Question about AudioBahn AEQ6 5-Band Car Equalizer
Need info on wiring for audiobahn aeq6q 5 band equalizer
There are 3 terminals one is power and one is ground and one says "sens" what do I hook up the "sens" terminal to is it the remote signal?
    President:
  • 1,990 Answers
Yes, This connects to the Blue Remote Wire. This will allow the EQ To Power on when in ACC or Start on the Ignition. Please Rate My Response! Thanks!
Posted on Feb 03, 2009
How to get the whinning noise outta my radio in a f-150
Try running the ground wire directly to the battery ground.
Aug 07, 2014 | Planet Audio Peq15 5-band Parametric...
I need to no how the wires get hooked up
bottom right( red wire 12 v dc on/off ignition switch)
2. top right( blue wire with inline fuse to amplifires)
3. bottom left( black wire ground)
4. top left( blue wire stereo2_bing.gif remote wire)
May 09, 2010 | Pioneer EQ-6500 9-Band Car Equalizer
How to hook up a equalizer
i believe you need to be running an aftermarket amplifier to use this E.Q. does it only have RCA inputs and outputs on the back of it? if it does, you'll need to run the rca's out of the radio into the E.Q. then run the rca out's from the E.Q. to the inputs of your amplifier. and of course there's probably a constant 12v, a switched 12v, and a ground you'll have to wire up.
Feb 17, 2010 | Kenwood KGC-4042A 5-Band Car Equalizer
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
Equalizer doesn't turn on
hookup the remote wire of your EQ to that of the HU or just simply connect it to the positive line but it would make your EQ powered ON all the time. That remote wire of your EQ is to get a trigger signal from the HU so that it will turn the EQ "on".
Apr 20, 2009 | Power Acoustik PWM-19 4-Band Car Equalizer
I need a installation manual for audiobahn a8002t amp.
very simple run a ground from gnd on amp to a good ground spot on car run 12 volt power cable from back of fuse relay by battery to 12v+ on amp then splice blue wire on back of stereo splice in another wire about seven feet run that to remote on amp then hook up speakers its pretty simple to hook up an amp hope this helps
Apr 18, 2009 | AudioBahn A8002T Car Audio Amplifier
Pyramid eq 906vl no remote lead
that unit use just two power wire you have to connect it to an accessory power source that turn of by your car radio
Oct 08, 2008 | AudioBahn AEQ6 5-Band Car Equalizer
INFO:EQ
Sens is ussually a term for the more common "remote
" wire. You will need to look at diagram to be sure but Im about 99% positive that in your case the sens wire is the input wire for a switched ingnition, especially since you say it is located next to theGND and BATT wires. You will need to connect the SENS wire to 12v hot, similar to the BATT wire but this wire will need to be switchable, meaning it can be turned off and on, say when you turn your key on and off, or when you turn your radio on and off. For example, the remote wire output from the back of an aftermarket cd player, ussually blue with a white stripe or just blue, or the ignition wire of your aftermarket radio, ussually red, or the ignition wire of your factory radio, or any 12v switched fuse in your fuse box. They will all work. In a worse case senario, if you have trouble locating a true ignition wire, there is a short cut. If the EQ has an actual power button that you can turn on and off, you can make this short cut by wiring the SENS wire to the 12v hot BATT wire. Then you can manually turn the eq on and off with the power button. Just remember if you wire it up this way, and forget to turn it off when the vehicle is not running, after about 24 hours or so, the battery may be drained somewhat, and you'll have trouble starting your vehicle. This is definately your last option.
The BATT wire needs to go to the hot in the BATT or the memory ( yellow) from the aftermarket CD player. The GND needs to be connected to anything metal in the car that is connected to GROUND, for example the frame work of the dash board that is metal, or the ground wire from your aftermarket radio ( black).
The rca input will be the RCA;s coming from your cd player.
the rca output will go to your amplifier.
Placement is completely up to you.
If it came with brakets, placing it flat against the underside of the dash board should work. But it could litterally be anywhere, and any where where it will suit your needs. Glove box works well too, so does in side the arm rest console, if you can get you wire to reach good luck.
Jan 29, 2008 | AudioBahn AEQ6 5-Band Car Equalizer
Which wire is power and ground
generally red is the ignition wire, black is ground, orange is 12+ all the time, a yellow could be the same....it would be more helpfull if you would give the model number of the eq
Jul 13, 2007 | Kenwood KGC-4042A 5-Band Car Equalizer
AudioBahn AEQ6 5-Band Car Equalizer Logo
371 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
