Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Won't spin Will not spin, and makes a loud buzzing noise.
  • 750 Answers
Faulty Direct Drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The Direct Drive (motor) Coupling may be broken.
Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Last the huming may be the motor is sized! Done, finished!
This is not a do it your selfer job
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Feb 03, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Efi makes buzzing noise
glad you solved the problem
Jul 30, 2012 | 1989 Toyota Camry
Kenmore 80 series washer won't spin just makes a loud buzzing noise.
Possible that the motor is not moving , could be a faulty capacitor to the motor. Also check for the free movement of the agitator, if the shaft is tight then it can cause a drag on the motor.
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jun 28, 2012 | Kenmore Washing Machines
MY WASHER WILL NOT SPIN. iT MAKES A LOUD BUZZING
Sounds like a broken motor coupler for sure, the motor shaft will still spin the drain pump, but drive between the motor and transmission is lost. Part# 285753A. Have fun. If you need breakdown info let me know.
Dec 30, 2009 | Kenmore 22422 Top Load Washer
Samsung DLP4663W. Loud buzzing noise from inside
The loud buzzing is usually due to the Color wheel being broken ir the bearings being bad.You can get replacement wheel at the following link.
http://servicemanuals.vstore.ca/
Sep 12, 2009 | Televison & Video
Buzzing - will not spin or drain water
This noise is probably the pump trying to start but will most likely be obstructed.Drain the machine manually by lowering the drain hose into a bucket or bowl and then remove blockage.
Nov 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Loud buzzing noise
It is normal with xbox 360 it is just your system cooling down...
Jan 21, 2008 | Microsoft Xbox 360 Console
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
256 people viewed this question
Dan Webster
Dan Webster
Sal De
