Question about Sanyo DS31590 31" TV
I have sanyo tv with a universal remote and hit the input button to swith over to my dvd player to watch a movie. When i was finished I hit the input button again to switch back over to the tv and it won't respond to the input button or the channel buttons on the remote or the tv itself. I even tried reprogramming the remote and unplugging the TV. The screen just stays blue with the world Video in the top right corner. Please Help!
  • 1 more comment
  • bkf2008su Feb 03, 2009
    I already tried changing the batteries also, thanks though! Any other suggestions?
    i can access the menu button but, i'm only limited to two options, the others are red and wont let me choose them.
  • logeli Feb 23, 2009
    i have the same problem. my front panel has only the two buttons i can get at antd it's on closed captioning all the time. my universal won't work with it either just to turn it on or off.
    President:
  • 1,214 Answers
Try some new batteries in the remote, or, just roll the batteries in the holder.
Posted on Feb 03, 2009
  • Mark Egan Feb 03, 2009
    Power the unit off, and unplug for a minute or two.If it still doesn't work, can you access the memu using the front panel buttons?
    Here's a copy of themanual -
    http://www.sanyoservice.com/pdf/images/D...
    It describes the method that is used to select various adjustments via the front panel.
    Reply back to me if this works for you.
How do I hook up DVD player
Liz,, most DVD players come with RED, Yellow, White cables. on back of ur DVD player find the holes with the matching colors. and insert cables, now go to ur TV , on the back you should see some of the same colors plugins ,.once u have done that . put in a DVD and hit play. now go to the input/source button on ur TV or remote and push it . u might see a drop down menu if u do highlight the AV or Video 1 or 2 or 3 till u get a picture. when finished u will have to hit the input button and go Back to where u were in order to watch what u had it on before. NOW if u have a Blu Ray DVD player all u need is the HDMI cable , find the HDMI output onback of player and on the TV find the same. your tv might have 3 or so HDMI inputs ,, any will work. as before put in a movie, use ur remote , input button and find the HDMI on the menu and high light it. .
Jan 25, 2015 | Televison & Video
How do I watch a dvd movie on tv? I have the dvd
press the av or au bullon on remote until you get to the dvd "channel"
Feb 11, 2010 | GE 19GT243 19" TV
Universal rca 311 remote works on the sanyo tv but i cant get the input button to work so i cant swith the video source to watch dvd?
The keypad has a insert under it with the back side has what appears to be a group of black buttons attached to it. Remove battery and open your remote. Clean this buttons with clean cloth and alcohol. Also clean the circuit pad with which these buttons come into contact. This should fix your problem
Jan 20, 2009 | RCA RCR311B Remote Control
TVS2740B, how do I switch from TV to Video Input manually?
going to have to get a universal remote with input button on it, or tv/vcr button, had same problem!!
Jan 04, 2009 | Sansui TVS2750 27"
My new universal remote
Jo have you plugged in the Audio and Video cable in correctly. You need to check that the Video cable is in the corresponding input on the TV
Jun 08, 2008 | RCA Universal Remote Control
No input button
go to localtv shop try getting a used remote for your tv remote original no longer available and is what you need
Mar 15, 2008 | Sanyo DS31590 31" TV
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
Sanyo DS31590 31" TV Logo
239 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
