I have a ABIT-NF7-S2G. I am trying to format my computer however the usbs do not have power before the operating system starts so my keyboard does not work. How can i fix that?
  • Francisco A
    Francisco A May 11, 2010
    In the BIOS their is a option that allows USB to be powered on start. Search around and you will find it
  • 106 Answers
Hmmm. your System has an PS/2 slot for keyboard? you need to use ps/2 socket keyboard so that you can operate the bios set up and format your drive.. then if you finish put it back the USB keyboard.. ^^
Posted on Feb 03, 2009
The computer fell over and the jumper came loose now I dont know where it goes
Starting from page 16, in the manual you can find the jumper configurations.
Regards,
Andras
Oct 04, 2010 | Abit NF7-S2G Motherboard
Hi. i have abit motherboard nf7 s2. i bought 2
Did you make sure to install the memory starting from DIMM3? You should install into DIMM3 then DIMM2 according to the NF7 manual.
Mar 14, 2010 | Abit nForce2 NF7-S2 Motherboard
Driver for motherboard abit nf7 - s2g
Open the Abit NF7-S2G link provied below and download the drivers located to the right of the page listed under, Support Information.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF7-S2G&fMTYPE=Socket+A
Cheers'
Mike
Mar 03, 2010 | Abit NF7-S2G Motherboard
Abit NF7-s v2- hynix ram support problem
your system does not support the dual ddr ram unless you have a add-on VGA card
I have included the link to the user manual ... see chapter 1 section 1-1 Features and Specifications
Abit NF7-S v2
Supports DDR 400 only when using an add-on VGA card (NF7-M)
Feb 13, 2010 | Abit NF7-S V2 Motherboard
KB Genuis Luxemate 320 USB can not choice OS in loader's menu.
Try to change in the BIOS the option "Keyboard USB" from value "OS" to "BIOS".
Mar 18, 2009 | Abit NF7-S V2 Motherboard
On/off leads disconnected
If you have the Ports of the board facing you...
as you look down at it on the top right hand corner (ish) there is a black block with pins sticking out of it (some pins will be missing)
if you look next to that on the actual board it will have white writing saying [pwr] [hdled] [reset] etc...
thats where it tells you what cables go where
Let me know...
Matt
Jan 22, 2009 | Abit NF7-S2G Motherboard
No display at post
There are a few things that can cause no display on the monitor.
That single beep means POST = Power On Self Test. Post has tested everything on you're board to be good.
The cable between video card & monitor may be bad or not connected correctly (Swap out the cable as last resort).
2. You're monitor is defective, try swapping it with known working monitor.
3. You're video card is not functioning.
Lastly, when you reset the system cmos/bios everything went back to default. This means you're bios is now using the onboard PCI video graphics. Remove you're radeon 9600 video card. Try booting the system. You should see display again. The only way to test you're radeon would be to boot to the bios & set bios to boot using the AGP radeon. You need to change Init Display First to AGP & not PCI. If you loose video than you know you're AGP card is bad. Reset the cmos/bios before adding another AGP card or you will not get display. This setting is on pg 3-5. Integrated Peripherals. If you need you're manual you can download it from this link: http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF7-S2G&fMTYPE=Socket+A
Good Luck!
Mike
Jun 06, 2008 | Power Color RADEON 9600 (128 MB) Graphic...
Abit NF7-S Nvidia2 Failed to Boot
Try swapping the power supply and as Nitro says also check the cable and connector from the power switch to the mainboard.
Jan 12, 2008 | Abit nForce2 NF7-S2 Motherboard
Computers & Internet Logo
324 people viewed this question
David Payne
David Payne
