making sure you have a complete download. Some users have found that being connected to their companies VPN can cause downloads to be slow and timeout, resulting in an incomplete download.
If you have received 0 kb files have found that disabling Norton Internet Security or other firewall on their computer has solved the problem.
Below, is a site that may help you.
www.computerhope.com/issues/ch000726.htm
Sep 28, 2009 | Dell OptiPlex GX280 PC Desktop
Cant get to my text messages or inbox folder..
back up your files first and do format or Full EEPROM RESET:
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK!
but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
Jul 25, 2009 | Samsung Blackjack SGH-I607 Smartphone
SQL Invalid cursor number 135 error
The error is being generated because you are trying to order on a value not in your selected fields e.g EFFECTIVE_DATE
You only have TRANSACTION_TYPE in your select statement
Sep 24, 2008 | Gupta Team Developer for PC
Image crop want to made in flash
could you give me more info plz
Jul 16, 2008 | Computers & Internet
Computers & Internet Logo
670 people viewed this question
Top Micro Focus Computers & Internet Experts
David Payne
David Payne
Are you a Micro Focus Computer and Internet Expert? Answer questions, earn points and help others
