Question about Euro-Pro 1260DX Mechanical Sewing Machine
Foot pedal does not work.
The machine has power but the foot pedal does not work
    Scholar:
  • 69 Answers
If you are getting power and not sewing, it sounds like a bad foot control. (you don't need the entire power cord assembly). These are fairly easy to replace and can be found in most local sewing shops or places like ebay. To replace it your self, simply remove the old one and get a carbon style controller, slide the wires through the hole in the side and connect one wire to each screw, it does not matter which wire goes to which screw. Put the bottom cover back on and you should be good to go.
Posted on Feb 07, 2009
dupina
  • 110 Answers
SOURCE: Husqvarna Viking #1 use same foot pedal as the #1+ ???
Yes it will work, you can go ahead and purchase it.
Posted on Jan 22, 2008
  • 192 Answers
SOURCE: foot pedal dead, machine keeps sewing!
There is no suppressor in the foot control of a 425. Only the control unit, which may need to be replaced. If the machine accelerates to full speed, it may have a problem with the "stop right" board which tells the machine whether to stop with the needle up.
You could have several problems, so go see a qualified Husqvarna repairman. You may contact Husqvarna customer service to locate the best one in your area.
Posted on Apr 08, 2008
  • 13 Answers
SOURCE: Bernina Activa 135 foot pedal problem
If you can get acess to or borrow another foot pedal to try I would do this first any of the Activa, Artista range fit to try. The fault may not be in the foot pedal but in the main CB of the machine. This can give a fualt of lights on but no motor drive. In this case the board would need replacing by a technician. Hope this may help.
Posted on Jun 23, 2008
SOURCE: My Viking 5710 starts to sew without any pressure on foot pedal
Mine does the exact same thing. I think the problem might lie in the cord to the foot pedal. The cord packs into the foot pedal for storage, which forces the cord to to remain bent during storage. I believe the wires in mind became damaged and broken so I took it apart and reconnected the wires at the spot where the connector meets with the wires. But I still don't leave it plugged in if I'm not using it, it could be a fire hazard.
Posted on Mar 24, 2010
  • 22 Answers
SOURCE: Foot pedal not working on bernina 1030 but there
The problem with you bernina is coming from the circuit board located on the back of the machine, there ar e a couple of fuses you might want to replace, if you change out the fuses and still no power the board will need to rebuilt aprox cost$150.00
Posted on May 03, 2010
The foot paddle doesn't work; machine won't turn on. Help.
If the machine does not turn on, it is likely the foot pedal is not the problem. The foot pedal will not work unless there is power to the machine. Probably should take it for service.
Nov 26, 2017 | Sewing Machines
Pressing foot pedal and work work
check that the power lead is in properly
have the foot pedal tested for operation
have the machine serviced and the motor checked for operation
(brushes and bushes)
Jun 30, 2015 | Sewing Machines
Why does the foot peddle get hot?
Many sewing machine foot pedals are little more than a variable resistor. To run the motor at a slower speed much of the input power is wasted in the foot pedal in order to allow the motor to run slower. That wasted power comes out of the foot pedal as heat.
Newer foot controls are electronic and don't get hot.
Electronic vs Mechanical Sewing Machine Pedal
Aug 27, 2014 | Sewing Machines
My Brother Project Runway sewing machine's foot pedal is not working. No power. Is there a solution?
you can take the sewing machine and foot pedal to a repair shop and have them check the foot pedal and they can tell you if you need a new foot pedal or if that one can be fixed.
Aug 09, 2013 | Brother Ls2250prw Project Runway...
Foot pedal doesn't work
well if the foot pedal isn't working, you can either replace it with a new one or take the machine to a sewing machine repair shop & let them check the foot pedal & see if it's fixable
Mar 14, 2012 | Husqvarna Sewing Machines
You may need a new foot pedal. Find a small applicance repair shop and ask them if they can test the pedal. Take the machine with you.
Mar 09, 2010 | Husqvarna Designer I
My unit has no power to foot pedal. What are possible fixes?
change the power chord of your pedal, if not, open the pedal and look for the connection if that is cut or loose try to tight or connect it.
Oct 17, 2008 | Brother LS-2125 Mechanical Sewing Machine
Foot pedal dead, machine keeps sewing!
Mar 12, 2008 | Husqvarna Freesia 425
Euro-Pro 1260DX Mechanical Sewing Machine Logo
307 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
