Question about Linksys WRT160N Wireless Router
Linksys WRT54G2 Router + Zyxel P-600 Modem = NO INTERNET
I just configured my new WRT54G2 Router using my laptop. After the "checking network..", I noted I did not turn my Zyxel P-600 Modem (which is connected to a DSL) "ON". I turned it on, but still there was no connection. I proceeded anyway with the config. The config was successful. After installing the LELA, I was surprised to see that I was still OFFLINE. I recycled my modem, still no connection. I turned off my modem and my router, turned my modem ON, then my router ON. Still no connection. I tried to follow the troubleshooting wizard in LELA, still no connection.
I got tired of troubleshooting so I just disconnected the modem from my router and plugged the modem to my PC. STILL NO CONNECTION! I looked at the LAN Properties, I found a different IP Address from the usual one I was using. there was also no Gateway address, and no DNS server address! They got erased somehow...
Did my router change my IP address?? How do I fix this?
  • Ruwon Feb 03, 2009
    Hi, Its me again. I am not currently with my PC right now cause I have no internet connection at home. Could you give me a guide on what to do next so I could give you a more detailed description of my problem. Thanks a lot!
  • Mark Egan May 11, 2010
    The router didn't change the address.
    FIrst things first -
    Open command prompt.
    Type ipconfig /release
    When the prompt returns, type ipconfig /renew
    You should get a listing of all your connected network cards in your computer, with valid IP's the cards and for the gateways (for instance 192.168.0.1 for the gateway, which would be the modem.).
    Reply back what you get, and we'll proceed with getting you online.
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Problems with home networking between desktop running XP (wired) and laptop running Vista (wireless), using DSL broadband (PPPoE) internet connection, Westell 6100 modem/router & Linksys Wireless-G WR
Hi MissGarbs,
Based on your post and description, it would seem that your problem is caused by:
1. having 2 routers on the same system;
2. Both routers performs DHCP server function; and
3. Both routers use 192.168.1.1 as default IP Add.
Your problems are:
a. laptop has no internet access only local network; and
b. you cannot access the router to make changes.
A possible solution. Pls back up your configurations first before attempting changes (or log them down somewhere so if needed you can revert back).
A. Power off and remove all connections to the LinkSys WRT54GS, set it aside for the moment. The objective is to verify/establish Internet connection.
Connect your desktop PC via LAN cable to the Westell 6100. Boot your desktop PC, right click on the networking icon bottom right side in your system tray, click on Status, click on Properties button, highlight Internet Protocol (TCP/IP), click on properties button (mid right):
tick "Use the following IP address"
Enter values as shown below -
IP address: 192.168.1.4
Subnet mask: 255.255.255.0
Default Gateway: 192.168.1.1
DNS servers: 68.238.0.12 & 68.238.112.12
click on OK, OK, Close.
Power on the Westell 6100, give it time to sync and connect to your Verison. .In the desktop PC, open a browser. Verify that your desktop have access to the Internet, do it on a few sites. Should you have no internet access, pls seek assistance from Verizon tech support. You need not mention the LinkSys nor the laptop since you have as of the moment a single PC attached directly to the Westell 6100.
If it is all green & go, power up your laptop and boot to Windows. Remove the LAN cable at the back of your desktop and connect it to the laptop's networking port. Do the same configuration ("Use the following IP address") to the networking/LAN card of your laptop.
IP address: 192.168.1.5
In the laptop open a browser. Verify that your laptop have access to the Internet, do it on a few sites. Should you have no internet access, pls seek assistance from Verizon tech support again. You need not mention the LinkSys nor the desktop since you have as of the moment a single laptop attached directly to the Westell 6100. (This is of course assuming that your laptop has a networking port)
If both the desktop PC and the laptop can now connect albeit individually to the Internet, the LinkSys may now be inserted into the system.
B. Disconnect the LAN connection of the laptop to the Westel 6100 and connect it to one of the 4 LAN ports at the rear of the WRT54GS; do the same with the desktop (use another LAN cable). The LinkSys for the moment need not be connected to the Westell. So in effect you have 2 units connected to the WRT54GS. Do a hard reset on the WRT54GS, with the power on, press on the small reset button at the rear of the unit. Allow it to reinitialize. Open browsers to both laptop and desktop. Type "192.168.1.1", password is "admin" and the username is blank, verify that you can open the LinkSys Web Configuration Utility. On either the laptop or the PC desktop (assuming both can access the same page), on the setup page of the LinkSys Config, change your Internet Connection Type to "Static IP",
Internet IP Address 192.168.1.2
Scroll down to Network Setup,
Change IP Address to 192.168.1.3
Disable the DHCP Server (You can have at any given time only 1 instance of a DHCP server, either from the LinkSys or the Westell, but you can also have NO DHCP server if you are using static addresses.)
