Question about Fossil ME1020 watch
I have a proble with setting date & day.
To set the date & day , I read the insturction. But there is no insturction for my watch mode. Please advise me how to do.
I think it's explained on the first page of your manual. first u turn the crown clockwise in position 3 to set the day (you have to turn it 24 hrs evey time to change one day). When this is done, you can set the date with the crown in position 2 and turn counter clockwise. i hope this answers your question
Posted on Apr 05, 2009
How do you set the time on an Armitron 165 wrist-watch?
Hi wtgillo,
Hi there I see that you are in need of assistance setting time on your Armitron Wrist watch.
I would be more than glad to give you details on how to, Please see steps below.
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push D/Alarm Button to set the minutes
  • After setting the minutes on your watch, Press date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Have a nice day,
mvincentc
Apr 21, 2011 | Armitron Watches
I can't set the time on the Timex 1440
To set the time on your Timex 1440 Watch, please follow these directions:
1. Press and hold MODE (Upper left button)
(HOURS will flash and you'll be in Alarm Mode).
2. Press MODE again to enter TIME mode.
(SECONDS digits will flash.)
3. Press ADJUST (bottom right button) to set SECONDS to zero.
4. Press START/STOP (upper right button) to select MINUTES
5. Press ADJUST to change
6. Repeat to set Hours, Date, Month, and Day of the week.
(Go through 12 hours to set AM or PM)
7. Press MODE when finished
8. To display DATE from TIME display, press START/STOP
9. With DATE displayed, press and hold START/STOP, then press ADJUST to change display between DATE-MONTH
10. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12 and 24 hour format.
I hope you are now able to set the time on your watch! If you appreciate these instructions, please remember to rate this post.
--Sandy
Apr 18, 2011 | Timex Watches
My timex 1440 sport watch has buttons that are slightly different than any manuel I can find on line. the buttons are as follows going clock wise from top left mode, stop/start,adjust,and indiglo. I just...
Try this:
To set time and date:
1) With time and date showing, press SET.
2) Seconds ?ash. Press START/STOP to round time to nearest minute,
setting seconds to zero.
3) Press MODE. Hour ?ashes. Press START/STOP to change hour,
including AM (no symbol) and PM.
4) Press MODE. Minutes ?ash. Press START/STOP to change minutes;
hold button to scan values.
5) Press MODE. Month ?ashes. Press START/STOP to change month.
6) Press MODE. Date ?ashes. Press START/STOP to change date.
7) Press MODE. Day ?ashes. Press START/STOP to change day.
8) Press MODE. Time format ?ashes. Press START/STOP to select
12- or 24-hour time format. 12-hour format has AM/PM.
9) Press SET, at any step, to exit and save settings.
Date (day of month) appears in upper part of display in Time mode.
Press and hold START/STOP to see month and date in large digits.
Jan 19, 2018 | Timex 1440 Nylon watch
I've got a breitling superocean chrono and want to set the time, how do i do this?
Keep in mind that I dont have the watch in my hand... :-)
If this is an authentic Breitling...
You should have 2 buttons on the right with the crown between them. The crown screws down so you need to unscrew it before you attempt to set! Once unscrewed with gentle pressure pull the crown out. There should be 2 clicks, pull to 2nd click or furthest distance from case. That should be the time setting mode. Turn clockwise until the date changes then set your time. To change the date push back to the 1st click and that should be the date set mode. One direction will be for day and the opposite will be date. I believe that if you pull the crown back to 2nd click and push your buttons that should change the subdials for chrono. You might need to push both buttons at the same time.
Ive set Breitlings before but they arent a common watch we see. Most people dont use the Chrono so if the directions dont work for setting those then I wouldnt worry too much about it! Not many people are going to notice those. :-) Also be so very careful if its a real Breitling as they are a very expensive to fix! :-)
***DONT FORGET TO SCREW THE CROWN BACK DOWN OR YOU WILL GET WATER INSIDE THE WATCH!***
Jan 08, 2010 | Breitling Watches
Does anyone have instructions for Nike Imara Fit WR0076?
How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
PLEASE READ CAREFULLY
STEP 1:
First hold the button for set/light.
STEP 2:
wait for the "hold to set" message to appear
once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
STEP 3:
To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
*If you are done setting the time press the set/light button, and there you have it.
If you still need to change the minutes of your digital watch proceed to step four.
STEP 4:
After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
To set MINUTE:
press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
*If you are done setting the minute, press the set/light button, and there you have it.
If you still need to change the date specifically, the day of your watch proceed to step five.
STEP 5:
To set date, specifically, DAY:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
*If you are done setting the day, press the set/light button, and there you have it.
If you still need to change the date specifically, the month of your watch proceed to step six.
STEP 6:
To set date, specifically MONTH:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
To set MONTH:
press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
*If you are done setting the month, press the set/light button, and there you have it.
If you still need to change the date specifically, the year of your watch proceed to step seven.
STEP 7:
To set date, specifically YEAR:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
*If you are done setting the year, press the set/light button, and there you have it.
If you still need to change the 12/24 hour format of your watch proceed to step eight.
STEP 8:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
*If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
If you still need to change the power hour of your watch proceed to step nine.
STEP 9:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
Press set/light to set POWER HOUR.
May 13, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
How do I set the time for nike imara fit WR0076-002 wrist watch?
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
Mar 26, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
Day and date not synchronized with actual day and date
The watch does not have a "perpetual" clock so it does not know what month it is in. It will treat every month as a 31 day month, so you will have to re-set the date anytime a month is not 31 days.
If you appreciate me answering this for you then please rank this solution as "fixya" or at least "helpful" as what I have said will solve your problem. :-)
Jan 09, 2009 | Citizen 8700 BL8000-54L Wrist Watch
I dont know how to set the time
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
Nov 11, 2008 | Nike Imara Run WR0075-014 Wrist Watch
Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
Nov 11, 2008 | Nike Imara Soar WR0103 201 wristwatch
Seiko divers watch skx033
unthread the crown winding,the crown is threaded,first you do pull the crown half not full,for day and date adjusment..second pull full is hour and minutes setting,thats it,.when setting is done, push while winding the crown so it lock..rate me as fixya..
Jul 07, 2008 | Seiko 100m Diving Watch SKX033K2 Watch
Fossil ME1020 watch Logo
334 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
