Question about Frigidaire GLGQ2152ES Gas Dryer
Dryer smells like smoke and hasn't been used in a couple mnths
  • 750 Answers
If you just turned it on and it smells for only a short period it may just be that dust settled on the element during the period of non use.
if it goes away after 15 minutes to half hour it should be okay. just stay with it for that time!
Like when you first turn on the heat in some homes you smell that too!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Feb 03, 2009
My hotpoint tumble dryer almost caught on fire the house was full of smoke can l claim
Only if you can prove that the fire/smoke was caused by a machine defect and not a lack of cleaning the unit out once in awhile.
Jun 20, 2016 | Hotpoint Dryers
New dryer smells hot
It is not unusual for new appliances, espicially high heat ones like a dryer to smell hot. Also if this is your first gas appliance it might smell different than your old dryer if it was electric. Keep an eye on it when using it to see if you see any smoke. Also check your venting to make sure it is all clear with no blockage.
Jan 10, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer smelled like smoke and hose filled with water
Something is plugged dryers vaporize wetness not create water
make sure all ventilation is clear
Apr 02, 2014 | Samsung Dryers
Can a dryer heating element smoke if dryer is not running?
Something fried and is shorted. Unplug this unit right away. There are a few sensors on this that could have overheated as they failed causing this smoke and smell, but UNPLUG UNIT!!! Then look at what has fried.
Aug 31, 2012 | Whirlpool Dryers
Lg condensor tumble dryer c740045E, stopped turning, belt is fine, but a burning smell is coming from the motor, and smoke.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 18, 2011 | LG Dryers
The dryer makes a lound noise like grinding and smells like something hot or burning. I see no smoke and it started ok after a couple of turns or so the first time but the second time was when I smelled...
my daughter had a maytag dryer doing the same thing. I took it apart and the bracket that holds the drum broke off. it is cheaply made. what happens it that this causes the drum not to spin freely and causes a lot of resistence on the motor. the motor will get over worked and also the belt will slip causing smell and heat. my daughter ran hers for a while it was doing this and it also messed up the motor. we just bought a new dryer. all these parts are available, but it might be cheaper in the long run to get another one.
rick
Jul 18, 2011 | Maytag Dryers
My dryer stopped running in mid cycle and there was a burning smell. I thought it may be the belt, but it is not the belt. Also, the light inside the dryer hasn't worked for years, so I don't think...
heatman101
Jun 15, 2011 | Maytag HYE3658AY Electric Dryer
My dryer smells like smoke
just ry to run in on air dry for a while mayee wth dryersheets. charcoal and baking soda are also good at absorbing smell if you can find a way to implement them maybee baking sod box in dryer not running
Jul 09, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Dryer smoking, burned rubber smell
if the rug has a rubber side it will melt make sure dryer is clean and no left over burnt material ..
Sep 18, 2017 | Dryers
Dryer smelled of burning plastic, smoked stopped turning on
check the power cord itself, if you see on the back side of the cord a burnt or blackened spot then the cord is the issue
Apr 12, 2008 | Dryers
Frigidaire GLGQ2152ES Gas Dryer Logo
355 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
