Kenmore Series 90 Top load washer. Need to know how to remove the agitator, think something is under there
  • 2 more comments
  • brobogus Feb 03, 2009
    Thanks for your quick reply. With cap off, no bolt , but looks like 1/2 inch socket extension would fit . Is that the tool , Is it right or left hand thread ?
    Thanks
    Is a 1/2 in. extension the tool to use to remove the plastic nut ?
    It is not a socket it is a square piece that runs down thru there. That is what i am needing to know
  • Mark Egan May 11, 2010
    You should be able to remove the center cap, then bolt/nit, then lift the agitator out. Sometimes they crust up with detergent, so be prepared to use WD-40 or PB xxx (can't remember the name).
    Let me know if you have any more questions.
    President:
  • 1,214 Answers
Should be standard right hand. But go easy at it to be sure.
Posted on Feb 03, 2009
  • Mark Egan Feb 03, 2009
    It's been a long time since I took one off. It's either 1/2 or 9/16. You should be able to feel it drop on when you get the right socket.
    You can get an idea of the assembly from here -
    http://www.searspartsdirect.com/partsdir...
    Like I said, it's been awhile since I took one of these apart, so don't recall exactly the right socket and wrench sizes.
I have a Lady Kenmore Ultra Fabric Care Heavy Duty 90 series top load washer that is about 20-25 years old and works very well. I think that an object has slid under the big thing in the middle of the...
if it is like the other you have to remove the top cover of the agitator cap with a small flat head screwdriver, then using a 7/16" socket and ratchet with an extension remove the bolt(right hand thread) and pull up the agitator.
good luck to you.
Feb 08, 2011 | Kenmore Washing Machines
I have a 90 series kenmore Washer, everything works great - but i am getting what appear to be rust stains in my thinner white clothes. I think something is rusted out under the spinner - is this possible...
If you have a steel innerdrum, there could be rusted hole through it and maybe they are under the agitator cone that you cannot see. You can certainly replace the inner drum but you will need to know how to remove the agitator and the special spanner nut that is difficult without the right tools. The agitator can at least be removed without too much trouble so you can see if there is any rust holes where you can't see. Goodluck, MACGIVOR
Dec 27, 2009 | Kenmore 15864/15862 Top Load Washer
I think something is stuck under the washer basin I don't know how to remove agitator
on the old type you turn the centre top to unscrew it. pull up the agitator and replace the same way
May 09, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Remove agitator on Kenmore 90 series
ok take the top off the agitator there is a cap carefully remove this cap and then some have a inner cap with a handle remove that also in side the agitator it has a 1/2" or 7/16" head bolt remove the bolt and then pull up really ******* the agitator. to replace dogs you have to break the taps holding them in not the agitator be careful
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Baby clothes under the ringer
Loosening top plastic nut and removed top 1/2 of agitator, then loosened nut to lift out bottom 1/2 of agitator.
Jan 02, 2009 | Kenmore 24032\24036 Top Load Washer
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
