Question about Pioneer DVR-520H DVD Recorder
Need replacement remote for pioneer dvr-520h
5 Suggested Answers
SOURCE:
SOURCE: Pioneer DVR-520H DVD Recorder Picture is Yellow
If running component or RGB try replacement lead set. Otherwise is TV issue.
Posted on Jul 03, 2008
SOURCE: pioneer 520h dvdrecorder need to replace
ok
if it was that easy i wouldnt post
repacement burner $780 plus $100 labour from pioneer australia
dvr115 i replced it with comes up with error code on 520h
needs a service remote etc apparently to configure
looking for advice not a gratuitous comment about how to shop
Posted on Sep 30, 2008
SOURCE: Pioneer DVR-225 Set Up Code?
I believe it is one of these three:
021, 013 or 048
Posted on Mar 15, 2010
SOURCE: Need remote code to use a universal remont on my
hello, your DVD did come with a manual I guess.Talking about universal remote,I think it comes with a manual.You can request for a new universal remote control with a manual that contains the code of the device you are using.If not you could also buy the appropriate remote control for your device at an electronic store where they sell elect products, or better still, buy the remote from the place you bought your device. if you experience anymore problems operating your device pls feel free to let me know.
Thanks.
Posted on Apr 26, 2010
Where to purchase new or vg cond used remote.
If I need a Pioneer remote for a hard Disc Video Recorder I look at ebay first then the on line major remote suppliers. You can often get a good remote for $20-$35 at eBay the replacement places want $150 for not to mention many of the replacement remotes for older offered units are some sort of replacement unit which does not work as well as the real thing.
I'm in the process of repairing a Pioneer DVD Recorder remote it is done by removing five screws (including three hidden under the battery compartment cover) gentily separating the unit and taking out the soft pad. The contacts on the bottom of the pad were coated with conductive material so when you push the button the circuit is completed. Over time this material wears off so you have to push harder and harder and finally it does not work.
You can buy conductive paint on eBay and clean and repaint the bottom of the contacts which fixes this most of the time. Your fault may be a bad board in the remote but more often it is just the lack of a conductive coating on the bottom contact area of the button.
If you can't find the remote you need try to fix yours as I have noted it is worth the hassle. I recently found a remote for an arcane Sony MD Recorder for $2 at esale I balked at paying $65 for on ebay so if you are patient an live in a metro area with a lot of people donating to resale this might be another possiblity.
I hope this helps you...
Jul 19, 2013 | Pioneer DVR-520H DVD Recorder
Power supply unit failure
It could be the IC101 (MR2920) and the zener D104 both failed, or IC1 (MD5001T) failed as well, here is the link where I've descrived how I fix the issue on my DVR-520H, it is in italian but you can translate it with Google: http://www.plcforum.it/f/topic/181344-riparazione-guasto-alimentatore-pioneer-dvr-520h-dvr-520h-failure/
Feb 08, 2013 | Pioneer DVR-520H DVD Recorder
Looking for a manual free of charge for DVR-520 H. Where to find?
Hello
Get into this site where you can get its user manual for free download. If you fail to do it, either send your email address by fixya of send a mail to me at [email protected]. I've the manual in pdf format, and will send it to you by return mail. OK.
www.pioneerelectronics.com/.../Manuals/ci.OPERATING+INSTRUCTIONS+ DVR-520H.Protected - United States
Ok.
May 18, 2011 | Pioneer DVR-520H DVD Recorder
My Pioneer DVR-520H DVD Player works fine but sometimes when it is powered off the power just goes completely. When this happens I plug it into a different socket or just pull out the power cable from the...
It seems problem with power supply board in Pioneer DVR-520H, possible causes for that symptoms are few dried up/ leaky capacitors, cold/ dry solder joints on circuit board or chip resistors would be devalued.
Local repair shop will help you to replace bad capacitors, chip resistors in power supply board to solve this issue if you are not familiar with soldering work in circuit board.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 11, 2011 | Televison & Video
Power off after recording
Hi All,
This is a power supply problem.... the MR2920 stanby IC miss behaved, it power off and fail to power back on.
Solution, get pioneer power supply replacement or take the dvd recorder to your local electronic service repair to take a look at the power supply circuit.
Best of luck
Kenny
Apr 21, 2009 | Pioneer DVR-520H DVD Recorder
No power
Something inside is loose, so it's time to buy a flat panel tv or spend $50 to get it repaired.
Oct 17, 2008 | Pioneer DVR-520H DVD Recorder
Pioneer 520h dvdrecorder need to replace dvd burner
ok
Sep 30, 2008 | Pioneer Televison & Video
DVD shelf won't open
You know you can place a paperclip in the hole next to the DVD drive to release the door. Never just pull on the tray when it is all the way closed. Once the door is part way open you can gently pull it out the rest of the way. This will not fix anything, it just allows you to open the tray once.
Jul 17, 2008 | Pioneer DVR-520H DVD Recorder
Oct 12, 2007 | Pioneer DVR-520H DVD Recorder
Pioneer DVD Recorder - can get picture but no sound
If you are using RCA cables, you need to hook up three cables (1) yellow video, (2) white - left audio, (3) red - right audio.
May 28, 2007 | Pioneer DVR-520H DVD Recorder
Pioneer DVR-520H DVD Recorder Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
