Question about Yamaha HTR-5940 Receiver
Want to connect my RCA sub to my yamaha htr-5940 reciever
When i connect the sub using speaker wire and the speaker level inputs it works fine, but when i connect it using a sub cable i cant get it to work. If anyone has any suggestions it would be greatly appreciated.
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Posted on Feb 04, 2009
    Scholar:
  • 93 Answers
You may have to go into the speaker setup menu and choose SUBWOOFER YES/NO select Yes, this does enable the low level line output on receivers, so now the sub receives signal from the output, if you are getting low end sub sound using the speaker wire in/out from receiver to speakers it probably is not a Subwoofer failure issue, so I would investigate the setup option.
Can I use a JX-S900 Y/C separated I/O to run two subwoofers out of same reciever??
Yes, on two conditions:
1) the JX-S900 needs to be a proper matrix switcher. It has to have the ability to route 1 input to more than one output.
2) the sub signals need to be low level RCA/phono, and not high level speaker wire connections. That's not just about the type of connector. It's about the signal going through those wires. A low level RCA/phono sub connection conducts a maximum 0.7 Volt. A speaker wire connection can transmit 30 Volts! If you put 30 Volts in to a line level switching device such as the JX0S900 you'll fry it.
Provided that the above two criteriia are both met, then yes it will work.
  • Connect the AV receiver's sub out to Source 1 - white RCA phono.
  • Connect the two subs mono LFE Left input (white RCA) or the single black RCA/phono inputs to the JVC's outputs 1 and 2 - white RCA/phono.
  • Set the source routing: input 1 goes to output 1 and 2
Sep 17, 2014 | Audio Players & Recorders
I have the Yamaha HTR-5940 and it has worked fine for years. Today turned on and there is no sound for the TV. Sound works fine for DVD, and radio. I have tried everything except toss it out the window....
did you connect the cables correctly most probably to get sounds out of a tv it should connected to the 3.5mm headphone jack.
you would need a Rca to 3.5mm cable for this
Oct 20, 2017 | Yamaha HTR-5940 Receiver
I have a rca no rtd250 impedance 12 ohms subwoofer. how do i connect it to my yamaha htr 5940.do i need a special cabel where do i get it.
The Yamaha can only drive powered subwoofers. Make sure that the RTD250 has it's own amplifier built in, you won't be able to easily run it off the yamaha if it doesn't.( the powered subwoofer will have a mains cord to power if it's correct) If it doesn't have a amp built in, easiest weay is to buy a cheap powered sub.
Is the RTD 250 the sub fromthe RCA home theatre pack?
Jan 14, 2010 | Yamaha HTR-5940 Receiver
HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Jun 26, 2009 | Yamaha HTR-5740 Receiver
No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Mar 31, 2009 | Yamaha RX-V363 Receiver
Left from speaker not working- Yamaha HTR-5940-6.1 channel
Redbird,
What do you have in the "multi channel input" jacks on the rear of the receiver? Those inputs Right, Left, Center, Surround R+L, and Sub are used when selecting 6 channel mode. They bypass the receivers surround processor board.
John W
Jan 10, 2009 | Yamaha HTR-5940 Receiver
Yamaha HTR-5940 turns off after one second.
HI my Yamaha is working fine exept input selector , I selilng it for parts 45 , amp working fine exept inputs ( one milti channel in works fine) korrado6@hotmail.com
Jun 21, 2008 | Yamaha HTR-5940 Receiver
Yamaha htr-5940 with Acoustic Research wireless speakers AW877
use a 4 way splitter directly off the cable box 1 pair off cable to two out puts from cable box my setup works even tv is off I use it for music with tv off
Jun 03, 2008 | Yamaha HTR-5940 Receiver
HTR-5940 6.1 Channels
Every time this has happened to me it was either due to incorrect speaker impedance or incorrect polarity (+/- wires reversed).
Apr 21, 2008 | Yamaha HTR-5940 Receiver
Subwoofer
i have the same tuner.on the back you will see all connectors bottom row of rca jacks you will see subwoffer if your sub has to rca. red/white use a splitter monstor cable gold ..works best. i use Home Theater Reserch speakers... you can also plug your subs power plug into the tuner snd you never have to power it on seprate .........
Dec 08, 2007 | Yamaha HTR-5230 Receiver
Yamaha HTR-5940 Receiver Logo
269 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
