Question about HP Officejet 4355 All-In-One InkJet Printer
My printer is disconnected...how do i connect it
How to connect printer
I have not installed the CD due to misplace.I can not print.
Posted on Feb 05, 2009
Loss of power when printing
  1. Is the printer off?
    Press the I on the power switch to turn the printer on.
  2. Is the power cord loose or disconnected?Turn the printer off and connect the power cord properly. Turn the printer on again.
  3. Is the printer connected to a correctly rated outlet/socket?Connect the printer to an AC power outlet/socket that you know works. Do not connect any other equipment to the outlet/socket. Do not connect the printer to an auxiliary power outlet on the back of a computer.
  4. Is the printer defective?Turn the printer off immediately, disconnect the power cord from the outlet/socket, and contact your dealer or Brother Customer Service.
    Still having Problem Then follow Us For
Brother Printer Support
Mar 23, 2014 | Brother MFC Office Equipment & Supplies
I printed from a camera and can't get printer to turn on now. I've tried all steps up to stopping print-spooler and restarting and I think I'm not tech -savy enough to go on.
Please try below, it could help you tio fix the issue.
Solution 1: Power Drain
  1. Make sure printer is OFF.
  2. Disconnect the printer power cable/ Camera and PC usb cable.
  3. Disconnect the power cable from wall outlet.
  4. Press and hold the power button for 30 seconds.
  5. Connect the printer power cable and turn ON.
Solution 2: Printer Reset
  1. Take the ink cartridges out.
  2. Disconnect all the cables connected to printer.
  3. Press and hold "OK" and "CANCEL" button at same time.
  4. While holding the button connect the power cable and continue holding the buttons
  5. The printer displays "NVM reset" , then release the buttons. (Printer might turn itself down, don't worry just power ON it back.)
  6. Insert the cartridges when you see printer displaying "Missing Ink catridges".
Regards
Riztech
If this solution is helpful,kindly vote 'thumbs up' and write testimonial feedback.
Jan 04, 2011 | HP Photosmart 3210 Printer
Printer was stuck in "offline" mode, so deleted it
This is not Printer or PC USB port issue.
You need to drain the power from PC.
Follow these steps to resolve the issue
1. Disconnect the printer power cord from walljack or surge protector
2. Disconnect the USB cable of printer from PC or vice versa
3. Power off your PC, Disconnect the power cord from wall jack
4. Wait for 5-10 mins
5. Connect the PC power cord and power on the PC and wait till you are able to login to your PC
6. Connect the Printer power cord
7. Connect the USB cable to PC or vice versa you disconnected.
This should resolve the issue.
Oct 29, 2010 | HP DeskJet 5150 InkJet Printer
I keep getting a 'Phone off the hook' message. Phone is not off the hook
Disconnect the power cord from back of the printer ( while printer is power on )
While holding the # and 6 key connect the cord back
( This step will erase all the fax logs and settings you have set on the printer )
Also
Press the Setup button and Scroll to FAX SETTINGS ( or ADVANCED FAX SETTINGS )
Check for ECM ( Error correction mode ) - Press OK
Turn it OFF
Finally if the issue is still not resolved,
Disconnect the Phone cord from Printer port and re-connect
Check for any other loose connections ( of phone socket ) within the house. ( disconnect and reconnect )
The Error message should go off
Oct 12, 2010 | HP OfficeJet 4315 All-In-One InkJet...
Cant get my computer to recognize my printer hp deskjet 3930
Hi and Welcome to Fixyah,
I would suggest to you to disconnect your HP printer and then connect to another usb port. Another one thing is disconnect and then install the driver then after that is connect your printer check if computer detect your device. Make sure that there is a new hardware found.
Regards,
Mar 29, 2010 | HP DeskJet 3930 InkJet Printer
Computer tell me that my printer is not hook up
If its a USB printer, uninstall the software and disconnect the printer. Then reinstall software while printer is disconnected. The software will instruct you on when to connect the printer or just wait until the software is finished installing then connect the printer.
Apr 20, 2009 | Lexmark Z35 Printer
Lexmark x8350
In the back of the printer is an access panel with one screw to hold it in place.
The outer side edges are held in place with it plastic tabs (which you can not see due to they are inside the printer. So carefully remove this panel without breaking the tabs. Look inside and you will see a ribbon connecting to a circuit board. This is probably loose or disconnected. The end of the ribbon is hard and not flexible. Push the end of this ribbon in the white plastic standoff slot. This ribbon sometimes comes loose when the top scanner cover is partially remove from the printer. I said, partially because if you needed to remove the top scanner completely, then this ribbon would need to be completely disconnected. You can also see, when the access panel is off, other wire connections connected to this circuit panel. Sometimes they also come loose or disconnect when the top scanner is partially remove. Connect them if they are loose or disconnected. I believe to solve your problem is the ribbon disconnected. Best wishes in solving your problem.
Sep 28, 2008 | Lexmark X8350 All-In-One InkJet Printer
Printer will not print from computer
not a solution as such, but if the desktop won't send to the printer, then the laptop isn't the problem. if the connection is ok and the printer driver loaded ok then it might be a problem with wp software.
Sep 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP Photosmart C4380 All-in-One printer
check the ports first.. make sure that the printer is set as default ( make sure it has the green tick and the status "ready" or "online" on the printer icon in the printers&faxes. and if u want to connect it wirelessly, you have to install it as usb first before changing to wireless........
Jun 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Officejet 4355 All-In-One InkJet Printer Logo
21 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
