Question about 2wire 1000-200004-000 Network Adapter
I have a PC with Windows XP, that I can't connect to the Ethernet, I look to Device Manager and I got an interrogation yellow mark of <2 Wire USB Remote NDIS Ethernet>, What it does mind?
  • charles36 Feb 09, 2009
    I appreciate the solution to my problem. Thanks
  • 73 Answers
Download and install the driver for it here:
http://www.2wire.com/pages/drvrs/twusb1405.exe
Posted on Feb 06, 2009
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
Htc touch hd not recognised and will not install to pc. running on windows xp
You need to first install activesync, this will then install the USB drivers for XP. Once this is done, then connect your device and your PC should see your mobile.
If you still having problems, trying removing the unknown device from Device Manager.
1. Click start 2. Right click on My Computer 3. Go to Properties 4. Go to Device Manager 5. Check for a yellow triangle with an exclamation mark 6. Remove this device 7. Follow instructions above
Mar 02, 2011 | HTC Touch HD Smartphone
Sandisk is not being recognized on my computer
SOLUTION 1 - Verify if minimum system requirement is met.
SanDisk card readers support Windows Vista, Windows XP SP2 and Windows 2000 SP4.
For MAC users, see
Troubleshooting USB device on MAC
SOLUTION 2 - Verify the reader's status under Device Manager.
STEP 1 - Connect the reader to the PC
NOTE: It is recommended that you plug your card reader to the back USB port on your PC to ensure that there is enough power from the USB port for the card reader to be detected properly.
STEP 2 - Check under Device Manager
1. Right-click My Computer.
2. Select Manage.
3. On the left pane, click Device Manager.
NOTE: The card reader will appear in two places: Disk Drives and Universal Serial Bus controls as USB Mass Storage. If there is a yellow exclamation point (!) or question mark (?) next to the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action, and then click Scan for hardware changes.
STEP 4 - Verify if the reader is detected
1. Double-click My Computer.
2. Look for the card reader under Devices with removable storage.
SOLUTION 3 - Try other USB ports.
A yellow exclamation point (!) under Device Manager usually means that the device is not receiving enough power. If the reader is not receiving ample amount of power from the USB port, it may not function properly.
SOLUTION 4 - Change the drive letters
NOTE: The SDDR-89 reader should show 4 drive letters under My Computer.
Mar 01, 2010 | SanDisk Sansa m250 MP3 Player
Dell dimension 5150 ethernet problem reloaded windows xp home from a windows xp entertainment os. apear fine but not receiving.
Okay, so it seems you installed Microsoft Windows XP Home on a what was Media Center Edition installation, and the ethernet is no longer worker.
Please refer to dell.com's support section, enter your model, and download drivers that you need.
To find drivers you need, Go to start --> control panel and then go to (under classic view) system --> the hardware section, open up device manager, and then look for ones with a yellow big question mark, and get those drivers from dell's website. Burn these drivers to a CD on another computer, or use a USB flash drive if that does work.
Good luck.
Jul 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Ethernet controller
Go to device manager(right click my computer---Properties---harware tab---Device manager). See if there is yellow mark on ethernet controller or not and upadte ma the same. If there ie a mark over it, install drivers for the same.
Mar 31, 2009 | Microsoft Windows XP Professional for PC
Acer extensa 5620
i have laptop acer extensa 5620z, install windows xp professional os 32 bit, inside device manager open that time
Ethernet controller
Ethernet controller
Mass storage controller
Pci device
Pci device
SM Bus controller
Universal serial Bus (USB) controller
biling the yellow(!) mark, and usb device put in the usb port not open how to solve this problem, please reply me, thankyou,
my email senthil_japan@yahoo.com
Jan 26, 2009 | Acer Extensa 5620 Notebook PC
Installing xp on acer aspire m1610
First you want a Windows Xp genuine CD and most of the drivers are built-in in Windows xp, also try to install windows xp with service pack 2 and after installation go the device manager and see how many device required drivers as you can see them with exclamation marks or question marks. go to google and download the device driver run it inside your pc also i recommend before you do got to device manager and indentify all your dirvers like VGA Sound and other devices
Jul 02, 2008 | Computers & Internet
ERROR: code 28 -- Windows XP & USB 2.0
I'm unable to connect my western digital hard drive to my Windows XP computer via the USB port. When I check the USB 2.0 Controller in the Device Manager, there is a yellow exclamation mark (!) next to it. When I check on the status of the USB 2.0 Controller, the following message appears:
The drivers for this device are not installed (code 28).
What do I do now?
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
2wire 1000-200004-000 Network Adapter Logo
240 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
