Question about Sansui DTV2760 27" TV
Sansui lcd27' model SAN2701
Takes 5 t0 10 minutes to start.Hope you can help.Thanx.
Your Problem is in the power supply, the filter capacitors  need replacing .
By memory there's 3x 3300mf 63v and 3x1000mf 25v
any cap with a buldging top throw out.
Cheers
Posted on Jun 14, 2009
I have a sansui tv model sv2918,it doesn't play
The TV has some firmware defect. Seek tech support.
Unplug it from AC mains wall socket, and plug it again after 5 minutes. This must make it a hard reset.
May 31, 2012 | Samsung Televison & Video
The tv turned off by itself and now wont turn back on it is a sansui san2701
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
If there is no power at all check the power supply unit - the SMPS
check the link
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
May 05, 2011 | Sansui Televison & Video
SANSUI SV2918 switches on after 30 minutes
Failing power supply. It takes 30 minutes to recuperate, then fails again.
Feb 07, 2018 | Televison & Video
HELP ME PLEASE............
You need to be more specific with the model number. Most Sansui TVs have model numbers like "SAN2701" plus a version letter like "Version A"
Additionally, procedures for removing the Child Lock, Panel Lock and TV Lock are in the users manual.
In some models, for the V-Chip, the original code is 000000, if you want to clear the code, please press the keys VOL + and VOL - on the front panel at the same time.The password of the TV's V-Chip Set up or Movie V-Chip Set up may be changed at any time. Press UP or DOWN to input the password,then press to select OK or Cancel. Press menu to confirm your input.
Hope this be of initial help/idea. Pls post back as to the exact model and version of your Sansui TV, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 31, 2008 | Panasonic TH-37PX60U 37 in. Plasma HDTV
SANSUI 27" LCD Model SAN2701
video recorder are recievers only not a video audio transmitters( well if it is a player too maybe a button is to be pressed for auxilary)..
and I am sure it comes with a warranty. apply it to the seller and so they can fix the problem of your unit.
Feb 17, 2008 | Sansui DTV2760 27" TV
When I turn TV O
When i open it screen takes 15-20 minutes to be displayed complete.sound & other things are ok.So i request to have sansui tv service dealer in Mumbai/Navi Mumbai/Thane India No; to contact. Regards M.w.Ahmed
Mar 02, 2007 | Sansui LCDVD200 20 in. TV/DVD Combo
Sansui DTV2760 27" TV Logo
151 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
