Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Dos telnet command with vb 6.0
Hi..
I wants to run telnet command with ipaddress with username and Password and then wants to run some command eg.
telnet ipaddress
username uid
Password pwd
find channel
and wants to get the response of it in some variable or any file.
How it is possible
    Problem Solver:
  • 9 Answers
Http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
PLink allows for command link execution passing a username, password and host.
To get the response to a file you could use Shell "C:\windows\cmd.exe /c batch.bat > C:\file.txt"
Batch.bat contains your plink script and file.txt is the output.
Posted on Feb 03, 2009
Sannce DVR-DH81NK1T i am lock out need code or password
Connect dvr to local network
boot up the dvr
connect to local network with a computer (eg Mac)
login into admin screen of your router to identify the assigned ip address of the router
start a terminal session
telnet to the ip address
default user name : root
default password : xc3511
mbaad@MBAADs-MacBook-Air:~$ telnet 192.168.0.3
Trying 192.168.0.3...
Connected to 192.168.0.3.
Escape character is '^]'.
YourCCTVDVR login: root
Password:
BusyBox v1.16.1 (2014-12-24 15:47:14 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
Welcome to Monitor Tech.
[root@YourCCTVDVR /]$ cd /
[root@YourCCTVDVR /]$ ls
bin etc linuxrc proc share usr
boot home mnt root slv var
dev lib opt sbin sys
[root@YourCCTVDVR /]$ cd mnt
[root@YourCCTVDVR /mnt]$ ls
custom dvs logo mtd usb web
[root@YourCCTVDVR /mnt]$ cd mtd
[root@YourCCTVDVR mtd]$ ls
Config Log
[root@YourCCTVDVR mtd]$ cd Config
[root@YourCCTVDVR Config]$ ls
Account1 StorageCfg network
HvrMode SysComs ppp
Json SysTime resolv.conf
RT2870STA.dat dhcp.cfg uboot_env_lang_video
There will be an Account## file for each account you have set up
Remove all of these files
[root@YourCCTVDVR Config]$ rm Account1
Reboot your dvr box and it is at the first setup screen
Here are the commands - note you can't send password as part of the telnet command
telnet 192.168.0.XX
root
xc3511
cd /mnt/mtd/Config
rm Account*
exit
CCTV Networking Technical Support
Apr 10, 2017 | Home Security
Where is the password located at
Hey, the Netopia routers do not have a default username and password. If a password is already set up, you might need to reset the router.
In order to log into the router you need to Telnet into it.
If you are using Windows XP, you can start Telnet from Start>Accessories>Communications>Telnet
if you are using Windows Vista or Windows 7, Telnet is not enabled by default. You need to enable it first. You can quickly re-enable Telnet by following these steps:
Start
Control Panel
Programs And Features
Turn Windows features on or off
Check Telnet Client
Hit OK
After that you can start Telnet via Command Prompt. (or the Start menu)
then once you get into the Telnet Console, type in:
192.168.1.1
and the router interface will open up and let you chanfge settings.
[CLICK HERE] for the official Guide by Netopia.
Sep 23, 2011 | Netopia (3347NWG-ENT) Router (3347NWGENT)
How to reset password of username in 6506e switch through telnet not console plz give reply as early as possible.
login through telnet, remove the current username and password.
configure the username with the new password
config t
username xxxx pass xxxx
1. do not exit the current session, telnet the sw with new session and give the username and new pass. if does'nt work roll back the config.
or
2 excute login in current session and try with the username and new pass
Feb 21, 2011 | Cisco Catalyst 6506E Switch Chassis...
I have a start up disk for a newer linksys but i think something must be wrong with my new router. i want to know if i can use the same start up disk for my old router
You can try to access the router using the ipaddress:
1. go to the command prompt. 2. type in ipconfig. 3. look for the default gateway. 4. open your browser and type in the default gateway. 5. username is "username" password is "password"
Thanks
Jul 30, 2010 | Linksys Wireless-G WRT54G Router
Comtrend adsl2+ keeps timeing out
Hello, To prevent this happening, you need to disable the block list. Use the following steps:
  • Open a DOS prompt (start->run and type in cmd)
  • Type the following:
    • telnet 192.168.2.1
    • Username = admin
    • Password = password set to access the router config
Once you access the router config, type the following in:
  • firewall set IDS blacklist disable
  • Close the window.
You should now find that you can access the sites that were timing out.
Apr 18, 2010 | Belkin (F5D7231-4) Wireless Router
Connection is asking for network security pin
Network Security pin is the WEP or WPA provided by your service provider, while configuring the Router. Please follow the below steps to get the WEP key.
1. Click Start -> Run -> type "cmd". Click OK. Command prompt screen will popup.
2. In the command prompt type "ipconfig" hit Enter.
3. Please make note of default gateway address (Eg. 192.168.1.1)
4. Open internet browser and type http://<default gateway address> (Eg. http://192.168.1.1)
5. You will be prompted to enter Router login Username and Password. (provided by service provider). Enter the username and password.
6. You will see the Router configuration page, then select the Wireless Tab; there you will see WEP / WPA key.
Thanks n Regards
Rizwan
Jan 28, 2010 | Computers & Internet
Forgot my password for router or ip addressed
by default leave the username blanck and password is admin, for the ipaddress go to command prompt type in ipconfig then hit enter, the gateway is the ipaddress
Oct 20, 2009 | Linksys Wireless-G WRT54G Router
Lanier ld122 503 service unavailable
This can occur if the Web services has been turned off in either the Web Image Monitor or from a telnet command for this device.
To check the status of these services you will need to telnet into the device.
1. From a command prompt type : telnet then the IP Address of the device
2. Telnet will respond back with a request for a login and then a password. Enter the login and password. The login and password used for Telnet are the same credentials that are used to log into the device’s Web Image Monitor (WIM).
3. Type in show at the msh> command prompt.
This will output many lines of information. The information you are concerned with is under the TCP/IP-Mode heading. You may need to scroll up in the command prompt window to see these services. The device’s services will be shown followed by their status. The ‘show’ command will show if the services are enabled (UP) or Disabled (Down).
4. If Web shows a down status, at the command prompt msh> type in set web up.
5. At the command prompt msh> type in logout
6. To make your changes Active you must type yes when prompted to "save configuration data"
Note: Always check with your system administrator before making any changes on a network device.
Aug 19, 2008 | Ricoh Office Equipment & Supplies
Computer
On the controlled pc you must open administrative tools - services and make sure telnet service is started and set to automatic.
On the controlling machine, open a dos window and type "telnet computer-name" or "telnet ip-address" when prompted enter username and password that is valid on controlled pc, at that point you can run many dos command line commands and programs. Make sure that controlled pc has passwords for all accounts, otherwise you open a big security hole.
Apr 06, 2008 | Microsoft Windows XP Professional With...
Run dos command through vb 6.0 without showing it
visual basic, on windows, right? jumping to dos, implies a command line, no? how else would you access a command line interface, if not through cmd?
Mar 20, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
607 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
