Question about Konica Minolta magicolor 2430 DL Laser Printer
Have to reboot system to print
I'm running VISTA with the current printer drivers, and when I go to print, the jobs will stay in the queue until I reboot my computer, then it will only print 1 job, and the others remain in the queue. Any advice would be appreciated.
  • clevans0612 Feb 03, 2009
    The cable works fine with my other computer with Windows XP, but when I plug it into the laptop the printer won't work.
  • 41 Answers
If the driver is properly installed you have to check or change the cable between the PC with printer..
Posted on Feb 03, 2009
Canon mx922 not printing word document from PC. Puts it into queue
How To Fix It - The fix is simple. You need to clear the print queue manually so that all the print jobs currently in the queue are deleted properly - once the queue is empty you should then be able to print new documents without problems. We will show you how below, depending on whether you use XP or Vista/7:
1. XP - click 'Start' then click 'Run' and in the Run window type CMD then press 'OK' - this opens a Command Prompt window. Now skip to Step 3.
2. Vista/7 - click 'Start' and type Command in the search box. Right click on the 'Command Prompt' result in the search results above it and select 'Run As Administrator' - this opens a Command Prompt window.
3. All version of Windows - in the Command Prompt window (these commands are also shown in the picture below):
4. Type net stop spooler then press the Enter key.
5. Type del %windir%\system32\spool\printers\*.* /q then press the Enter key (Note: the only spaces in this command are a single space between del and %, and a single space between * and /q)
6. Type net start spooler then press the Enter key.
7. Type exit then press the Enter key to exit the Command Prompt window.
Fixing the print queue
This should have cleared the print queue (i.e. all print jobs have been deleted) and you can now submit new jobs for printing
What Do These Commands Do?
The Command Prompt is a throwback to the pre-Windows days of Microsoft DOS but is still a useful way to type and enter system commands. The print Spooler is basically the print 'queue' - we need to Stop it running before we can Delete documents stuck in it.
The Del command deletes everything currently held in the print queue, including the 'stuck' document(s). We then have to Start the Spooler (print queue) up again so that it can accept new print job requests in future.
What If It Keeps Happening?
If the problem only occurs occasionally it is likely just due to an incompatibility with the actual data being printed ( a webpage that has unusual fonts or some other format that the printer is unable to convert into printed output - run the above fix to resolve it.)
However, if you find that almost all documents keep getting stuck in the print queue then Microsoft's answer is that it is an issue with your printer drivers (software) - one solution may be to download and update new printer drivers from the manufacturer. You could also try the Microsoft automatic Fix It for printers . This will repeat our fix above but may also flag up/fix any different Windows errors that stop printing.
Other causes may include a misconfigured printer e.g. network printing to an IP address that doesn't exist uninstalling and reinstalling the printer software from scratch should fix this.
Aug 19, 2017 | Canon Office Equipment & Supplies
Cannot get a driver to load off line. 64 bit windows7 no disk
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 964 Photo All-In-One Printer owners thread (W7)
Rick
Aug 14, 2011 | Dell Photo 964 All-In-One InkJet Printer
HP LaserJet P1005 Print Queue won't cancel or restart. I've turned printer on/off, opened and reclosed lid, paused and resumed, everything but what I fear I'm going to have to do and that is reboot my...
If you've ever had a print job hang, you're probably familiar with the Windows Print Spooler window. You get to this window simply by selecting the relevant printer from the Control Panel's Printers and Faxes applet (simply Printers in Vista). In the somewhat unusual event of a printer queue jam, you can go to the Print Spooler and simply delete the job. Sometimes, though, the system won't let you cut off print jobs that way: It marks the job "Deleting..." but never quite gets there, and you end up rebooting. But there's an easier way.
Open a command prompt (go to Start ' Run, then type cmd) and enter the following:
net stop spooler
del c:\windows\system32\spool\printers\*.shd
del c:\windows\system32\spool\printers\*.spl
net start spooler
In Vista you'll need to open an elevated command prompt by right-clicking on cmd.exe and selecting Run as Administrator. For those of you who remember batch files, use Notepad to save the four commands above as a batch file. I've named mine Killqueue.bat.
Jan 07, 2011 | HP Office Equipment & Supplies
I need to clean the print queue once this
net stop spooler
net start spooler
Jan 05, 2011 | Epson Printer
A print job queue is preventing other print jobs from printing
a print job in the print queue is preventing other print jobs from fixed printing
Dec 30, 2010 | Costar DYMO DiscPainter Printer
The print operation hangs in the print queue
net stop spooler
net start spooler
Dec 18, 2010 | HP Photosmart Premium C309g multifunction...
Can't print a cd on epson stylus 1400. The printing queue says paused.
right click on the print job in the queue, and click "restart". Other wise try this:
net stop spooler
net start spooler
Dec 14, 2010 | Epson Stylus 1400 InkJet Photo Printer
Print jobs are stuck in the queue I have windows 2010
net stop spooler
net start spooler
Dec 10, 2010 | Dell Photo 964 All-In-One InkJet Printer
Print Job enter's queue, but doesn't actually print.
hi thanks for using fixya!
Do you have 32bit or 64bit system?
Mar 24, 2009 | HP LaserJet 4250n Printer
Printer hangs up.
1. check the printer, make a copy
2. check connectivity, open device manager - USB Printing Support(under Universal Serial Bus Controllers) must be there - swap cable/port if it´s not
3. uninstall, reboot then re install printer driver
Jan 03, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Konica Minolta magicolor 2430 DL Laser Printer Logo
127 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
