Question about Gateway MT3705 Notebook
I only get sound out of 1 side even with headphones.
  • Steve Rand
    Steve Rand May 11, 2010
    I was going to post the same solution as wayneard, until I opened this topic and had a look.
    More than likely this is your problem.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    First thing I would suggest is to double-click the volume control on your taskbar (the little speaker) and see if any of the items has the Balance moved to one side. if so, slide it (all) to the center.
  • 33 Answers
Check the balance of your Windows media /audio player. if not then,
one of the speaker of your headphone has stopped working.
Posted on Feb 09, 2009
What is causing humming sound in headphones?
Well, there are a couple things in the troubleshooting process you may want to check first. If Possible,
1. Have you tried a different pair of headphones thru the same jack?, Is it buzzing as well? Then its not the headphones. If the buzzing stops with a different pair, then we proceed to to headphones in question.
so , headphones are buzzing. Both sides? if yes , or even 1-side, then yes, it is a ground issue. can you expose the wiring at the input jack?
Basically, you want to put an ohm meter on each wire and independently check each wire for continuity. check for any breaks in the line, and or check to see if a wire is crossing over to ground via a break. so check each line to itself, then each line to each other.
if you fo not understand on the process of using an ohm meter? you can go to this You Tube link and it will give you a general understanding.
hopefully this gives you a little insight? If not?, ask the question again, and also include the make & model of the headphone set. that always helps;m Thanks,
Good luck.!!
Mar 22, 2016 | Music
I can hear audio from out side of my headphones
They are semi closed headphones, you can get closed type that keep the sound inside the headphones but these are not like this.
You need a different pair of headphones to suit this purpose.
Mar 04, 2012 | Bose QC15 Headphones
I can hear only from the left side of the headphones
1) unplug the headphones and check if sound is ok with laptop speakers
2) try different headphones
Dec 15, 2009 | Toshiba Satellite A60 Notebook
Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
Nov 24, 2009 | Sennheiser RS 140 Consumer Headphones
Only hearing sound out of left side of headphones
i think the problem is in the jack of your sound blaster. since you have already tried different headphones and the problem still persist, and when you use speakers it works fine. i conclude it is the jack of your sound blaster card.
Dec 22, 2008 | Creative Labs Sound Blaster Live! 5.1...
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Nov 25, 2008 | Denon AVR588 Receiver
I hear more from my right side of my ipod with headphones
There is 2 possible reasons this is happening, 1 is that you have better hearing in your right ear or it's possible that your headphones are tangled and if they are the sound waves will not come through fully.
Oct 28, 2008 | Apple iPod nano
Jack
sounds like the headphone socket is faulty. one of the channels could have a stray wire bridging it across to the earth connection. this would also explain the pause, as it would create a short circuit within the electronics.
sugest you take it back to the shop and complain.
May 29, 2008 | Samsung YP-K3 MP3 Player
No sound
Are the lights on the side on? If not try the little switch on the side of the in line remote, also they need to be plugged into the soundcard&USB.
Dec 25, 2007 | Razer Barracuda HP-1 Consumer Headphones
Less sound on one ear than the other
Yeah, based on all of your problems, i would safely say that you have a blown speaker. Call up Bose at 1-800-999-2673. If the headphones are under warranty (1 year) they will replace them for free. If now, they will charge you $100 for a replacement pair, which is quite a deal considering that the headphones cost $300.
Jul 05, 2007 | Bose QuietComfort 2 Consumer Headphones
Gateway MT3705 Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
