Question about LG KU990 Viewty
The battery backup is very low
The battery third signal is good but the remaining two escapes in a few minutes.
  • 79 Answers
Looks like either the devices connected to the backup battery are consuming too much power than that backup can handle or the backup battery is getting worn-off. You may need to change the batteries or take-off some load (remove some devices that consume power) from the backup battery.
Posted on Feb 03, 2009
Hitachi TV freezes aft viewing for few minutes. Can turn off n back on for few min then freezes again
before doing any thing check signal level,if it is low this can cause picture to pixlate or freese to test use a dvd player as a signal source ,if it plays fine its low signal level to tuner good luck, butler
Oct 02, 2016 | Hitachi Televison & Video
Invertomatic victron imv ups
Malfunction of input circuit: voltage delivered is too low. The batteries may
be faulty or depleted. Wait for a few hours, leave the UPS switched on
If absence of input power (utility failure, maintenance work) is expected to last longer than a few hours, switch
off the UPS to save battery power. If the UPS input power is absent for several days and the UPS remains on
under no-load conditions, the batteries can be discharged very deeply, resulting in a short battery life time
Apr 22, 2014 | Computers & Internet
2001 Ford Escape, Cleaned the battery posts and reconnected. Car wont start after reconnection. Checked cables for disconnects, terminals for tightness, etc... everything is fine there. Car started about...
It sounds like th ebattery has failed with high internal resistance. Get a voltmeter (or multimeter in dc volts mode) and measure across the battery while trying to crank. It should remain near 12 volts, possibly drop to 11 or so while cranking if low charge, but a failed battery will drop to very low voltage. With no load, it may stay high enough to run small items like the fuel pump. You could also check the negative lead where it attaches to the engine and clean its connection. The voltage will give you a clue, if it stays around 12V then the problem is in the wiring somewhere.
Oct 23, 2010 | Cars & Trucks
I have a 2002 Ford Escape V6. When I first had the car in 2006 the battery light would come on when I would start the car and would stay on for approx.10 mins. My car would always need jump starts. I...
The battery light usually comes on when the alternator is not putting out sufficient voltage equal to or above the battery voltage. Sometimes the alternator can be generating enough voltage to make the light go out but not enough current to recharge the battery properly especially when driving at night with lights etc on. Eventually the battery will not have enough charge left to start the engine. The most common cause of low output is worn brushes but your description tends to suggest that the electronic regulator inside the alternator has an intermittent fault. An auto electrician will be able to diagnose the problem fairly quickly and probably offer to fit an echange unit.
Sep 13, 2010 | 2002 Ford Escape
Short backup time
Suspect battery failure/faulty cell in a batt
Remove batts and check outside unit
charge up to around 2.27V/cell then check discharge on each batt (12V car lamp is good dummy load)
faulty one will be obvious.
MAKE SURE YOU ARE VERY CAREFUL WITH BATTERIES, THEY ARE VERY DANGEROUS, AND ALWAYS LIVE!
Check you manual for safety procedures, BEFORE working on Batteries.
hope this helps
thanks for using Fixya
Jul 06, 2010 | Powerware 9120 UPS System
Why my battery status says 1hr 30 minutes remaining only to say next minute that i have 5hr remaining, than it says 3 hr, only to say i have 4hr 28 minutes remaining?
90% of the reason is that ,depending on the working condition the backup of battery varies . What I mean is , if you are running a software which need high resources (example nfs games) then back up reduces and on the other hand if you are running a simple program like ms word ,paint etc maximum backup.
Hope you get the answer.
Mar 11, 2010 | Dell Latitude D620 Notebook
05 ford escape wont start. jump started it and it started fine but only runned for a few minutes and the engine started to stall and went off. tried to start it again and it wont turn with the same...
okay try this....talk to your parts store and get a battery load tester, and find out if the battery is indeed dead. My guess is it sounds like the Altenator is dying. they are around 50-100 and can be install by a pro in minutes.
Jun 16, 2009 | 2005 Ford Escape
LG KU990 Viewty Logo
229 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
