Question about Sony Playstation 3 (PS3) Console
My ps3 will work on the rca hookups but not on the hdmi hookups
We were playing the ps3 we changed the input on the tv now the hdmi wont work for the ps3. i can get the rca cable to work but not the hdmi.
    Problem Solver:
  • 5 Answers
When you hooked up the HDMI did you go into display settings and change all the PS3 settings to HDMI instead of AVI? I thought my HDMI wasnt working, just a blank screen but I could hear the sound, then it hit me..... change the video and display settings to HDMI and poof, there was the pic. lol
Posted on Feb 06, 2009
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
I have an RCA home theatre...model rt2910. I have hooked my PS3 via HDMI to the TV for the video and used an optical cable for the audio. I set the PS3 to send video via HDMI and audio via optical cable....
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
Feb 28, 2011 | RCA RT2910 Theater System
In a hotel with a tv that only has coaxial input. bought a rf modulator video converter from rca to coaxial. Was running hdmi at home. current set up does not work? console should automatically switch to...
Unfortunately it does not automatically switch. Turn off the power to your PS3 and then turn it back on again. But when you turn it on, hold down the power button until you see something on the screen. When you hold down the power button of the PS3 when you are turning it on, it completely resets the video settings to the most basic settings (480p I think) so that it'll work on any TV or monitor. You can then configure the video settings to match the TV you are hooking up to. You'll have to do the same thing when you take it back to your original location.
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
AWe are attempting to play PS Three, but the Inputs on the front and back of tv for the RCA cables arent working. What should we do to make the inputs work?
change the input, i have the same configuration ps3 and 52 inch rca, just plug it into front and change the input to front, if that dont work try this, since your ps3 probably came off a tv that had hdmi you need to hold down the ps3 button for 9 seconds and it will ask you if you want to change it to lower settings, but first make sure you have the input right
Sep 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I changed my HDMI cables to get my PS3 to play
You need to set your HDMI, resolution down, on PS3 FIRST, using composite, or component hookup, to the TV FIRST, Turn OFF, but DO NOT select HDMI, leave it on, Composite, or Component, when finished setup the TV, the turn it off, leave off, Then connect up PS3, power on, NOW turn on the TV, select HDMI, Change PS3 to HDIM, now it should appear. Sometimes you have to "Reset" the TV, by tuning it on & off.
Apr 24, 2010 | Vizio L32 32 in. LCD HDTV
Ps3 won't transmit on tv, tv works ps3 is running, checked all cords
You need to check and make sure that you are trying to view the PS3's output on the proper channel or input on your TV. If you need to scroll through every channel and input.
If that doesn't work try replacing the A/V or HDMI cables. If it still doesn't work you may need to send it to Sony and have it replaced. The video output section of the console may be bad or not functioning correctly.
If you have a friend with a PS3 try to see if they will bring their's over and let you test it out. If their PS3 won't display then it's something wrong with the wires or the TV.
Dec 16, 2009 | Sony Playstation 3 (PS3) Console
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
314 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
