Question about Dell Latitude D600 Notebook
Fan off but on for a few seconds occasinary
I noticed that the fan is not rotating but when i opened the lap top, and switched on while opened, the fan responded only for a few seconds. This happen several other times i swiched on and off. Is there a sensor that instructs the fan to start rotating or could the cable be loose where i am not checking? Help
  • jmsimuko Feb 05, 2009
    Your anwer is correct as i also observed later. It appears that i have never noticed or bothered to check what happens. On that particular day however, i thought there was too much heat and when i noticed that the fan was not rotating, it became a major concern. On the following day I decided to risk and surprisingly all went on well.
  • 3,940 Answers
The cooling fan runs when prompted by a thermistor on the motherboard. If the CPU temperature is below the temperature threshold, then the fan doesn't run.
The system is functioning as designed unless the system is displaying symptoms of overheating.
Posted on Feb 05, 2009
Why doesn't my fan rotate anymore?
definitely sounds mechanical. try prying open the motor area and see if anything happens when you turn it on. i'm guessing it might be a short somewhere that's making the other parts have to compensate
also check into servos, relays, and whatnot
May 15, 2015 | Miscellaneous
Why doesn't my new blend door switch not rotate with the ignition switch on acc.?
Blend door changes temperature, does not close air flow. need better description.
Apr 30, 2014 | Ford Windstar Cars & Trucks
When I start my M70-192 lap top , it does not work and the fan operates for few seconds and stops . also the the power indication LED operates for second and turns off .nothing is displayed on the screen...
Remove the main battery and try again, if no change! the DC jack in the laptop is a common source of trouble and must be dismantled down to the motherboard level to address, bad solder connections are common under the plug, I recommend you have it fully assessed before repair.
Apr 16, 2012 | Toshiba Satellite PC Notebook
115,000 btu reddy heater, 5 hrs used in sprayfoam-grinding environment. stopped working. when plugged in, only hums for a few seconds, then stops. how can i fix that?
First, remove the top cover. Inspect for a varmint nest. If clear, manually spin the fan. If it does not you either have a broken rotor that is binding or you have a bad bearing.
If it spins freely, apply power- see if the motor runs with the top cover removed.
If YES, replace the top cover. Its possible that the top is binding the fan.
If NO, the start capacitor is defective. The cap on R115 is internal and is not servicable.
Reading material about a hummer
Nov 04, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Sir i am using asus motherboard(ASUS M2N68-AM SE2) in my pc, when i switch on my pc the processor fan and smps fan is rotating for few seconds(4 to 6 Seconds) and it stopped rotating. 1. the monitor shows...
remove all the ram from motherboard and switch on the system and see it is working or not like just on and fan are rotating and the smps fan is also working and your system is giving beep sound for ram.try with other smps also some time problem with power supply also. Remove the connector of power switch and restart switch and directly try to on from shorting the connector with the help of pen or screw driver point. Some time faulty switch also give problem. Just try all these possibilities.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Jan 03, 2011 | ASUS M2N68-AM SE2 Motherboard
I have a GSS25KGMD fridge. I opened the Fridge compartment top part was very warm and the bottom was cooler. Upon investigating more I noticed that the fridge bulb was very hot. So I pushed the fridge...
Your refrig light switch does control the freezer fan and the refrig light bulb . Replace the refrig light switch .
Open the refrig door , freezer fan goes off and the refrig light comes on .
Nov 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
How to set up time on TAG HEUER SLR CHRONOGRAPH ? what are the functions of the 2 boutons and 2 crowns ?
The crown at 3 o'clock is used to set the time and change modes. The crown at 9 o'clock is used to rotate the flange at the edge of the dial.
The A button at approximately 2 o'clock starts and stops the chronograph function. The B button at approximately 4 o'clock resets the chronograph.
Lap Timer: When the watch is displaying normal time, press the right side crown to switch to chrono mode (the hour hand will indicate CHRONO). This watch measures lap times, press A to start timing the first lap. Press A again to stop the first lap and automatically start timing the second lap (the hour hand will move to indicate you're on the second lap), and so on. You can measure up to 20 laps this way. When you're fininshed timing laps, press the right side crown to see the best lap time. To reset the lap timer, hold down B for 2 seconds. To switch out of chrono and see the normal time, just press the right side crown in.
Chronongraph: To time an interval that is not a lap, just follow the above instructions, but instead of pressing A to stop the first lap, press B and the watch will show the elapsed time to the nearest 1/100th of a second. Hold B to reset.
Crown at 9 o'clock: This crown rotates the inner flange at the edge of the dial and is used to measure total race time (i.e. the total of all the laps). Simply rotate the crown until the the little start trinagle on the flange is aligned with the minute hand. This way, the total elapsed time can be read at any time, similarly to how a rotating bezel works.
To set the time: Ensure the watch is not in CHRONO mode, if so, press the right side crown in. At this time pull the right side crown out until you feel a click.The position the second hand moves to indicates what is currently being set. If the second hand is at 9 o'clock, you are setting am hours, press A repeatedly to set am hours. Then press B and the second hand will move to 6 o'clock, pressing A repeatedly will set the minutes. So on for year (11 o'clock), month (12 o'clock), and day (1 o'clock).
Feb 25, 2009 | Tag Heuer SLR Mercedes Benz Limited...
Toshiba M55-S135
check your battery on some other's laptop, i think the battery life is over, you have to replace the battery
Oct 29, 2008 | Toshiba Satellite M55-S135 Notebook
Edge 305
Try Holding the Lap + Mode, for a few seconds, release and then hit Power button. It worked for me.
Cheers
Sep 29, 2008 | Garmin Edge 305 GPS Receiver
Dell Latitude D600 Notebook Logo
135 people viewed this question
Alun Cox