Click on Save Settings at the bottom, exit, and close. Verify that the LinkSys can be accessed from any of your browsers by typing "192.168.1.3", if no; go through the procedure again very carefully. If yes, proceed to change the Default Gateway of both the laptop and desktop PC from 192.168.1.1 to 192.168.1.3, all other configurations stand.
In your laptop, right click on the WiFi networking icon (bottom right of System Tray). Click on Status, click on Properties button, highlight Internet Protocol (TCP/IP), click on properties button (mid right):
IP address: 192.168.1.6
Default Gateway: 192.168.1.3
Verify that you can access/connect/ping 192.168.3; 192.168.4; 192.168.1.5; and/or 192.168.1.6 from either the laptop or desktop.
If yes, we can now connect the LinkSys WRT54GS to the Westell 6100. Remove the LAN cable attached to your laptop. Verify that you can still access/connect/ping 192.168.3; 192.168.4; 192.168.1.5; and/or 192.168.1.6 from the laptop even without the LAN cable since you are now connected via WiFi.
If yes, connect that LAN cable to the Westell 6100 LAN port, move the other end from 1 of the WRT54GS ‘ 4 LAN ports to the WAN likewise at the rear of the LinkSys.
Verify that you can access the Internet from either computer. At this moment, you have not assigned a security method (WEP, WPA, MAC Filter). Your choice as to what security you want implemented but offhand I would suggest the simplest, MAC Filter since any other would affect speed of your connection.
Additionally, you may want to enhance you browser connection. In Mozilla, click on Tools, Options, Advanced tab, Network tab, Settings button, tick "Auto-detect proxy settings for this connection, OK, OK;
In IE, Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings", OK, Advance tab, check Use HTTP 1.1 through proxy connections.
In Opera, Tools, Preferences, Advanced tab, Network, Proxy server buttons, check "Enable HTTP 1.1 for proxy, OK, OK.
Normally (and perhaps easier for some) would be using the DHCP and not using static. Experience has shown me that static proves to be more stable especially if WiFi is concerned and in your case, only 2 PCs.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 05, 2007
Bat1956
  • 585 Answers
SOURCE: setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 28, 2008
kakee
  • 1269 Answers
SOURCE: Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Posted on Apr 25, 2009
  • 137 Answers
SOURCE: router connection
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
Posted on Mar 13, 2010
I have a ZyXEL EQ-660R-F1 and a Linksys Wireless Router (B BEFW1154) that I'm trying to hook up. Can you tell me what I need to do?
Who is your ISP (internet service provider)? Anyway, it is possible to get your set up working. ZyXel is the DSL modem gateway and Linksys, your router/wifi. If you are able to get online by hooking up directly to the Zyxel, then it is possible to add the Linksys to the system.
Dont hook up the Zyxel to the Internet port of Linksys just yet. First you have to configure the Linksys by connecting your PC to it with a cable. Boot up the PC.
Open web browser and enter the address 192.168.1.1 and hit enter. This is the default address of the Linksys. username = admin and no password. It is probably the same as the Zyxel which causes the conflict.
The first set up page may look something like this below.
Change the LAN IP address from 192.168.1.1 to 192.168.2.1
Then click apply...From now on the Linksys IP address is 192.168.2.1.
Now you can connect the Linksys internet port to the Zyxel. Reboot the Linksys and Zyxel.
Your PC should be on the internet after that. To check/setup wifi, you need to log back into the Linksys using the new adress x.x.2.1
Feb 15, 2013 | Zyxel Prestige 660R Router (91004397002)
Show me how to connect linksys wireless
Hi
The Router configuration is not that much difficult, only few thing you have sure,
1) Correct ADSL Connection User name & password,
2) Chose unique ip address in All host.
Follow the mention bellow instruction to configure and connect to Wifi Router,
  • Plug the network cable ( Mine was Blue ) which comes with the Router Box pack to your computer. The other end goes into any of the Router Ethernet Port ( 1 or 2 or 3 or 4 )
  • Now type in 192.168.1.1 in IE or Firefox or any browser. You will prompted for password which is admin. You must be logged into Linksys Router.
  • Now since your ADSL modem is also having the same IP , we will change the IP address for WRT54G2 Router to 192.168.5.1
  • Under Setup >Basic Setup look for Network Setup and Change Router IP. Change to 192.168.5.1 and Save changes.
  • Since the IP has changed you will need to close the Browser.
  • Sometimes the IP doesnt change automatically. Do a IPCONFIG / RELEASE and then IPCONFIG / Renew
Making WRT54G2 Router talk to ADSL broadband modem
  • Plugin the Ethernet cable which comes from the Modem into the port on Wrt54g2 router which says Internet.
  • Open Internet Explorer and Type in 192.168.5.1.
  • Type in same password ( admin )
  • You will be in Setup > Basic Setup
  • Take a look at Section , Internet Setup. The current selection should be Automatic Configuration DHCP. Select Static IP instead.
