Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Networking In Windows XP, if IP address is known, one can create a shortcut. How to go about it in Vista? Pls help
  • 271 Answers
Control panel > view network and internet > network sharing center > manage network connection
Posted on Feb 03, 2009
Trying to open port 3389 in my firewall. Set for UDP and TCP but the tester program still says that they are closed. I have disabled windows firewall. Still no luck.
Make sure you are doing this for the right ip address. The ip address should be your local computer's ip address and will probably look like 192.168.1.x . To get to this go into your network control panel and click on your connection and view the details to get this information. Remember that every time your router resets this ip could change. I would suggest setting a static ip in either the router or on your computer in question. To set up a static IP for windows xp: For windows Vista: For windows 7:
May 13, 2011 | Belkin F5D8236-4 Router
How can i administrate a cajun p115g because it dosn´t have a console port?
open up internet exploer on any machine and type ip address into the url bar the default is usually but yours maybe different to know your ip address open up your command prompt and type in ipconfig
to open your command prompt in windows xp click run from the start menu and type in cmd
if it is Vista then type cmd in the search and choose the first option
Oct 21, 2009 | Lucent Cajun P115G (108360850) Networking...
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default DNS server address type the default gateway in primary DNS and in secondary your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
Vista cannot connect to xp printer
It sounds like your are using your Windows XP computer as the print server, and you are trying to connect your Windows Vista machine to the Windows XP print server. Your Vista machine is trying to download the XP drivers from the Windows XP computer to your Vista machine. This won't work. Windows XP and Vista print drivers are not compatible.
If the printer is truely networked (it has it's own IP address on the network, it has its own ethernet connection). Then instead of trying to map out to this shared printer, add new printer to the Vista machine using Vista drivers for the HP Deskjet 3940. The type of port you would need is a standard TCP/IP port. To get this address, print a settings page from the printer. Look for either a TCP/IP address or IP address on this print out. This is the port address you want to create and then connect to.
May 04, 2009 | HP Computers & Internet
How to share internet connection on Windows Vista OS. I want to share internet connection between two Laptops using Windows Vista Operating system and the other using Windows XP. The Host computer is...
All right let's call your Vista computer A and your Xp computer B. First you have to bring the two computers into LAN. If you already did this, please skip the next eight steps.
Step 1: In Vista, before doing this you should enable Sharing and Discovery. You can do that by going to Control Panel -> Network and Sharing Center. Under the section ‘Sharing and Discovery, enable Network discovery, File Sharing, Public folder sharing and others if you want to. (See picture below)
Step 2: If your LAN card that is connecting to another computer is installed, it will be shown under Control Panel -> Network Connections.
Step 3: Right click that local area connection and click properties.
Step 4: Under the tab ‘Networking’, click the properties Internet Protocol Version 4 (TCP/IPv4).
Step 5: Click the radio button to ‘Use the following IP’ and give an IP address (For example, IP address: and Subnet Mask:
Step 6: Don’t give any other information, Click Ok and close everything.
Step 7: In computer B, which is the XP, make sure you enable the LAN card which is used to connect to computer ‘A’. Here you need not give any IP information as Computer ‘A’ will assign an IP address dynamically. If it’s not working make sure there are no IP assigned and change the properties to ‘Obtain an IP address automatically’.
Step 8: Test the connection by pinging. (You can do this by typing ping or whichever is Compter ‘A’s IP in the comand prompt)
NOW your computers are connected. Now to share the internet:
Right click LAN card which is connected to Internet under Control Panel -> Network Connections and click ‘Sharing’ tab and enable both the options to share Internet. (Note: Unless there is another enabled LAN setting you will not be able to see the shared tab under properties)
Click Ok and close. This option is given by the Windows OS known as ICS (Internet Connection Sharing).
Now you can use Internet from both Computer A and Computer B from a single connection.
So this is the setup you need on the Host computer as you requested, if you turn out to need help witht he XP one too, let me know:)
Feb 14, 2009 | Compaq Presario 700 470024-192 Notebook
Doesn't work with windows vista
1. check if there are lights on the specific router port where you have connected the Vista (e.g. if it is on port 2, check if there are lights on #2 at the front panel of the router).
2. check the ip address by going to command prompt (click start-run-type cmd press enter. on the command prompt, type ipconfig/all)
3. ip address should be similar to what your Windows XP is getting. Subnet mask, gateway, and DNS servers should be identical.
Eg. If XP has a IP, your Vista should have 192.168.1.x IP address where x is a variable number other than 100.
4. If your IP address, subnet mask, default gateway, and DNS seems aligned for both PCs, check your browser settings. Open IE, go to tools, internet options, network connection and make sure that never dial a connection is selected.
Jan 16, 2009 | Microsoft Broadband Networking MN-500...
How to connect a laptop having vista home basic with a xp desktop
Be advised that,
it makes not different to connect one PC/Laptop to another one via LAN because when you connect your system in lan networking you system will be automatically detected if LAN has been set up through a server.
And if not you need to do manually by assigning ID address on bot PC/Laptop.
For that,
first assign an IP address in either Laptop or desktop (IP address must be same category)
ex. (first one)
and second one should be you can up (instead of 231) any number excep 0 but make sure not confliction between other system. means not duplication IP address on same LAN.
once you ae done with IP assigning
Go to
Star>Run>command and hit enter
once you see command prompt then
type there:
ipconfig and hit enter (it shows your ip address) if you wanna have more info then type ipconfig/all
once you are done with this then
you need to ping to your next PC.
for that
type in
ping (means you need to type another PC's IP address here)
and hit etner
if you see like on image
then you are good to go.
Thank you
and rate all answers.
Jan 02, 2009 | Microsoft Windows Vista Home Premium with...
Windows Visa slow Internet speed with WRT54G version 8
A possible solution that could address both the slow Vista and the static IP:
  • Pls go to Start, Control Panel, Network Connections;
  • Right click on your Local Area networking and click on properties;
  • Highlight Internet Protocol (TCP/IP) and then click on the Properties button;
  • Tick on "Use the following IP address;
  • Enter IP address >;
  • Enter Subnet mask >;
  • Default gateway >;
  • The DNS would be what your ISP has set;
  • OK, close.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Linksys Wireless-G WRT54G Router
Netwoking problem
computer names as to be same workgroups either windows XP or Vista & ip segment as to be same.........
Jul 02, 2008 | Compaq Netelligent 3612 (267007-001)...
Internet sharing
Hi, Could be done. On the Dell XP - 1. Activate your Internet Connection Sharing. Go to Control Panel, Click on Network Connections, right click on your Local Area Connection, Properties, Advanced tab, check Allow other network users to connect through this computer's internet connection. In Home networking connection, choose "Local Area Connection", OK; 2. Back to General settings, click on Internet Protocol (TCP/IP), click on Properties, tick Use the following IP address: IP address, Subnet mask, Default gateway, if you know ITT DNS use them otherwise tick "Obtain DNS server address automatically." You have to connect the DellXP with the DellVista using a crossover networking cable. On the Dell Vista- 1. In your Network Connections, right click on your Local Area Connection, Properties, click on Internet Protocol (TCP/IP), click on Properties, tick Use the following IP address: IP address, Subnet mask, Default gateway, if you know ITT DNS use them otherwise tick "Obtain DNS server address automatically." The above method will also work with peer to peer wireless networking. It might also facilitate connection if you enable auto-detect proxy settings in your browser. There are other methods. This is also better explained at Microsoft support Hope this be of help/idea. Post back how things turns up or should you need additional information. Good luck and kind regards.
Sep 30, 2007 | Computers & Internet
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
32 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
