Question about Hitachi 53FDX01B 53" Rear Projection Television
The television is whistling with no picture - Hitachi 53FDX01B 53" Rear Projection Television
  • gaurav bv Feb 14, 2009
    television whistling with picture and sound on
  • Hitachi Master
  • 5,568 Answers
Your sets use CRT technology and the whistling is probably caused by the failure of the high voltage supply which operates at ultrasonic frequencies and normally should not be audible at all. When the frequency falls to the point of being heard, the circuit is no longer producing the high voltage needed by the CRTs.
Not knowing your sets, I can't say whether the HV supply is separated from the main supply or not but you should be able to determine this by opening the back of the unit and visually tracing wiring and cables from origins to the CRT area. If it is separate, then a call to the US Hitachi customer service should get you the cost of a replacement or repair.
Posted on Feb 15, 2009
Philips 60PP9202 60 in. Rear Projection HDTV-Ready Television no Picture no sound
Are you getting some kind of high pitched squeel from set when you try to turn it on?
The more you tell me the more I can help.
Nov 10, 2011 | Philips 60PP9202 60" Rear Projection...
Can't get a picture on tv
high voltage issues.
needs a power supply/deflection board or maybe a flyback transformer
200-300 $
May 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung DLP HL-P4663W - loud whistling noise while the TV is on
That most probably seems to be a future issue with your color wheel, it's starting to go out, you need to identify which one you have before you purchase one, there are two kinds, one with a gold bearing and another one with a silver bearing
Jul 24, 2009 | Samsung SP46L3HX 46" HDTV-Ready DLP TV
No picture- no sound
hi
first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 12, 2009 | Mitsubishi WD-65732 65" Projection HDTV
No picture no sound just a whistling noise
maybe the flyback transformer or horizontal output ic
Jun 01, 2009 | RCA 27R411T 27" TV
Super high pitch whistle from tv, only powering it off helps.
Shut it off and unplug. You have a serious HIGH VOLTAGE problem that could cause a fire. Professional repair needed.
Mar 07, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Problems at start
Please email me the model number for the tv so i can better assist you.
Thanks,
Tim Nolan
Experttv@comcast.net
Oct 09, 2008 | Sony KP-53HS30 53" Rear Projection...
Television won't power up
It sounds like the high voltage circuit got damp and arced. This arc caused the horizontal output transistor to short.
You might try replacing the output transistor if you're experienced in this type of repair. If not then you need to take it to a repair shop.
The "whistle " you're hearing is the power supply indicating that it has a short on its load. When the power supply has an over load (short) its frequency drops down when your ear can hear it oscillating. This type of power supply is a switching power supply normally operating a several thousand hz(cycles) which is out of range of human hearing.
Stargazer
Mar 15, 2008 | Televison & Video
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 53FDX01B 53" Rear Projection Television Logo
43 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