  • Add following details to it. In the first step we backed up All the IP configuration. Use them here
Internet IP Address: . . .
Subnet Mask: . . .
Gateway: . . .
Static DNS 1: . . .
Static DNS 2: . . .
Static DNS 3:
ADSL Modem Settings to Wrt54g2 Router
  • Once Done just save changes and you should be back at same page.
  • Now try to connect any application which talks to internet. You should be able to connect
Configuring for Wireless Connection :Now once your Router is talking with Modem, it is pretty easy to connect on Wireless. The only thing we need to setup here is Security. Lets get WIFI
  • Get to the Lynksys page again. Do all login and regualr stuff.
  • Now look for menu Wireless, click on it. You should land on Basic Wireless Settings.
  • Select wireless configuration to Manual .
  • Wireless network mode to Mixed.
  • Give a Wireless Network Name (SSID), make sure its unique.
  • Make Wireless channel selection 11 ( 11 - 2.463 GHZ)
  • Select Wireless SSID Broadcast to Enable
  • Save Settings and you will be back at the same page with changes you made.
Now Lets secure the Router :
  • Go to Wireless Security on the same page.
  • You will need to configure here Security Mode : WPA Personal, WPA Algorithms: TKIP
  • WPA Shared Key is what you will need when you connect to your router without wire. This key does the authentication and keep unwanted people away. Add 8 digit alphanumeric key.
  • As suggested in comments, there is a new mode which you can use : WPA2 with AES
  • Save changes.Just make sure you save that key to a notepad or remember it.
Wrt54g2 wireless security
  • Now last step, Move to next menu Security > Firewall .
  • Uncheck Block Anonymous Internet Requests .
  • Save Settings.
Wrt54g2 firewall settings
  • Remove the blue cable which you had connected with Router.
That's it. Now just turn on your WIFI and Search for the router. The name should be visible. Click to connect. At this stage it will ask you for the Password or Shared Key which we configures just above. It will connect and you will be able to connect to Internet.
That's all Folks. This is how you connect WRT54G2 Linksys router with Adsl Broadband Modem. If you have any questions feel free to comment.
Aug 03, 2011 | Linksys WRT54G2 Wireless Router
Linksys WRT54G2 Wireless router unable to connect to Internet
Try again by Disabling the WEP (or WPA), MAC Address Filtering and Firewall Setting Individually. Should be a problem with one of those. Then when you receive the Signals, try to Adjust using Bottom Up method. That means one setting at a time, Hardening the Security. Have you checked your DNS settings? Have you checked the Channels you are using? Re check them and try again.
Feel free to contact back.
Please rate the answer if it helps you to solve the issue.
Thanks for contacting Fixya!
Jun 12, 2010 | Linksys WRT54G2 Wireless Router
Can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Sep 28, 2009 | Linksys Wireless-G WRT54GS Router...
Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Sep 20, 2009 | Computers & Internet
Cable Network Routing with Zyxel 600
You have to set different ip address. To clear this up this how I got my setup. I have verizon internet. I use a westell 6100g modem, I have the local ip address set for 192.168.1.1 and I got a linksys wireless router and the ip address set for 192.168.9.1. Then I plug my modem into the wan port and it works. What am I doing is setting a static ip address from my modem to the router and using the router to distribute my address through the network. If you have any printers on the network you need to change that numter to 192.168.9.x number. If you don't have two different numbers set the router will take over.
Aug 09, 2009 | Zyxel Prestige 841 (91-004-226010) Modem
Access home network remotely via zyxel modem
you will not be able to access from one network to another even if you are on the same workgroup. However, you can setup VPN on both side. the other is to use commercial remote software. i.e.: vnc, mypc, teamviewer, etc.... they don't need anything else, but do require setup on both machine. This is much easier, don't need any permission from the network administrator, or company permission.
Jan 09, 2009 | Zyxel Prestige 660M (P-660M-61)...
Setup linksys wrt54g2 broadband router with prolink h9200 modem
Dec 27, 2008 | Linksys Wireless-G WRT54G Router
Laptop
Alright, first we'll configure the router for internet connection. I have a links here for you on how you can manually configure the router for internet connection. click here. Just let me know if you will have a problem getting the router online. After we setup the router for internet we will configure the router and the wireless for wireless connection.
Aug 12, 2008 | Linksys Ultra RangePlus Wireless Routr...
Cannot connect to the internet with my laptop
To connect to the router wirelessly using a Windows XP, right click on the wireless network connection icon on the lower right corner of the screen and choose view available wireless networks. Select your existing network and click on the connect button. If you are using Vista, go to network and sharing center of your control panel then select connect to a network. If you still having problems, please provide details of the problem like your Internet service provider and if there are already other computers online with your WRT54G2.
Jul 11, 2008 | Linksys Ultra RangePlus Wireless Routr...
Linksys WRT160N Wireless Router  Logo
822 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
