Question about InFocus LP70+ Multimedia Projector
Power problem with infocus lp70+ projector
The light from my infocus lp70+ projector flickers kind of like a regular bulb that's going bad, the unit turn off by itself after a few minutes and will not turn on for a few hours afterwards.Since I have been able to turn it on briefly from time to time, I know the bulb is still good. What is wrong with this machine? any help would be appreciated.
  • starchaser Feb 03, 2009
    I have not reset the the lamp hours, I only have about 900 hours on it and the manual says the lifetime of the lamp is about 3000 hours.
    Should i still reset it? Providing the projector stays on long enough to let me get to the menu (somtimes there is not enough time).
We can repair your power supply for LP70+
Posted on Feb 13, 2009
  • 10,594 Answers
If you have replaced its Lamp (bulb) please rest Lamp hours in projector Menu immediately.
Lamp Hours reset procedure is written in user manual.
Posted on Feb 03, 2009
  • Shahid Electronics
    Shahid Electronics Feb 03, 2009
    You should reset lamp hours in case lamp is just replaced. I think projector has problem with ballast lamp supply so turning off immediately.
    Qualified service tech will fix it properly as its not seems home fix.
    Problem Solver:
  • 5 Answers
It seems the power supply board problem. shoud be checked by the trained technician only.
Hi, I have a Infocus Projector, Model # LP70, serial # begins with ACAN. The projector only has 951 hours on the bulb. The unit powers on and I get the Infocus startup screen. as soon as I turn on a video...
I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 22, 2011 | InFocus LP70+ Multimedia Projector
LP70 appears to be stuck in standby mode. The orange light illuminates immediately when the power is turned on. The bulb was just replaced.
the power supply needs to be upgraded which involves soldering a wire to the power supply then to the main board.
Jun 25, 2010 | InFocus LP70+ Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
I have infocus lp70 model projector. i replaced the bulb and now it won't light. i put back in the old bulb and the light still wont come on...any ideas? You can tell that the projector wants to run and is...
if you don't hear a high-pitched whir, your colorwheel needs replacing. you can remove the lamp and see the colorwheel inside (colored glass wheel). if you turn it on without the lamp, the colorwheel should still spin. if it does, you have a ballast problem. if not, the colorwheel. you'd still need to send it in to an infocus authorized service center. try av solutions in ny. they're pretty good.
Oct 22, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70
Have you tried another lamp? Sometimes thats your problem, but I've seen a several occasions that the a defective power supply causes this symptom. Do you see an image flicker before the projector shutsdown? I do have some spare parts for this projector.
I'm on Ebay - gtitubro if you want to contact me through there.
Sep 17, 2009 | InFocus LP70+ Multimedia Projector
Lp70 flickers and color wheel chirps at the same time. It's worse with more white in the image. Colored screen shots or dark movies have limited flickering. No issues prior to hookup to computer (Infocus...
it's chirping because it's trying to keep in sync with the dmd chip. for the refresh rate, go into the menu and first reset the settings to factory default. if this doesn't clear it up, try matching the signal.
Jun 09, 2009 | InFocus LP70+ Multimedia Projector
The light from the projector on my infocus lp70+ flickers kind of like a regular bulb that's going bad.somtimes the unit goes on for a few minutes and then it goes off by itself. any help is appreciated.
the colorwheel needs replacing. in order for the lamp to strike and stay on, the colorwheel has to stay at a certain speed to sync with the dlp. if the speed is off, the lamp won't stay on.
Feb 03, 2009 | InFocus LP70+ Multimedia Projector
In focus 70+ light flickers
I have the exact same problem, it comes and goes, but i noticed that the screen was flickering more when the projector was tilted up a bit.
I shifted the cable from s-vhs to vga and now i dont have this problem so often anymore.
I also have the common problem that it sometimes wont start up when i power it on, or it shut down after a few seconds. It seems to be a loose wire somewhere, but i just give it a punch and then it starts..
Aug 06, 2008 | InFocus LP70+ Multimedia Projector
Why does picture brightness change up and down on LP70.
Hi there
Sounds like the lamp is going , but it could be the Ballast as well ( lamp's powersupply ) Rather have a certified technician look at.
Mar 22, 2008 | InFocus LP70+ Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
663 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
